Rough Idle and sucking noise - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 20 Old 06-12-2009, 10:37 PM Thread Starter
rich_kildow
rich_kildow's Avatar
'98 Ram 4x4 360 w/ 144xxx miles.
I recently replaced the plenum gasket with the improved mopar gasket and Hughes plate. She also got new plugs, wires, cap, rotor, and some other stuff.
This was happening before the work, but soon after starting, regardless of engine temp, the idle will drop to about 500 RPM's and become very rough. Within a few seconds of this starting, there will be a loud sucking/hissing noise coming from the throttle body. It is air being sucked in the port that is controlled by the IAC motor. This will happen if I let it set when first started, or if I hop right in and drive. If I'm driving, there will be a sudden loss of power. Either way, turning the engine off and immediately restarting makes the problem go away and I can drive for hours after that with no problem.
The IAC appears to be functional, meaning I turned the key with the IAC out and the plunger moves in and out. It is not throwing any codes, and there are no codes pending. What could this be? I'd rather not start throwing money at replacing sensors, but does anybody know what could be causing this? Since it goes away with a restart, my thinking is a sensor somewhere, but I'm not an expert.
1998 Dodge Ram 4x4 360...bone stock and it's gonna stay that way. Used to haul my 19' bass boat.
rich_kildow is offline
post #2 of 20 Old 06-12-2009, 10:38 PM Thread Starter
rich_kildow
Also, I know O2 sensors do not operate until the they hit 600 degrees. I don't know how long that takes, but this often occurs withing about 1 minute of starting the truck.
post #3 of 20 Old 06-13-2009, 02:23 AM
onthaflooron24
onthaflooron24's Avatar
wow..so im not the only one with this..lol
ill definatly watch this thread.mine sounds like a dam evil ass race truck with the exhaust i have on mine when it starts acting up.
did yours ever start the hissing noise then all of the sudden the noise goes away,theres absolutly no sound from the motor,but its still running?iv had that happen twice.i could dam near whisper to the person next to me the motor got so quiet.
onthaflooron24 is offline
post #4 of 20 Old 06-13-2009, 07:53 AM Thread Starter
rich_kildow
I have not had that. I've never let it go all that long because the motor will really start bogging down and shaking. I've been told it could be everything from MAP to O2 to IAC sensors. A friend is bringing over a high end scan tool, and we are going to pull all the refernce voltages and see what is acting up.
post #5 of 20 Old 06-13-2009, 11:38 AM
Ram1878
Ram1878's Avatar
Quoted: 46 Post(s)
Mine did that a couple of times about a year ago when first started up. It would eventually idle normally and drive fine. Just before my annual road trip I cleaned the TB and the IAC and since then it hasn't done it. I suppose that was the problem.
1999 Ram 1500 4x4 X-cab short box, 215,000+ miles
318 3:55 ASD
NV3500 w/ tow pkg
33" BFG T/A KO2
3" SKYJACKER LIFT w/ M95s
Thuren 0-3" track bar
Redhead Steering (2)
Magnaflow Hi-flow cat w/ Thrush GP
Hughes Plenum Kit
Stant 180 stat
K&N drop-in
Luverne Chrome Grille Guard
Westin Nerf bars
LMC Dash
Fog and backup lights w/ relays
Smoke Pacer Cab lights
Recon Big Rig lights
BLACK TRUCK CLUB #78
CAN'T LAY SCRATCH CLUB #3
TRUCKS & GUNS CLUB #29
*DodgeTalk.com 318 Enthusiast Member #( 68 )*
Ram1878 is offline
post #6 of 20 Old 06-13-2009, 05:11 PM
onthaflooron24
yea,i only did it once to see wat it would do.see if it would just die or keep goin..(not smart i know,but i get curious.lol)as long as i give it a lil bit of gas wen it starts doin it,it runs just fine..
but keep us informed on wat you find out with that scanner.
post #7 of 20 Old 06-13-2009, 10:26 PM
Mister 4x4
Too Big to Sneak
Mister 4x4's Avatar
This is the same problem I've been complaining about for over 3 years now with my '97 5.2L.
I don't have to turn-off and restart mine to push through the roughness... I simply let off the gas and get back on it (when it happens as I'm moving), and bump the throttle once when it happens as I'm idling.
The only thing I haven't changed out in attempt to solve this issue is the Throttle Position Sensor. I've cleaned the throttle body, replaced the IACV, both temp sensors, MAP sensor, cap, rotor, plugs, wires, coil, intake manifold gasket, cat, and both O2 sensors. It has thrown anything more than a 'misfire' code - and only on a couple of occasions (I have access to Snap-On and Genesis scanners).
Honestly, I think I remember the problem beginning after I replaced the O2 sensors. Since I'm pretty sure the sensors are different model numbers between the before- and after-cat units, I'm thinking maybe I might've reversed them. I also swapped in Bosch units... I wonder if that has anything to do with it.
Keep us posted.
Eric
"My lugnuts require more torque than import cars can make..."
Mister 4x4 is offline
post #8 of 20 Old 06-13-2009, 11:19 PM
MeanThree18
Yea boooyeee!
MeanThree18's Avatar
My old (99) Ram did this too me from time to time.
It kept on fryin out my IAC. Turns out it was giving it too much voltage.
Replaced the computer.
Never had the problem again (after 4 IACs)
'13 2500 Hemi 4x
MeanThree18 is offline
post #9 of 20 Old 06-14-2009, 03:32 AM
onthaflooron24
well.mine has actualy been doin it for years as well..but since i dont drive it much i havent fixed it.but it started doin it after i totaled my truck years ago.and im on my 2nd computer rite,the first one was screwin my tranny.i doubt the comp could be my issue.
post #10 of 20 Old 06-14-2009, 11:32 AM
MeanThree18
Yea boooyeee!
I don't recall what the spec was... But basically I just put a volt meter inline with the IAC to see what signal it was getting. I think it was supposed to peak at 5 (Don't quote me) and it was getting like 7.
'13 2500 Hemi 4x
post #11 of 20 Old 06-14-2009, 05:24 PM Thread Starter
rich_kildow
Hooked up my scanner to it, and when the noise started, the bank 1 O2 sensor was reading .08 volts, and the bank 2 O2 sensor was reading .9 volts. I'm pretty sure the acceptable range is .1-.9. If I tapped the gas when it was occuring, then the voltages would max out at 1.00v on both banks.
Does this sound like bad O2 sensors? The truck has 146xxx miles, and these are more than likely original.
post #12 of 20 Old 06-15-2009, 12:34 AM
DODGEPICKUP
DODGEPICKUP's Avatar
Quoted: 2 Post(s)
both my rams did this.....only on a cold start though.....in the morning after sitting over night.....start it up....45sec's later she run's rough TB starts sucking.......can pedal it threw this or shut her off as it starts running rough and restart and it runs great.......i do have an air/fuel ratio gauge and this issue starts as the gauge starts to swings to lean lower voltage .1v......if i shut it off and restart the gauge/02 takes much longer to become active another min or more........to me it seems that the pcm might be using the reading from the 02 to soon.....the o2 isnt hot enough 600c......need to scan to watch open/closed loop operation......does the pcm go in to closed loop using the 02's readings when the truck act's up?
1999 RAM 1500SPORT QC 4X4 5.9 3.55's grrrr
360 MAGNUM POWER 165,000 MILES DYNOED 230/290 ON 35'S
1.7 CRANE ROLLER ROCKERS
DIY CUT,PORTED,EPOXY FILLED KEGGER/ALUMINUM PLENUM PLATE,53MM THROTTLE BODY
JACOBS PRO STREET CD IGNITION
BOSCH DESIGN 3'S 24LBS VETTE INJECTORS
MOPAR P DOUG THORLEY TRI-Y'S
TAYLOR 8.2 THUNDERVOLT WIRE'S
EBC ROTORS N PADS,RUSSELL SS BRAKE HOSES
MARCH UNDERDRIVE CRANK PULLEY
1 TON X-OVER STEERING
DT PRO-FAB TRAC BAR
HELL BENT STEEL 2IN SPACER/SKJ LCA
WINNDEKAR/DSS STEERING BRACE
DODGEPICKUP is offline
post #13 of 20 Old 06-15-2009, 07:04 PM
onthaflooron24
i have a hanes book..i think it says wat the voltage is on them and how to check them..wenever i get time to mess with my truck again ima have to remember to check it..
and i mite end up changin my o2 sensors as well,since they are the originals with bout 98000 miles on them i think..lol
post #14 of 20 Old 06-15-2009, 09:55 PM
1998 Ram
Rammin
1998 Ram's Avatar
I have the same problem with my 98. It sounds like it has a wild race cam in it when it idles every now and then and a loss op power is noticed. So is the conclusion possibly just changing out the 02 sensors?
If you cant Dodge it, Ram it!!!I love my second gen and i wouldnt trade it for the world!!
My old kentucky home! Go wildcats
Proud Member Of The White Truck Club(#98)
The 360 will get up and go, flowmaster 40 series forever.
1998 Dodge Ram 1500 slt laramie.
Proformance remanufactured 360, bored .030 over
178,000
K&N drop in filter
Firestone Destination A/T(245/75/16)
Champion spark plugs with Bosch wires
Flowmaster 40 series dual exhausts with 3 1/2 inch tips, summit cutout
Debadged all the way including dodge stickers
Top windshield tint/ 38% tint on side windows(Max legal limit in Georgia)
Rhino-lining
EGR rain guards/vent shades
Optima Red Top Battery
Mobil One Synthetic Oil, Lucas injector Cleaner
Lucas Transmission Additives
New Mods:
New front red clip and sport grille and bumper
summit exhaust cut out
Better Built Chrome Toolbox
Trans dapt chrome differential cover
Bully chrome billet gas cap
Mr Gasket chrome push in breather
1998 Ram is offline
post #15 of 20 Old 06-15-2009, 10:01 PM
1998 Ram
Rammin
1998 Ram's Avatar
What is the best way to clean the throttle body? I have a brand new engine in my truck as well, and it had this sucking problem with the old motor as well. So im thinking about just changing the 02 sensors and cleaning the throttle body. I already replaced the throttle position sensor already.
178,000
K&N drop in filter
Rhino-lining
New Mods:
1998 Ram is offline
post #16 of 20 Old 06-17-2009, 12:18 AM
Ram1878
Ram1878's Avatar
Quoted: 46 Post(s)
Best way to clean the TB is to remove it and use Carb cleaner on it with an old toothbrush. Just be sure to replace the gasket when re-installing it. Also be careful with the IAC as the plunger cannot be moved or it's ruined.
318 3:55 ASD
NV3500 w/ tow pkg
33" BFG T/A KO2
Hughes Plenum Kit
Stant 180 stat
K&N drop-in
Westin Nerf bars
LMC Dash
Ram1878 is offline
post #17 of 20 Old 06-18-2009, 11:33 PM
DODGEPICKUP
Quoted: 2 Post(s)
here's a vid of my cold start issue.....at 1min 20 it starts running rough.....at 2min 40 i shut her off and restart......if i drive b4 the rough idle it run's great.....ive replaced both o2's , map , iac , iat , all with in 6month's.....each part replaced changed nothing....
DT PRO-FAB TRAC BAR
post #18 of 20 Old 06-19-2009, 02:25 PM
cmh2007
Beware the Underbite!!!
cmh2007's Avatar
mine does similar, and even the stealership cant figure it out...when mine does it it boggs off the line, and if i let off the throttle or just leave the foot down it takes off like a rocket.
2009 Ram 2500 CTD 4x4 SLT Lone Star, Patriot Blue. H&S XRT Pro 120hp tune with OD tuning. Full delete on the exhaust, waiting on the EGR.
Big Country Nerf Bars, Frontier Grill Guard
Blue Truck Club Member 251
*DodgeTalk.com 318 Enthusiast Member Number 3* (For the old truck)
4x4 Club #18
"I'm as sober as a field mice...mouces...mouce" - Anonymous
cmh2007 is offline
post #19 of 20 Old 06-20-2009, 01:23 PM
DODGEPICKUP
Quoted: 2 Post(s)
mine run's great if i dont let it warm up.....get in start it , do pre-flight check , n drive she run's great....cold start warm up and the idle goes to s**t tell i drive then it idle's great....what's puzzling is both my ram's had this....my 98 was brand new
DT PRO-FAB TRAC BAR
post #20 of 20 Old 06-25-2009, 08:00 AM
foxmulder
foxmulder's Avatar
Same problem here. If I start it after the engine's been sitting for a while and then let it idle for a minute it starts to idle rough BUT if I just get in and GO it runs perfect.
I've changed TPS, MAP, plugs, wires, cap, rotor and still same problem.
foxmulder is offline
    Sucking sound and HIGH idle AKDodgeMan 3G Dodge RAM - General Talk 5 03-20-2009 06:33 AM
    whstleing/ sucking noise normal? hotshotgoal30 3G Dodge Ram Performance Talk 16 06-18-2008 07:56 PM
    Help Needed: Durango Hesitation rough idle and loud air sucking sound random spudsdude 1G Dodge Durango General Talk 1 03-23-2006 08:45 PM
