Fuel System Cleaners... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 08-25-2009, 10:01 AM Thread Starter
kakilakslick
kakilakslick's Avatar
I went to get an oil change at Jiffy Lube and was told my injectors has some carb building up. They offered their fuel system cleanse or whatever its called but I didnt get it. I noticed my gas mileage has gone down over the past 2 weeks. I want to try the bottle fuel system cleaner before getting it done at a shop. Has anyone used the bottled fuel system cleaners?
'04 Durango HEMI Limited 4x4
Giovanni DBL-G 22" Wheels
Nexen Rodian 285/45/22
Flowmaster 70 series
Infinity Reference Components
JL Audio 4Ch. Amp
JL Audio G-Max Mono Amp
12" Pioneer Premier Subs
kakilakslick is offline
post #2 of 11 Old 08-25-2009, 11:38 AM
chesterspot
chesterspot's Avatar
Chevron's techron is one of the only real proven fuel system cleaners. Your mpg would more likely be from spark plugs or a clogged fuel filter. The best way to clean the injectors is to remove them and clean them but that's a pain and unless you are at 100k+ miles it's not worth it. Get down to a 1/4 of a tank, add the additive, drive it until you need gas.
Also, doing WOT runs kinda does the same thing as cleaning the injectors since you are dumping a lot of fuel from them and well gas dissolves most things.
2005 D. 5.7L 2WD - Adventurer - Mule (Not as fast as a horse nor as stubborn as a donkey.. The best of both worlds)
Custom Magnaflow Exhaust w/ Side Exit
HEMI Orange Mamba Intake -#6 DIY Mamba CAI Club
Planned: 9.25 LSD, Maybe a gear change as well.
2001 Nissan Maxima SE 20th Anniversary Edition
1968 VolksRod - For Sale - Parts/Off-road only
chesterspot is offline
post #3 of 11 Old 08-25-2009, 12:18 PM Thread Starter
kakilakslick
My truck has 84K miles on it. I bought it with 66K on it. I got some of the Lucas fuel injector cleaner. I had the STP brand but the guy at autozone said Lucas was better. A co-worker said the same. I was already close to empty so I put half a bottle in and filled her up. Hopefully, my mpg will go back up soon.
JL Audio 4Ch. Amp
post #4 of 11 Old 08-25-2009, 02:42 PM
Dodge4L1fe
Quoted: 43 Post(s)
I agree with everything Chesterspot stated above... I don't use additives often, but when I do I use STP... don't fall for the price difference stated by many of the salesman at checkout
Regarding the fuel filter, does anyone know where it is located on our 5.7L Hemi engines?
Dodge4L1fe is offline
post #5 of 11 Old 08-25-2009, 03:06 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
if the 5.7 is like the older magnum motors, the fuel filter is probably in the fuel tank.
As for the dirty injectors, that is from the fuel used, Runs some of the chevron fuels, shell would be my next choice.
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #6 of 11 Old 08-25-2009, 03:08 PM
Dodge4L1fe
Quoted: 43 Post(s)
I'll check into that... thanks! Definately run good quality gas
post #7 of 11 Old 08-25-2009, 04:08 PM
Sir_Eagle
Hemi User
Sir_Eagle's Avatar
Quoted: 1 Post(s)
According to my Haynes Repair Manual:
There are two.
One is a nylon mesh strainer at the lower (inlet) end of the fuel pump/fuel level sending unit module. Located on the top of the fuel tank, protruding down into the fuel.
The main filter is part of the fuel pump/fuel gauge sending unit assembly.
'06 Durango SLT 4x4 / 5.7L Hemi / Tow Package
Drop in K&N Filter / Airaid Intake Tube / Breather Hose Filter / Rubber Flap Removed / Power Wire
OEM Running Boards / Bug Deflector / Side Window Air Deflectors / Molded Splash Guards
Ram Head Hitch Cover / 12" Black Stubbie Antenna / 20% Tinted Fronts
Resonator removed / Magnaflow 22" (12578)
265/70/17 General Grabber AT2 / Monroe Reflex Shocks / TB Lift(6 turns) / Drilled/Slotted Front Rotors
Sir_Eagle is offline
post #8 of 11 Old 08-25-2009, 04:22 PM
PKRcaver
How did they know you had carbon on your injectors? Did they pull an injector to look at it? Did they do a spray pattern and flow test? Do you think they might be trying to sell you a service that may not be necessary? Why not go for the transmission flush, and nitrogen in the tires while your there?
You can put in a lot of bottles of Techron, for what they charge. You were right to walk away.
PKRcaver is offline
post #9 of 11 Old 08-26-2009, 11:21 AM
Beach Assault
Beach Assault's Avatar
Quoted: 12 Post(s)
^Yep! x2!
Big Black Limited w/Hemi and 20" Chrome Ram Wheels
Roof Carrier for 20" Spare
Removed Front Spoiler
Tinted Front Windows
Blackened Tail Lights
SmittyBilt Grill Guard
Blacked out the grill
1 1/2" Torsion Lift
Westin Sidebars
OEM Mudflaps
Rancho RSX Series Shocks
Red Brake Calipers
Slotted Rotors
Hawk Pads
MOPAR/Magnaflow CAT-Back exhaust
SuperChips[tm] Tuned 93 Octane
Taylor "Shorty" Sparkplug wires
Home-built PVC SRI
DodgeTalk.com Durango Club Member #41
Beach Assault is offline
post #10 of 11 Old 09-02-2009, 04:18 PM Thread Starter
kakilakslick
Im glad I didnt fall for their fuel system flush. I used a bottle of Luca Fuel Injector cleaner. It works pretty good. I went from 15mpg to 16. I was getting 16.7 on the interstate. $16 tune-up in a bottle.
JL Audio 4Ch. Amp
post #11 of 11 Old 09-02-2009, 04:43 PM
matted2thefloor
matted2thefloor's Avatar
Replace the spark plugs and air fliter soon too ifthey haven't been done recently ( within the last 30,000 miles ). I see you have 22s on there...that in itself is going to affect your MPGs.
My D averages 17.9-18.8 on the interstate running the cruise with A/C doing 80+. If I drop it down below 70...it goes over 19!!! I saw 19.3 the last time we went to FL..was running about 70ish when I got that MPG...
I just replaced plugs and air filter today...so we'll see if in-town MPG increases...usually have been seeing about 13.5-14.1 in-town. I run Hess 89 octane...
04 D 5.7 SLT AWD (hers)(gone 3/12)
99 Cobra (mine) SOLD
00 Toyota Camry
06 Toyota Avalon Limited (hers)
matted2thefloor is offline
    fuel injection cleaners thefuneralman 3G Dodge RAM - General Talk 19 02-11-2009 11:03 AM
    Are fuel system cleaners good or bad? rebelram01 2G Dodge RAM - General Talk 12 02-08-2006 06:31 PM
    Fuel injector cleaners TREP R/T 3G Dodge RAM - General Talk 6 04-29-2005 07:42 AM
    Anyone tried fuel cleaners with 5.7L? onyxmonk 3G Dodge RAM - General Talk 7 12-27-2004 10:14 PM
