adjust idle? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 05-04-2009, 10:26 PM Thread Starter
dviper_5
dviper_5's Avatar
adjust idle?
is there any possible way to lower the idle on my 1996 dodge ram 1500, has a 5.2L, and since i cammed it, it wont idle down, sits at about 1250 all the time, and i wanna hear the thumpedy thumpedy can anyone help me?
1996 Dodge Ram 1500 5.2L 2wd EC/SB
Flowmaster super 44 Dual 3" out. Set for some ground poundin
Indy Cylinder Heads
Comp Cams 262
Shorty headers
Msd Coil
Round air cleaner
SCT Tuned by KRC
Sleeeperr
dviper_5 is offline
post #2 of 9 Old 05-05-2009, 03:00 PM
trucklover
trucklover's Avatar
http://www.bionicdodge.com/Download/...a%20Magnum.pdf
2001 1500 Dodge Ram QC 4x4 360 Magnum
God Squad member #60
4.56 GEARS!!
SCT Tuner by Hemifever
EQ 2.02 heads
2200 PATC stall
cut & ported intake & 52mm TB
stainless steel headers
KRC 210X cam
Powertrax No-Slip Locker
Rough Country Shocks
Rough Country Steering Stabilizer
Flowmaster Catback dual exhaust system
Hughes Engines Plenum Kit
M1 2bbl Intake
Moroso 14" Low Profile Chrome Airhat
add-a-leaf in the rear
2" Leveling Kit from Top Gun Customz
Rebuilt engine!!
trucklover is offline
post #3 of 9 Old 05-06-2009, 12:51 AM Thread Starter
dviper_5
dviper_5's Avatar
my comp wont let me open it up, just comes up in garble crap
Indy Cylinder Heads
Comp Cams 262
Shorty headers
Msd Coil
Round air cleaner
SCT Tuned by KRC
Sleeeperr
dviper_5 is offline
post #4 of 9 Old 05-06-2009, 01:02 AM
pepsi71ocean
Much too young to focus,
im assuming it is a carburated engine, if so just re adjust the the set screw in the carb.
oh and that a pdf file, you need adobe reader to open it. if your browser doesn't have the pdf extension for it.
99 3500 Auto 3.55 4x4, BHAF, 6" lift, Danin Optix, Gauges, DAP 60hp sticks, FASS 95 2spd Rear disconnect HIGH Idle BOMB Silencer ring delete 4" exhaust, SMARTY 08 3500 Auto 4.10, PTO Idle Big Thanks to Walt(FTE Diesel) JKidd(DAP)
They ROCK!
pepsi71ocean is offline
post #5 of 9 Old 05-06-2009, 01:06 AM Thread Starter
dviper_5
dviper_5's Avatar
nope, its a 5.2 magnum fuelie, somedays i wish it was carb'd...things were so simple in those days
Indy Cylinder Heads
Comp Cams 262
Shorty headers
Msd Coil
Round air cleaner
SCT Tuned by KRC
Sleeeperr
dviper_5 is offline
post #6 of 9 Old 05-06-2009, 07:16 AM
hounddogg
hounddogg's Avatar
There is a hidden set screw.It has to be drilled to get to the screw.Then you uplug IAC,set taget idle and plug IAC back up.( I believe) try contacting www.thefastman.com unless someone has a wy to describe/post a picture of where the screw is etc.
hounddogg is offline
post #7 of 9 Old 05-06-2009, 07:47 AM
trucklover
trucklover's Avatar
The pdf file I posted has pictures. If anyone can't open it go to http://get.adobe.com/reader/?promoid=BUIGO and download the reader.
4.56 GEARS!!
EQ 2.02 heads
2200 PATC stall
KRC 210X cam
M1 2bbl Intake
Rebuilt engine!!
post #8 of 9 Old 05-06-2009, 08:38 AM
OleTomCat
Bridal Veil Falls
OleTomCat's Avatar
Quoted: 1 Post(s)
I coppied the text and posted below, I couldn't copy the pics.....
Good luck and welcome to DT....
The idle is set in the PCM by a idle target parameter. Installing a newer throttle body or cam cam change what the PCM needs to see to stop surging or erratic idles.
The picture above is a stock plug in a stock throttle body, to adjust the throttle plates angle, this plug needs to be removed. On the Flometrics throttle bodies (right), all you need is a Allen wrench to adjust. Note: some of the Flometric TB's have double set screws in the throttle shaft adjustment.
To set the throttle plates correctly, the vehicle needs to be warmed up for at least 5 minutes to ensure it is in closed loop. Once done, the IAC port (shown below, left) needs to be blocked off with your thumb, then turn the adjustment screw clockwise to open the plates, counterclockwise to close them, until the rpm sits at 800 rpm steady. Remove your thumb from the IAC port and the idle will climb up and then return back down to norm. You have just set your IAC count to 30-60 counts. This is a good number for the IAC to sit at without having to swing wide to recover from extreme idle conditions such as braking or WOT.
If you have a scanner, adjust the IAC count at idle to be between 40-60 counts. You can also install a false IAC sensor in the plug to fool the PCM into believing there is a idle control when you are setting the idle by the throttle plates directly, the false sensor will operate while the original IAC motor sits idle in the throttle body. This eliminates the long decel times after rev'ing the throttle.
This is a picture of a Flometrics 58mm throttle body IAC being plugged for throttle adjust while idling around 750-800 rpm.
My name is Al from Summerville, SC and I am a
Me: '14 Ram 1500 EcoDiesel
'01 Ram 1500 5.2L Sport
Rhino Liner, Pioneer sound, new ball joints
I am not just a member I am the President
Wife: '05 Durango 4.7L
OleTomCat is offline
post #9 of 9 Old 05-06-2009, 10:48 AM
ozplanet
Just Call Me Oz
ozplanet's Avatar
What cam did you go with ?
94 SLT 1500
Flat Black 2wd
Mods: M1 / Comp Cams / 4.10 / 20" 3rd Gen Rims / 4/6 Drop / Flow Master 40's / All New Skins /
2010 Sport Crew Cab Black 4x4 5.7 3.92 Sport hood 10 Speaker Alpine w/nav
Mods: Diablo 91 Canned Tune / Billet Tech Oil Catch Can / Vararam Intake / Magnaflow Muffler / All Interior|Exterior Bulbs LED White / Recon Smoked 3rd Brake Light / Recon LED Light Bar / Orange Striping / Lockpick / Debaged|Murdered / 2 12" Foxbox / 2 Alpine SWR-12D4 Subs / NVX JAD1200.1 1200w amp / Flat Black VIP Wheels VP2 / Black & Orange Leather / Orange Interior Accents with Gloss Black /
Soon: Race Rotors / EBC Yellow Stuff /
ozplanet is offline
    2001 1500 QC 5.9 4x4 Will Not Idle, Engine Stalls During Deceleration To Idle Also? MadMacs 2G Dodge RAM - General Talk 1 01-20-2008 12:22 PM
    adjust or not? maximus1000 2G Dodge RAM - Drivetrain Talk 7 11-16-2007 11:41 AM
    How do you adjust the clock? Macster33 3G Dodge RAM - General Talk 7 01-07-2007 02:50 AM
    How to adjust headlights on an 06 kmu 3G Dodge RAM - Interior/Exterior Talk 5 08-14-2006 02:52 PM
