Go Back   Dodge Talk Community Forum > Dodge Vehicle Forums > Caravan Talk
mattdalt
  excessive tire wear - Posted: 07-30-2002, 09:47 PM
City: Dubuque
State: IA
Post #1
I have a 1998 grand caravan. The tires outer edges on the front tires have nearly worn through on a set of 4 firestone ft70c ttires. These are 70,000 tires with a little less than 30,000. I had the front end aligned at a dealer 7,000 and they still have worn down to almost nothing. the head mechanic at the dealer suggested just buying the less expensive tires and living with the outer edge wear. Is this the best advice, or is there something else that could be causing the wear problem?
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
McClane
 Posted: 08-02-2002, 06:12 PM
McClane's Avatar
City: Calgary, Alberta
State: OTHER
Post #2
Excessive tire wear is not normal.
My first instinct would be to get the alignment looked at, but you've already done that.
Other things to look into would be the suspension, like shocks, bearings, ...
1995 Dakota 4x4 Club Cab
5.2L, 3:55 rear end, 46RH tranny
Mods : M1, NGK zfr6f11s, 180 t-stat, Bilstein shocks, Roadmaster Active Suspension, Mopar Valve Covers, Mopar 3 inch cat back, relocated IAT, FMS/Bosch Design 2 #21 injectors, TransGo Shift kit (tfod-hd2), 8mm Taylor Spiro Pro wires
angldrkns9
 Posted: 08-12-2002, 01:09 AM
Caravan driver =)
City: New York
State: OTHER
Post #3
i lowered my 2000 Grand Caravan Sport. I used Eibach Pro-Sping Kit, which only included the springs, and I left the stock shocks. i've been rotating my tires every 6000 miles and at 28000 miles i've now noticed my rear two tires are completely worn out. these were factory tires and there is no tread left on the rears and barely any left on the fronts. could there be something wrong? i know the alightment is right.
2000 Dodge Grand Caravan SE FWD
Mods: APC Exhaust, Altezza Euro Tail lights, 5% Tints Front, 5% Limo Tints Back, Eibach Pro-Kit Lowering Springs, Rear entertainment System, Bosch 4+ Plugs, Carbon Fiber Dash Kit, Blue Underbody Kit Lights, Custom K/N Cold Air Intake, Tornado Air Product, Focal Utopia 136 W, JL Audio XR-570, JL Audio VR-690, 2 JL Audio 12W6 V2 in Customer Sealed Enclosure, MTX Thunder 8100D Amp, MTX Thunder 6304 Amp, Alpine IVA-801, Alpine CHA-S634, Alpine DHA-S680, 5.6'' Headrest LCD Screens, APC Side Markers, Flowmaster 40 Series, Viper Alarm System 500 Series w/ Glass Breakage Sensor, StarTech DE Projection Headlights, Eagle Ultra-Grip Winter Tires, Silver Grill, Magnecor 8.5mm Spark Plug Wires, Hella Micro-De HID Fog Lights, 7000K Hella HID H7 Driving Lights.
Future Mods: Alpine Navigation System, 18' Tenzo Racing Rims & Performance Tires, Turn Signal Mirrors, Brembo Brake System, Hood Scoop, 56mm TB, Koni Shocks and struts.
McClane
 Posted: 08-12-2002, 01:37 PM
McClane's Avatar
State: OTHER
Post #4
I've only done some light reading regarding lowering vehicles. I am certain that if you lower a vehicle, you don't just cut the springs.
A lowering kit is required, and new "shorter" shocks may also be required. If I were you, I would take your vehicle into a good suspension shop, explain the whole situation to them, and they could probablly correct any possible errors.
angldrkns9
 Posted: 08-14-2002, 12:10 AM
Caravan driver =)
City: New York
State: OTHER
Post #5
yeah.. i didn't cut my springs... i acutally bought ebiach pro-spring kit for the caravan.. but i know, cutting the springs kindof messes thing up...
Vengance
 Posted: 08-22-2002, 08:49 AM
State: MO
Post #6
Did you install the rear shackles, too? If not, you might be putting too much weight on the front, and wearing those tires faster, or actually slightly "lifting" the rear (because of the weight distribution) and causing problems.
-Vengance
angldrkns9
 Posted: 08-22-2002, 06:20 PM
Caravan driver =)
City: New York
State: OTHER
Post #7
i installed the shackles too. it seems that the rear tires are wearing faster.. i think it's my cornering habits... =P
McClane
 Posted: 08-23-2002, 11:19 AM
McClane's Avatar
State: OTHER
Post #8
Say, what is the prognosis of your vehicle not starting ? Was the dealer able to locate the problem ?
carguy2
 Posted: 08-28-2002, 12:35 AM
City: Greenville
State: NC
Post #9
Do you drive the caravan like Mario? This is most likely your cause. i see it all the time at my shop. The van handles pretty well, so the take corners like in a sports car, and it'll wear the edges pretty quickly. If you like to drive aggressively, get a performance oriented tire, not the 70,000 mile granny tires. You also could have a little more negative camber put in the alignment. This will help with the problem.
angldrkns9
 Posted: 08-28-2002, 10:07 PM
Caravan driver =)
City: New York
State: OTHER
Post #10
that's why i'm getting ultra-high performance tires.. i'm looking into the SP9000 sport... talk about over-kill for my mini-van... haha
McClane
 Posted: 08-29-2002, 11:02 AM
McClane's Avatar
State: OTHER
Post #11
angldrkns9, sounds like your drive your Caravan like they do in Nascar !
tire wear MARLIN FAN 2G RAM - 4X4 Talk 3 06-12-2003 12:48 PM
goodyear tire swap! billyboy 3G RAM - General Talk 12 03-27-2003 09:40 AM
Spare Tire Lock 'key' stolen gcvt 2G RAM - General Talk 1 03-19-2003 09:23 AM
Bad tire wear Billy 2G RAM - 4X4 Talk 2 06-19-2002 11:32 PM
Quotes from experts on tire pressure HankL 2G RAM - General Talk 1 05-12-2002 05:02 PM
