Whining noise while driving. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 19 Old 07-04-2009, 05:35 AM Thread Starter
Raydrin
I own a 2004 Dodge Ram 4.7 QC, the truck has a little over 50k miles on the engine. Anyways anytime I start to drive I hear this whining noise kinda like the power steering however if I park the truck and turn the wheel I don't hear it at all. I took it to the dealership once about it but they said they didn't find anything wrong with it and that is normal however I don't think it is since I drove other trucks like mine (I work as valet) and I don't hear that same noise. Any ideas? By the way the truck drives fine other than that noise.
Raydrin is offline
post #2 of 19 Old 07-04-2009, 06:38 AM
BMFRAM
BMFRAM's Avatar
maybe the belt ten , mine does it sounds like a super charger
2004 2500 4x4 hemi q/c patriot blue ( sold )
94 2500 12v cummins (sold)
01 2500 reg cab 4wd 6spd 24v
BMFRAM is offline
post #3 of 19 Old 07-04-2009, 08:58 AM
chard222
Pb Pes
chard222's Avatar
does it do under accelration, under decelrartion, cruising, certain gear, what are the conditions when you hear the noise?
08' 4X4 QC 5.7, U7137 (CMR Guerra Motorsports), 3rd Strike CAI, FRI Shrike Cam, FRI Street Heads Milled .030 (PAC Springs & 6.1 Rods), DynaTech LT (PolyDyn Gold Coating), DynaTech HiFlo Cats, Edge Billet 2800 Stall, Shift Kit, Motive 4.56s, Badlandz 3" ecut-out, FlowMaster 50 HD SiSo, Jet 180 Thermostat, Flex-a-Lite, Schaffer Moly Blend
chard222 is offline
post #4 of 19 Old 07-04-2009, 10:57 AM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 235 Post(s)
I'd check everything that's hook-up to the belt but the belt tensioner or the alternator would be your best bet with that type of noise.
dmcelhannon is offline
post #5 of 19 Old 07-04-2009, 11:04 AM
RussNash
Quoted: 1 Post(s)
I used to get this terrible whining sound whilst driving all the time, but since my divorce it stopped.
If it sounds like the power steering, you might want to try stopping the truck, turning to full lock on the wheel and creeping to see if the noise is there also.
Also, back when I worked at a dealership, I heard something similar from a 4x4 Ram and it was coming from the 4x4 transfer case.
Does the pitch change with speed or engine rpm?
Russ.
2006 Dodge Ram 1500 Quad Cab SLT 4x4
RussNash is offline
post #6 of 19 Old 07-04-2009, 04:29 PM Thread Starter
Raydrin
it happens the moment you put the truck in drive and start to go. Doesn't matter what gear your in. I never tried to hear it while I go in reverse but I can always hear it when I am in drive.
Raydrin is offline
post #7 of 19 Old 07-04-2009, 05:45 PM
dmcelhannon
Admin - David Mack
Quoted: 235 Post(s)
Put the truck on level ground and check the ATF in the transmission. Follow the instructions that are on the side of the transmission dip-stick. While you’re checking the level make note of the color and smell of the ATF. You said the truck has 50K; was the AFT changed at 30K?
post #8 of 19 Old 07-04-2009, 07:08 PM
chard222
Pb Pes
chard222's Avatar
X2....may need a fluid and filter change.....does it whine in nuetral?
chard222 is offline
post #9 of 19 Old 07-04-2009, 07:47 PM
Voodoo
Motörhead For Life!
Voodoo's Avatar
Quoted: 56 Post(s)
I thought you where going to talk about the wives
2012 Ram 1500 TRADESMAN REGULAR CAB 4X2 8' BOX ( TOTALED )
2014 Black Express
Edition 1500 Ram.
"You Can't fix Stupid"
Voodoo is offline
post #10 of 19 Old 07-04-2009, 08:47 PM
ladale
ladale's Avatar
Quoted: 1 Post(s)
sssshhhhhhhh dont let her hear you oh shit hi hunny
2002 RAM 1500 4.7L 4x1 quad cab ST
Prev. 2004.5 RAM 2500 325/600 5.9L
Prev. 2003 ram 1500 quad cab 1x4 slt 5.9l 360
BEWARE I POST FOR THE F@^& OF IT!
if ur not cum'in ur try'in too hard
100,000K+ club member #21
Quad Cab Club #666
Don't TOUCH my truck Club!!!! Member #36
DT MIssissippi Chapter Member # 1
ladale is offline
post #11 of 19 Old 07-04-2009, 08:52 PM
Voodoo
Motörhead For Life!
Voodoo's Avatar
Quoted: 56 Post(s)
OOOOPPPPSSSSS
2014 Black Express
Edition 1500 Ram.
Voodoo is offline
post #12 of 19 Old 07-04-2009, 08:59 PM
big guy
big guy's Avatar
Quoted: 12 Post(s)
Remove your serpentine belt. Then drive your truck. If the noise goes away. The problem is one of the accessories. If noise is still present. The transmission or engine/ driveline is causing the noise. Word of caution do not overheat the engine when doing this. You will have about 60 seconds of drive time with no belt. I had a whine noise at idle/low speeds. I thought for sure it was a power steering pump. Turned out to be the A/C compressor clutch bearing.
Good Luck.
2003 Ram 1500 SLT, 4.7,4x4 L.B. 4.10 motive gears, auburn LSD, PML rear diff cover, 3715 super chip, airaid M.I.T. & E.A.A. dry air filter, flexalite electric fan B.M. 180 extreme with moe's fan shroud delete kit, jet 180* stat, hemi radiator (spectra CU 2813). JBA shorty headers, homebrew power wire, aeroforce interceptor scan gauge, sonnex line pressure booster.
big guy is offline
post #13 of 19 Old 07-04-2009, 11:36 PM
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 229 Post(s)
I figured out what it was on my truck. The whining noise... my wife!!!
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #14 of 19 Old 07-05-2009, 01:42 AM
StreetHEMI03
StreetHEMI03's Avatar
Front wheel bearing or rear differential. Sounds like the rear diff gear or pinion making noise.
2003 Dodge Ram Hemi
Reg Cab Black
4X4 LSD 3.92
Terra Grapplers 305/55/20
Volant CAI with custom cold air scoop, power wire
SuperChips
Srt-10 Hood, Srt-10 A Pillar & Gauge, SRT-10 Floor Counsel
Custom Magnaflow Cat-back, Exhuast Cutout
Front and Rear IAS Shocks
and many more modifications
StreetHEMI03 is offline
post #15 of 19 Old 09-24-2009, 12:28 AM
1999Ram360
1999Ram360's Avatar
this really does suck
i have a 99 ram and mine is doing the whining too, the t case is getting hot and the noise is coming from the t case for sure, i jacked the truck up and ran it, had my ear up against the rear and it was fine, and its not the trans cuz the sound does not change with the gears... when i was looking it up on line it looks like something in those sun gears in the front are going, the reason im saying this is because most of the heat is coming from the front of the t case
1999Ram360 is offline
post #16 of 19 Old 09-28-2009, 01:03 AM
Dormaar
Dormaar
Dormaar's Avatar
I'm getting a whine as well but only when the engine is under load. Idle, coasting, and deaccelerating it is fine but as soon as I touch the throttle I can hear it and it seems to increase with speed and not rpm...?? From the drivers seat it sounds like it's coming form the front right side of the truck.
Dormaar is offline
post #17 of 19 Old 09-28-2009, 02:56 AM
zbgsaa
mine has been lately also but i think it is my u joints
Member #72 "The Red Truck Club"
zbgsaa is offline
post #18 of 19 Old 09-28-2009, 06:50 AM
BMFRAM
BMFRAM's Avatar
thought mine wine was the belt ten so i changed it , still have the wine think it might be the pully below the alt , does get louder when wife is in truck though
BMFRAM is offline
post #19 of 19 Old 10-18-2009, 08:12 AM
BMFRAM
BMFRAM's Avatar
ok finally found out what the noise was , the pulley bellow the ten pulley found out the hard way (belt shredded on the way home from work) pulley is not there any more if you are getting a loud supercharger sound at start up i would look at this pulley
BMFRAM is offline
    I too have a whining noise madmikeismad 2G Dodge RAM - 4X4 Talk 4 12-20-2008 11:55 PM
    Whining noise above 62 richmenefee Dodge Sprinter Forum 1 12-09-2008 03:39 AM
    Whining Noise... Loud_Dodge 2G Dodge RAM - General Talk 16 01-16-2007 03:55 PM
    Whining Noise DODGEIT 2G Dodge RAM - Drivetrain Talk 12 09-12-2006 10:13 PM
    Whining noise dieselracer 3G Dodge RAM - 4X4 Talk 3 12-04-2005 03:28 PM
