Bolt size to take fan clutch off??????????? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 06-04-2009, 08:46 AM Thread Starter
ddgoose69
i just want to know the size bolts to put in the water pump pulley to keep it still while taking the fan clutch off? also what size nut is the fan clutch??? finally got my taurus efan in and wanting to install it next week, shroudless!!!!
04 Dodge QC
4-6 Drop
ddgoose69 is offline
post #2 of 10 Old 06-04-2009, 12:04 PM Thread Starter
ddgoose69
13 views and no bites????? i am sure somebody will chime in!!!!
04 Dodge QC
4-6 Drop
post #3 of 10 Old 06-04-2009, 12:39 PM
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 231 Post(s)
I am going to guess. But 10 or 12MM.
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #4 of 10 Old 06-04-2009, 01:22 PM
Rich 2500
Rich 2500's Avatar
If you're looking to take the clutch fan off, that's not the way to do it.
Elec. Blue 07 2500 Thunderoad QC Hemi 4X4
BTC #181
Mopar Cai, Mopar SS Nerf Bars, Mopar Tow Mirrors, Mopar Wheel Well Liners, EGR In Channel Window Vents, Tinted Windows 30%, Hella 500's behind the grill, Gibson Dual Sport Catback Exhaust, Magna Flow "Y" Pipe, Jet Stream Scoop, Power Wire, LineX Bedliner, Flexalite 180 Efan (shrouldless), Jet 180 Thermostat, Edge Evolution (used as monitor) DiabloSport Predator, Solid Steel Industries-Steering Stabilizer, Carli Starter Suspension System, Carli Adj. Track Bar, Toyo 35/12.50/17 MT on Stock Wheels, Carli Anti Sway Bar, Xeon Fogs 6000K
Rich 2500 is offline
post #5 of 10 Old 06-04-2009, 01:39 PM
06trxhemi
ASE approved
06trxhemi's Avatar
guess again its more like a 36MM or something.
honestly just use a 18in crescent wrench. and you will be fine.
Originally Posted by PCP View Post
if it doesn't put a smile on your face, youre in the wrong shop..
follow along with the CNC Plasma cut parts on a 41 Plymouth rat rod build
(i have the capability to do the cutting)
06trxhemi is offline
post #6 of 10 Old 06-04-2009, 02:04 PM Thread Starter
ddgoose69
how did you all keep the pulley from turning is what i meant???????
04 Dodge QC
4-6 Drop
post #7 of 10 Old 06-04-2009, 03:11 PM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 55 Post(s)
Best bet is to use a spanner on the pump pulley. Advance Auto Parts will usually rent you one. You can buy one for a bit more. It's a big honking nut alright. It's crescent wrench time.
'03 1500 QCSB Hemi
Vent shades/15% tint
A.R.E. Tonneau/Bed Rug
Nerf step bars
Rear LED light bar/LED frt. turn signals
LED tails & 3d brake light/White Night backup lamps & LED interior lights
Halos/projector headlights KC HiLites Titanium Driving lights
Tailgate Easy Lift & EZ Down
E&G Classics mesh grill
WeatherTech Floor Liners
Overhead console with HomeLink
JVC KD-AR780 Receiver & CH-X1500 Changer
Jensen 6x9 3-way up frt., 5 1/4" 2-way rear
GenTex auto-dimming mirror & Towing mirrors
Fender liners & Ram splash guards
Silver Truck Club Member #140
S.N.A.T.C.H. Club Member 666-666
2 1/2" level kit
Jetstream Scoop/Power Wire
MagnaFlow Stainless Cat-back SI/DO
TrueFlow intake kit
Hellwig 7651 sway bar
Flex-a-lite Black Magic Extr. 180 Elect. Fan
Dick Cepek Chrome DC-1s/Bridgestone Revo2 285/70
MikeHTally is offline
post #8 of 10 Old 06-04-2009, 03:45 PM
myoung84
Administrator
myoung84's Avatar
Quoted: 19 Post(s)
Phillps screw driver stuck in one of the pulley holes and wedged against the water pump.
Retro Shop Custom FXR Projectors | Diablo inTune | Vararam Intake | Moe's 87mm TB | BT Oil Catch Can
Toyo A/T II Tires | Bilstein 5100 Front Shocks @ 2.1" | Bilstein 5100 Rear Shocks | Movotech UCA's
Bora 1.25" Spacers | AirLift Air Bags | Bestop PowerBoards | Undercover LUX Bed Cover | BedRug
Magnaflow Exhaust | Volant Intake | Diablo inTune w/Hemifever Tuning | BT Oil Catch Can
myoung84 is offline
post #9 of 10 Old 06-04-2009, 03:52 PM
compressor man
compressor man's Avatar
Don't use a screwdriver you don't want bent, mine bent pretty bad. Wedge the screwdriver in then get a hold of the nut with the crecent wrench and hit it with your palm, constant pressure is what mess up my driver. The impact of wacking it with your hand should break it free better. Or you could do it the right way with a spanner wrench, but what fun would that be.
FRI'D 2007 Bright Silver QC 4X4 HEMI SLT SPORT. In the 13's
compressor man is offline
post #10 of 10 Old 06-04-2009, 05:35 PM
06trxhemi
ASE approved
06trxhemi's Avatar
why not just use a pices of bar stock with a bolt through it and make your own spanner wrench it will cost you $8 to buy everything needed to make a wrench. then you will have it to use over and over again. dont use a screwdriver!!!!!!!!!!!! you can break the gussets in the water pump housing if your not careful.
    Durango 01:clutch fan to electric fan mikeedodge 1G Dodge Durango - Drivetrain Talk 0 09-20-2008 09:06 PM
    questions to everyone who upgraded their clutch fan to electric fan low pressure 1G Dodge Durango General Talk 6 01-04-2008 09:18 AM
    Replacing 98D clutch fan with Hi-Flex SS Racing Fan? techie 1G Dodge Durango General Talk 0 03-19-2007 12:32 PM
    Fan Clutch, Electric Fan - broken? Help help help! ciredeelron 2G Dodge Dakota - Drivetrain Talk 5 04-17-2006 11:56 PM
