lower transmission line removal from radiator? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 08-18-2009, 09:06 AM Thread Starter
LuckyBadAzzBoy
I have a 1999 ram 1500 4x4 automatic with a 5.2 liter engine. I'm replacing the radiator and i can't figure out how to remove the lower hose of the transmission line from the radiator core. I removed the nut and the tube seems to be pushed into the fitting? The haynes repair manual really doesn't say anything. I need help on this. Thanks
LuckyBadAzzBoy is offline
post #2 of 4 Old 08-18-2009, 12:19 PM
UNHPistol
UNHPistol's Avatar
That should be a quick disconnect. You can get a quick disconnect set at Sears or any of your local auto parts stores, they're usually pretty cheap. They'll probably be labeled as fuel line disconnect tools.
1999 Ram 1500 4x4, 318
Current mods:
K&N FIPK, F&B 50mm TB, MOPAR M1, Harland Sharp 1.6 Rockers, MOPAR valve gear, custom grind CompCam, Hedman shorties, Magnaflow hi-flow cat, Flowmaster cat-back, MOPAR PCM, March Perf. Power & Amp pulleys, MSD Blaster 3
UNHPistol is offline
post #3 of 4 Old 08-18-2009, 02:05 PM
djturnz
djturnz's Avatar
Quoted: 16 Post(s)
Yup, he's got it right. You'll need the fule line tool (under $10 from Autozone) to pop it off.
When I pulled my radiator I didn;t have the tool so I cut the part off the old radiator and then slid a piece of plastic over it to remove it. I forget what I used, but it was shaped like a pen cap, but larger.
98 Ram SS/T, Black (work in progress)
94 Ram 1500 Reg Cab, Long Bed (headed for scrap soon)
djturnz is offline
post #4 of 4 Old 08-18-2009, 06:36 PM Thread Starter
LuckyBadAzzBoy
Thanks very much UNHPistol and djturnz it worked perfectly. Have a great week you guys.
    Transmission line leaking at radiator RobbsRamSST 2G Dodge RAM - Drivetrain Talk 4 02-03-2009 09:06 PM
    Transmission cooler line removal tool gergregg 3G Dodge Ram Performance Talk 23 03-05-2008 10:57 PM
    Lower radiator hose Grey Ghost 2G Dodge RAM - General Talk 0 12-04-2006 07:58 AM
    Trans flush.. which line is the return line from radiator? Damn Dirty Ape 2G Dodge Dakota - Drivetrain Talk 1 06-27-2006 09:39 PM
