Error codes P601 and 1684 on Dodge Caravan 2001 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Vehicle Forums > Dodge Caravan/Grand Caravan Talk
va2gwy
  Error codes P601 and 1684 on Dodge Caravan 2001 - Posted: 07-09-2009, 05:39 PM
City: montreal
State: QC
Post #1
I was coming back from work today , the check engine light came on . At home , i 've extracted the codes P601 and P1684 . Seems to be computer internal error (601) ,battery resetted within 50 starts (P1684). Four questions:
Can i run the car without any problems for few days?
I'm suspecting that the PCM would need to be replaced ?
What is the approximately for a new PCM ?
I heard that PCM has to be reprogrammed by Chrysler if replaced
Need help !
bw03
 Posted: 07-09-2009, 06:45 PM
City: Boston
State: MA
Post #2
You're probably fine for a few days, if not weeks but there's no guarantee. I got my ECM within 3-4 days on ebay. Also, a rebuilt one on ebay will not need to be programed by the dealer. See these threads for more details.
http://www.dodgetalk.com/forums/showthread.php?t=257121
http://www.dodgetalk.com/forums/showthread.php?t=253436
va2gwy
 Posted: 07-10-2009, 07:30 AM
City: montreal
State: QC
Post #3
Just called Chrysler , the cost for a new PCM is 975 $ Canadian . They said that this module does not need to be flashed with mileage and VIN. (the BCM does!) . So why some US website that sells refurbished PCM would require this info ? Any ideas or thoughts?
bw03
 Posted: 07-10-2009, 08:46 AM
City: Boston
State: MA
Post #4
No idea about the mileage but the companies use the VIN to determine the build on your van. They don't want to flash it for a 3.8 liter engine if you have a 3.3 liter. When I got my ECM, they had a sticker with my VIN on it. Probably for tracking and warranty purposes if need be..
va2gwy
 Posted: 07-10-2009, 08:53 AM
City: montreal
State: QC
Post #5
Just talked to the dealer . They mentioned that the code P601 might be related to the BCM . I'm confused , any toughts ?
bw03
 Posted: 07-10-2009, 09:12 AM
City: Boston
State: MA
Post #6
When you say P601, I assume you mean P0601. The P0601 means a checksum error in the PCM/ECM for our vans (according to what Autozone told me). I'm not sure if there is a code for the BCM.
Edit: Just went to autozone site and pulled these based upon a caravan 3.3 liter.
P1684 - Battery Has Been Disconnected
Possible Causes:
Quick Learn procedure was performed with scan tool
TCM battery direct (B+) circuit is open or disconnected
TCM power ground circuit is open
PCM/TCM was disconnected or it has been replaced
P0601 - PCM Random Access Memory Failure, Self-Test Failed
Possible Causes:
PCM needs to be replaced, and then reprogrammed
Rick99
 Posted: 07-10-2009, 11:05 AM
City: NH
State: NH
Post #7
The PCM does store the VIN and a new one would have to be set up for your vehicle, but that doesn't take a dealer very long to do. If you haven't already come across it, it's very important to have the PCM properly programmed if you have the Sentry Key system (chip in the key), since the PCM stores the key codes and the van won't run unless they're set up with your keys.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
Just got a new set of BFG All-Terrains
Planning retrofit to 4WABS
1999 Durango SLT+
4x4, 5.2l
Mods: B&M Supercooler, Ford OEM Remote Start/Keyless Entry/Alarm, Heated Seats
01 T&C Limited 3.8l
va2gwy
 Posted: 07-10-2009, 12:13 PM
City: montreal
State: QC
Post #8
According to the dealer, the van will run even if the PCM is not programmed .
bw03
 Posted: 07-10-2009, 07:01 PM
City: Boston
State: MA
Post #9
The dealer is wrong. It needs to be programmed to your vehicle with it's specific options (unless the donor vehicle is optioned exactly the same as yours). Don't say we didn't warn you if it causes damage to your BCM too. The rebuilt ones that you can buy come programmed by the rebuilders.
va2gwy
 Posted: 08-06-2009, 11:41 AM
City: montreal
State: QC
Post #10
A quick update, i've changed the PCM 4 weeks ago and i did not have it reprogrammed and os far i have no problems with the car.. So the dealer was right !
Check Engine Light-Codes-Dodge Caravan Se 2001 gogia Dodge Caravan/Grand Caravan Talk 5 09-29-2008 10:10 AM
2001 Dodge Grand Caravan Codes P0351-P0353 lyons4413 Dodge Caravan/Grand Caravan Talk 0 08-03-2008 01:06 PM
2001 Dodge caravan w/3.8L tranny codes p0700 & p0740 Caravan-N-Sand Dodge Caravan/Grand Caravan Talk 11 01-14-2008 11:52 AM
2001 Dodge Caravan Sport codes Baracuda Dodge Caravan/Grand Caravan Talk 4 03-31-2007 01:07 AM
2001 codes P 1684 - P 1698 xswinnyx 2G Dodge Intrepid - General Talk 1 05-16-2006 07:05 PM
