Loosing Coolant from top radiator hose - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 07-03-2009, 06:05 PM Thread Starter
Talamantez
ok i have a 2004 2.7 car has been great to me till a week ago. i was going through a drive through and the car started to heat up, it got so hot the ac started to blow hot air instead of cold. i checked under the hood and noticed i was really low on coolant. i also noticed all this gunk on my motor. i started to think maybe im loosing coolant from there. it looks like a hose from my radiator into the motor. is that where the thermostat is at? could a new thermostat stop the leak? here are some pics anyone have any advice please post
Talamantez is offline
post #2 of 5 Old 07-04-2009, 01:49 AM
Daytrepper
2.7 Trauma Surgeon
Daytrepper's Avatar
That is just a water outlet. Its pretty common for them to leak, you'll need a new one to fix it. They are available at the dodge dealer.
Dan C.
1998 Dodge Intrepid
1999 Dodge Ram 3500 CTD
Daytrepper is offline
post #3 of 5 Old 07-04-2009, 12:02 PM Thread Starter
Talamantez
is that the name of the part? also it is hard to change?
post #4 of 5 Old 07-07-2009, 01:15 AM
Daytrepper
2.7 Trauma Surgeon
Daytrepper's Avatar
Its the water outlet. About an hour to change it. The intake plenum has to be loosened up and raised about an inch to get to the back bolt, and you have to remove the radiator support shroud. Connected to that water outlet is a long metal pipe that runs under the intake and out the back of the throttle body. You disconnect the heater hose below the throttle body, raise the plenum, remove the upper radiator hose, unbolt the water outlet, and then slowly pull it out with the pipe that runs under the intake attached.
Dan C.
1998 Dodge Intrepid
post #5 of 5 Old 08-24-2009, 05:35 PM
popeye304
popeye304's Avatar
I Feel that I was Ripped Off
I just had this Coolant Outlet Connector (service manual's name) replaced, local mechanic charged me $187.00. The invoice called the part a Coolant Tube Kit.
My daughter's 2004 Intrepid SE 2.7L engine check light came on, so I had her stop by the local parts store to have the car's diagnostic codes read. They told her that the thermostat probably needed replacing.
I didn't expect the thermostat to be where it was so I crawled under the car, yes I had to jack it up, and saw a bunch of red Permatex all over the thermostat housing. Ok, I bought a new thermostat and gasket and I was going to replace it yesterday.
The service manual says I have to remove the engine mount, bolt for the alternator, and the dipstick tube. After staring at the housing for 45 minutes, and not being able to determine how to remove the dipstick tube, I decided I'll let my local mechanic take this on.
The Outlet Coolant Connector was also leaking, I could see some staining. The thermostat housing was warped, that would explain the red permatex all over the place. The intake manifold would have to be removed (gasket replaced). Total bill, $641.00
1. I think I need to find another mechanic.
2. I don't care how long it takes me to do a job, I'm doing it myself for now on.
Sorry for the rant and the hijack of the thread.
Lou Karnbach
A biker who had visited Florida for vacation wrote, "The vegetation is sharp, unfriendly, and almost screams at you to stay away."
I responded, "Welcome to Florida, now go home."
Follow me on Twitter popeye304
popeye304 is offline
    Top radiator hose exploded!! 2k1DurangoR/T 1G Dodge Durango General Talk 10 07-01-2007 06:42 AM
    Loosing Coolant? IdMegaMan 3G Dodge RAM - General Talk 16 03-14-2007 11:25 PM
    Blew my top radiator hose... CRMRAM 3G Dodge RAM - General Talk 45 08-27-2006 03:51 PM
