Dodge Talk Community Forum
Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Ram 2nd Gen (94 – 01) Forums > 2G Ram Diesel Talk
burton9010
  more transmission shifting problems - Posted: 07-01-2009, 04:31 PM
State: PA
Post #1
I have a 1999 dodge 2500 diesel. When I first got in last year it was having shifting problems going back and forth between 3rd and 4th. This fourm helped me out to find out the problem was a bad battery. I replaced both batteries last jul then. Now it is having similar problem shifting. It will still do the 3rd to 4th jump but now it just seems like the shift points are a little off every once in a while. sometimes it revs up higher then normal before it shifts and sometimes it shifts harder then normal into a gear and other times it is normal. But now it also does this thing that I will start it up and go to drive it and it will be stuck in first gear (I am guessing some kind of a safe mode). I shut it off and disconnect the battery for a min and it resets everything and then it starts shifting fine. Then sometimes when I shut it off and go to start it back up it will do the getting stuck in first gear thing again. It only ever does that when I first start it up never gets stuck in first once I start driving. I have not check the batteries yet but I am guessing they would still be good being there NAPA battereis and less then a year old. I was thinking trying to get new battery cables put on as mine are a bit rusted and such. Has anyone every had this problem before?
budnate
 Posted: 07-01-2009, 10:50 PM
budnate's Avatar
State: WA
Post #2
plug in and see if the computor has any codes thrown for a starter, sounds like it might possibly be the trans over voltage deal.
B.
-98,12V,quad cab
burton9010
 Posted: 07-02-2009, 09:30 AM
State: PA
Post #3
would it trip a light on if there was a code? Where is the overload sensor your talking about located at?
burton9010
 Posted: 07-04-2009, 12:28 PM
State: PA
Post #4
bump?
budnate
 Posted: 07-04-2009, 03:00 PM
budnate's Avatar
State: WA
Post #5
you need to go to pep boys or? and borrow there DBll.. plug into your truck and get ALL your codes right them down and report back, get help from the counter guy if you cant work it, no lights will trip.
-98,12V,quad cab
regans5
 Posted: 08-03-2009, 07:26 AM
regans5's Avatar
City: Independence, KY
State: KY
Post #6
I had problems on my 01 where it would shift back and forth between 3-4 at certain speeds and throttle positions and someone here pointed me towards a TSB for regrounding a wire near the engine. Have you ever heard of something like this. Not sure if it is the same problem but thought I would mention it.
2001 RAM 2500 4X4 CTD QC/LB AUTO
Silver Truck Club Member #57
Triple pillar Isspro pyro (pre-turbo),tranny temp,turbo boost,fuel pres on steering column,BHAF w/ outerwear & heat shield,Silencer ring MIA,Straight-pipe exhaust dumped in front of rear tire,Bulldog remote entry/start/security,Westin SS step bars,Extang full-tilt bed cover,Perma-Tech spray-in,Darin Steering Stabilizer Brace,16.5x9.75 Mickey Thompson Classic II rims, 33x12.5x16.5 BFG AT/KO tires,2" TGC Leveling Kit,Stampede "Ruff-Riderz" fender-flares,BD Aux Lift Pump.
2009 Volkswagen Jetta Sedan TDI
Wife's Ride
budnate
 Posted: 08-03-2009, 11:16 AM
budnate's Avatar
State: WA
Post #7
http://www.turbodieselregister.com/f...les-fixes.html
-98,12V,quad cab
regans5
 Posted: 08-03-2009, 12:31 PM
regans5's Avatar
State: KY
Post #8
That's very thorough and helpful budnate. However that is more complictaed than what I did. Someone on this board gave me the directions. I can try to find them if you need them burton9010 or hopefully someone else can post a link. All I did was locate a ground wire to the (I believe) TPS sensor. Cut the wire and splice on two new wires and run them to the battery negative.
Wife's Ride
budnate
 Posted: 08-03-2009, 02:52 PM
budnate's Avatar
State: WA
Post #9
you got away with the easy fix, print the trans info and save it and tab this link to your favorites, http://dodgeram.org/support_pgs/tech_index.htm
-98,12V,quad cab
Thundering6
 Posted: 08-03-2009, 11:47 PM
Thundering6's Avatar
City: York
Post #10
There is a TSB and a computer flash from Dodge to help this.I know alot of guys down here who have had this done over the years and it fixed the problem.You may want to check with Dodge on having this done before doing any home brewed wiring changes.
1998 Dodge Ram 2500 4x4 Quad Cab ...12v Cummins 5speed...MITCHELLized
Eagle Alloys Series 137...Pro-Comp Extreme M/T's 315/75R16...McGuard...Mag-Hytec...AFE Stage 2 w/Mega-Cannon Filter...HTT Pro-Street 66/71/13SS...ATS Exhaust Manifold...Banks Twin Ram...Flex-A-Lite #262 Fans...MBRP 5" Exhaust...5"-6" Angle Cut Roll Tip Stainless Tip...SkyJacker D25 Coils...Reflexxion Viper Cowl Hood....Bilstien 5100 Shocks...Pro-Comp Front Double Shock Mount...Corsa Intellidash...FASS 150/200-1010@45psi...Haisley Double Disc Clutch...EEP & Stewart-Warner Gauges...TST...Schaeffer Oil Lubricants...Ladder Bars By East Coast Diesel Performance...Overfueled and Injected By Ghost In The Machine Diesel Performance.....Fuel Only-608hp/1282Tq-Carlisle ATN's 8/8/09 & Nitrous-771hp/1200+Tq Fall Brawl 2009 10/17/09
Mason-Dixon TurboDiesel Club Event Co-Ordinator
Transmission down shifting zooterboy 3G RAM - General Talk 0 04-06-2008 08:50 AM
06 Transmission shifting mrservictime Hemi 5.7L, 6.1L Tech 0 02-24-2006 09:27 PM
Transmission shifting problems tomroos 2G RAM - Drivetrain Talk 2 08-01-2005 07:30 PM
transmission not shifting right canadarules 2G RAM - Drivetrain Talk 10 05-03-2005 11:47 AM
transmission shifting to soon hookbone 2G RAM - Drivetrain Talk 15 03-24-2005 04:14 PM
