Need help with transfer case linkage repair - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 05-08-2009, 09:10 PM Thread Starter
15Ram00_02
Question Need help with transfer case linkage repair
Please help. I have completely lost my 4W shifter link-rod for my transfer case shifting, as in fell out and disappeared. I bought a new rod from Dodge, but I am having a problem mounting it. The mounting holes are rather large compared to the rod link points...like it requires bushings. What bushings do I use to secure the linkage to the shift lever and to the transfer case lever?? The dealer parts person told me they discontinued selling what was shown, and not very clearly, on the illustrated parts breakdown diagram. I am assuming these are some plastic bushing of some sort that, in my case, deteriorated to cause my linkage to come apart. Since I have never seen the setup, I do not know what I am looking for and hate to take it to the dealer and spend labor bucks for such a simple thing. I searched these forums but did not find anything on the subject. Am I the only one this has happened to, losing the whole linkage?? Please tell me what I need and where to get it. Thanks
15Ram00_02 is offline
post #2 of 8 Old 05-09-2009, 10:25 PM Thread Starter
15Ram00_02
**BUMP**
Nobody? Can someone take a quick look under there for me. Thx
post #3 of 8 Old 05-09-2009, 11:54 PM
ggravant
Serenity
ggravant's Avatar
Not sure if this helps, but here are all the parts relating to the transfer case shift lever from my 04 parts catalog. I checked and the 03 catalog looks the same. What year is your truck BTW?
Gary
2004 Dodge Ram 1500 4x4 4.7 RC/SB/5 Speed Manual
Red Truck Club Member #194
287 Enthusiasts Member #130
Magnaflow #12288 3"SI,2.5" DO, 2" drop shackels [slammed1],Overload springs removed,
Rear Wheelhouse liners [makeitmopar],Monroe Reflex Shocks [Advance Auto Parts],
Motive 4.56 Gears and Auburn LSD [AIR_RAM]
Gear Install [4 Wheel Parts Denver],Jet Stream Scoop [AIR_RAM]
Westin E-Series SS Nerf Bars [Amazon.com],Silver Radio Bezel [slammed1]
Billet Grill Powder Coated Black [DT classifieds & local powdercoater],MRK silver steering wheel accents
Wheelskins Leather Steering Wheel Cover [stylinconepts.com]
Ebay rear drilled/slotted rotors and Hawk HPS Pads [DT classifieds]
Painted Calipers [Rustoleum Sunrise Red],Hurst Performance Shifter [HUU-3910155 - Jegs]
Baer Front Slotted/Drilled Rotors and Powerstop Ceramic Pads [Moe's Performance]
EZ Down Tailgate Dampener [Moe's Performance],Visor DVD Player [eBay]
Tinted Windows (25% sides, 15% rear) [D&S Window Tint - Boulder, CO]
BFG T/A KOs 287/70/17 [craigslist],17" Eagle Alloy 187s [craigslist]
ebay AEM CAI Clone painted flame red,Catch Cans mounted to CAI heat shield [summit racing]
Flex-A-Lite Extreme 180 eFan [DT classifieds],SQC 70mm Throttle Body [DT classified]
**Soon To Come**
ALI Leather or Wet Okole Neoprene Seat Covers
ggravant is offline
post #4 of 8 Old 05-10-2009, 10:45 AM Thread Starter
15Ram00_02
The truck is an '02.
Thanks, but that is the diagram which does not show the clip or bushing that is required to secure the linkage to the shift levers.
I guess I really need someone to look under their truck and report what they find or a mechanic that is familiar with this.
Thanks
post #5 of 8 Old 05-10-2009, 11:32 AM
hemi1569
All Around Great Guy
hemi1569's Avatar
Hope this helps. This is from my 2004
Names' Kevin
9/26/09 htc rally, best run 4880lbs, full street trim minus tailgate
14.31 @ 93.52
6.1 cam and pushrods
Ramhammer intake
Doug's headers(mids) with factory cats
catback
My 6500rpm superchip shift 0 to 60mph video
Knock retard limitations by the pcm on a stock tune, it can pull:
15.0 degrees at low RPM's
5.0 degrees at 6000 RPM
9.0 degrees at 4800 RPM's.
hemi1569 is offline
post #6 of 8 Old 05-10-2009, 11:33 AM
ggravant
Serenity
ggravant's Avatar
Thanks
But if it is not listed in the parts catalog - how are you going to buy one if one were to exist?
Gary
**Soon To Come**
ggravant is offline
post #7 of 8 Old 05-10-2009, 03:28 PM Thread Starter
15Ram00_02
Thanks Hemi1569. Just as I thought, I need some kind of bushing. The fact that Dodge does not show this as a part in their catalog (attached in thread), leads me to believe that it might be somewhat of a common part?? Maybe this part is shown on the transfer case IPB diagram? The search continues. Hopefully, someone with some experience will see this thread. All help appreciated.
post #8 of 8 Old 07-01-2009, 10:58 PM
BR549
BR549's Avatar
I just had this problem occur to me. Going down the highway something started banging against the firewall or floor boards then stopped. As I was driving, I noticed my 4x4 shifter was laid all the way back in 4W High. After I got home, I found that the shifter glided easily forward / backward leading me to believe the linkage had come undone. I was lucky as the linkage was still connected to the shifter but not the transfer case. The loose linkage was hitting the drive shaft going to the front differencial which is what made the noise to begin with. On both ends of the linkage appears to be a rubber (not plastic) grommets. Mine are rotten, one almost completely gone. I removed the linkage until I can get the parts needed to repair it, for fear of loosing like you did. The grommet looks like a thick black "O" ring used for passing wires through sheetmetal. Looks like something we may be able to get from any hardware store, but the linkage looks like it was suppose to have a clip to hold the rod in the grommet. The diagram shown earlier did not show enough detail to know for sure. Please let me know if you learn more, hope this was of some help.
2000 Durango White SLT 4.7L 4X4 3.55 rear
Stock with Gray Leather
But fully Loaded
Tranny #2 at 64K
BR549 is offline
    transfer case help parks9 2G Dodge RAM - Drivetrain Talk 0 12-02-2008 05:07 PM
    Need transfer case help!!!!!! DODGEGIRL 1G Dodge Durango - Drivetrain Talk 5 03-21-2008 04:09 PM
    transfer case iviper123 1972-1987 Dodge Ram Trucks (D, W-series) 2 02-15-2008 09:40 AM
    Transfer Case Linkage cgex 2G Dodge RAM - Drivetrain Talk 1 12-02-2007 01:54 PM
    Transfer Case Rammin360 2G Dodge RAM - Drivetrain Talk 6 03-04-2005 09:12 AM
