:teacher: Ok, for anyone who wants to add LED replacement bulbs to our rams, and they have a 02-06 ram with the circut boards on the tails, most charts will tell you to use a 3057 bulb, more commonly known as a 3157, well what most wont know is that there are whats called a 3157 SRCK bulb, so what that means that the 2 bulb types share plug sockets but the wiring in the sockets are different, now why is this little bit of information important, because the use of a regular 3157 LED bulb can cause a few different things to happen, some as simple as the bulb just not working, but also a bulb i tested actually caused a short in the system, which had it been hooked up to the truck, it would have shorted out the FCM, and we all know the FCM is not something to mess with on our truck, and its not a cheap part to mess up on a regular basis, so in short if you are going to replace the bulbs in your tails with LED bulbs BE VERY CAREFULL, if you get the wrong one it can be a costly mistake.
now this only applies to the TAIL LIGHT CIRCUT BOARDS, of an 02-06 ram, no where else is this a concern to our trucks, if you have an 07-up, you dont even need to be reading this
Below is a few PIX that show the difference in the wiring between the 2 bulb types
This happened to me. I've bought 3 different types of LED bulbs and they all started smoking once I plugged them in. What a nightmare. Now I shall try this one more time. Thanks Demon!
With LEDs its reccomended that you match the color of the lense with the bulbs, ex: red tails - Red LEDs, i just didnt mention the SACK ones to avoid any confusion, and so no one goes and buys amber bulbs for brakelights
I would read this AFTER i bought bulbs I shouldnt have bought. The LED's i put in are extremely weak and caused the "lamp out" light to come on and now the check engine light just popped on. Is this a result of the wrong type of bulbs being installed?
first thing is put your regular bulbs back in asap, then as long as they all still function the fcm should be ok, but putting in the wrong bulbs can cause a short, which would blow fuses and possibly fry your fcm, so if you replace all bulbs with factory ones and they all work, start checking EVERY fuse, and then reset the pcm and see if the CEL comes back on
Dont do that seriously. Thanks for your help Demon i got it all sorted out now. One of the bulbs wasnt in all the way causing the lamp out light to come on.
glad to hear you got it all sorted out, now just put about 50-100 miles on your truck and see if your CEL comes back, if it does tell us about the code and we will see whats up, but also if you want to still put LEDs in your tails the type of bulbs to get are listed in this thread but i can give you a few sites that sell LEDs but the srck bulbs are more expensive than the rest but they wont short you out, and also if you do this man, remember your resistors!
then thats all you need is any that will plug into those sockets, but make sure you get RED bulbs and not WHITE, you always want to match the lens color to the bulb color on the LEDs or you will take away from the light output
hey demon what led light would you recomend for the reverse light i want to get a set of led tails but none come with a led reverse so what one would you suggest for that or am i s.o.l.
cant do it my emergency lights are on a bracket the holds my plate so that wont fit in there.... thats why i was asking about the ones for the tailights
so demon with this set of bulbs are they just plug right in no probs no haven to wire resistors to it or anything like that
Related Threads
DodgeTalk Forum
4.7M posts
289.9K members
Since 2002
