trucks trans keeps going into safe mode
- Posted: 07-27-2009, 01:16 AM
Post #1
I have a 1999 dodge ram 2500. First my truck was jumping from 3rd the 4th and then would be stuck in first gear (safe mode I guess) whenever I shut the truck off then started it back up. I fixed that with the cheap trick of wraping the wire off the alternator in tin foil then wraping it with electric tape. The truck doesnt jump from 3rd to 4th anymore but almost every time now it will go to safe mode anytime I start the truck up and start driving. I have to pull off the road disconnect the battery for a min or so then hook it back up it is getting really anoyying to keep doing this. What do I need to change out or fix to stop this from happening. Now that I have taken the battery termenals off and on so much they are pretty much shot. Can just the terminals be replaced or are they special ones because they have that alternator wire in with the terminal. Could a dodge dealer or someone change them out or would they order the whole new wire harness. Could these worn out terminals be my problem in the first place with it going into safe mode or is the a transmission computer that is most likely bad that I could change out?
| Sponsored Links |
Posted: 07-27-2009, 08:59 AM
Post #2
ahhhhhh your in for some fun now, just went through the whole deal, here is right up on troubleshooting it. first thing plug in and get the codes out of the puter.
http://www.turbodieselregister.com/f...les-fixes.html peace, B.
-98,12V,quad cab |
Post #3
That just happened to my 2K Caravan (yes, I KNOW they are different) but it might not hurt you to check this out. Check out the vehicle speed sensors (on my Ram there were 2, one on the tranny and one on the rear diff; I'd change the one on the trans first). AAMCO transmissions wanted $800
to take the trans apart just to see what was wrong with it. A small trans shop in a town near me charged me $50 to change the speed sensor. ![]()
1999 Dodge Ram 1500 Sport Quad-Cab 4x4 5.9L ![]() Brand new Fog Lamps (!&#*~@! Deer!) ![]() Cat-back Duals, BFG Long Trail T/A's P265-75R16 ![]() More mods to come as I can afford them! ![]() 2005 Dodge Neon SXT: My Econobox! ![]() Other cars and trucks from different makers but ALL American!
Posted: 07-27-2009, 10:16 AM
Post #4
U was just about to ask this becuase a dodge tech was telling me to try changing the speed sensor. |
| Sponsored Links |
Posted: 07-27-2009, 04:39 PM
Post #5
that is why you pull the trouble codes first so you know what your trying to fix.
-98,12V,quad cab |
Posted: 07-27-2009, 05:40 PM
Post #6
the shop wants $50 to hook there scanner up to pull the codes and the speed sensor is $40. I think I am going to try my luck.
Posted: 07-27-2009, 05:47 PM
Post #7
any pep boys, schucks etc... have the scanner, you use them for free at there store.trust me this can be a simple or big deal to sort out, guessing aint going to fix it.
-98,12V,quad cab |
| Thread Tools | |
| 98 caravan Overheated - trans stuck in limp mode - HELP PLEASE | warstoryz | Caravan Talk | 1 | 09-27-2008 12:20 AM |
| Maximum safe trans temperature? | mullerjd | 2G RAM - Drivetrain Talk | 6 | 07-11-2005 07:44 AM |
| 1991 dodge dyansty/controller safe mode problem | mikebd | Other Dodge Vehicle Talk | 0 | 01-28-2005 08:40 PM |
| what kind of automatic trans came in the 1989 dakota trucks? | MoParts | Dakota 1st Gen (Pre-1997) Forum | 0 | 08-09-2004 06:00 PM |
| Sponsored Links |
