Brake Light Warning Light - In Dash - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 07-26-2009, 01:48 PM Thread Starter
mistypotato
mistypotato's Avatar
Quoted: 14 Post(s)
Can anyone save me some research and tell me about the brake warning light on the dash over on the left? On most cars, this is the light that would indicate the Parking Brake is ON. But it isn't.
By the way, my brakes work fine and the taillights come on as they should.
The light stays on constantly whether the Parking Brake is on or off.
Does the BRAKE warning light indicate other brake problems or just that the parking brake is on?
thx
1999 Grand Caravan SE 3.3L Flex Fuel - Approaching 300,000 miles
2006 Caravan SXT 3.3L - Lowest mile Gen 4 engine Caravan in the USA. (3,700) - See full rebuild documented
mistypotato is offline
post #2 of 3 Old 07-26-2009, 03:47 PM
StandOnCliff
StandOnCliff's Avatar
The brake light functions in two ways. One with the e brake and another when there is a problem with the system. Most likely the cause is either low in fluid or a line is leaking. If it's just low in fluid this is a sign it needs new brake pads and soon. If it's low in fluid, see if you have any wet spots on any brake lines or around the drums and calipers from the inside of the wheels. Look around the master cylinder too. If you find evidence of leakage this will be why your reservoir is low. The front brakes do the majority of the stopping so if you don't notice any brake problems, check the rear brake system over entirely. If you can't find any sign of leakage or the master cylinder is full. It could be a bad switch on the ebrake. It could also be a bad master cylinder,it's sign of being bad is usually pumping the brakes once or twice gives a much firmer feeling pedal, after looking and finding no evidence of leakage.
StandOnCliff is offline
post #3 of 3 Old 07-26-2009, 04:04 PM Thread Starter
mistypotato
Quoted: 14 Post(s)
Ok,
I've done brake work for years so this is good stuff for anyone else searching on brakes.
Mostly I needed to know how the brake warning light worked on this model since I've only had it a month now.
thx,
    Brake Warning Light On jmbones 2G Dodge Avenger - General Talk 5 11-13-2008 08:31 AM
    warning light on dash and racing RPM's jcnlmorris Dodge Caravan General Talk 3 04-20-2008 11:03 PM
    Warning Signal Dings But No Warning Light on Dash harcum1 Dodge Caravan General Talk 6 09-05-2007 09:44 AM
    Brake light out...not LAMP OUT light on dash jlee989 3G Dodge RAM - General Talk 5 08-09-2007 08:24 AM
    Parking brake warning light and anti lock dash lights on RoadRam 1973-1993 Dodge RamCharger 3 10-24-2006 06:45 AM
