Bad motor mount=Vibration - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 05-01-2009, 10:52 AM Thread Starter
Eggman
God,I'm gettin old!
Eggman's Avatar
Quoted: 2 Post(s)
Picked up a vibration in my 87.While tinkering on the engine I took 5 steps,turned back and low and behold the motor was leaning to the passenger side.Upon further inspection I found that I have a broken motor mount.Does anyone make "better" mounts like say,Energy Suspension for our trucks? edit I did a search after I posted and found poly mounts sorry
Eggman is offline
post #2 of 10 Old 05-01-2009, 11:26 AM
Speed Dragon
Aka Force Fed Mopar
Speed Dragon's Avatar
Trans mount can cause vibration too.
Also, installing poly mounts may cause more vibration also, as they do not insulate/dampen as well as rubber. They are performance items.
Rob M.
'93 D150 RC SWB, 5.2 Magnum, NV4500 5-spd, 9.25" diff
'72 D100 RC LWB, PT project
Speed Dragon is offline
post #3 of 10 Old 05-01-2009, 02:27 PM
brandenberger
how hard is the tranny mount to install i just replaced me engine mounts(more like install since there were none when i bought the truck. i already have the tranny mount just no clue where it is or how to put it in.
1978 Dodge D-150 Adventurer F.U.B.A.R.ed interior and wiring
brandenberger is offline
post #4 of 10 Old 05-01-2009, 02:48 PM
Speed Dragon
Aka Force Fed Mopar
It's easy, it goes at the end of the trans, 3 or 5 bolts, can't remember. Take the weight off the trans w/ a jack (use a piece of board under the pan if it's an auto), take the big through bolt out, jack it up as far as you can, remove the bolts holding it to the trans. Replace in reverse order.
Rob M.
post #5 of 10 Old 08-13-2009, 03:34 PM
sam03v
I have a 1980 d150 with a slant 6. One of the motor mounts looks bad. Anyone out there ever replaced these and willing to offer some advice?
Thanks in advance.
S
sam03v is offline
post #6 of 10 Old 08-13-2009, 11:10 PM
dolfans
Quoted: 1 Post(s)
i had both motor mounts and transmission mount replaced in March.i checked around before i bought mine.the motor mounts were about $10.00 each(advance,autozone etc).i got them at rock auto for $3.00 each and with shipping it still was cheaper.i cant remember the price of the trans mount
dolfans is offline
post #7 of 10 Old 08-13-2009, 11:32 PM
sam03v
Thanks for the reply.I was wondering how hard the actual job was. I called a local shop, and they quoted about 200 bucks. I assumed I'd have lift the engine , so I'd have to build an A-frame lift of some sort(out of wood in my case) Just trying to deciide if its worth doing it myself or not.
sam03v is offline
post #8 of 10 Old 08-14-2009, 01:00 AM
thejudges69
Eggman i'm a dealer for energy suspension and i know that we have GM mounts and universal mounts. nothing that is directly sooted for out trucks check out www.energysuspension.com to see what we offer.
NOW THIS IS A TRUCK
thejudges69 is offline
post #9 of 10 Old 08-14-2009, 12:26 PM
dolfans
Quoted: 1 Post(s)
when i had the stuff done to my truck it was $160.00 labor.i had motor mounts 2,trans mount,drag link,front brakes,rotors turned,brake caliper 1,pipe from muffler back,wheel bearings
dolfans is offline
post #10 of 10 Old 08-14-2009, 07:36 PM
MoparSteve
MoparSteve's Avatar
You don't need a lift, just jack up the engine a little and unbolt the engine mounts. It is a very simple job. And $200 is a rip off specially since the mount only cost $4.50 each at NAPA.
77 D150 340/stepside/2wd
MoparSteve is offline
    Another Motor Mount Problem cloner1979 Dodge Neon - Performance Talk 1 10-28-2007 10:52 AM
    Picture of LH motor mount? m37boblee 3G Dodge RAM - 4X4 Talk 1 04-13-2007 06:37 PM
    motor mount removal joatmon 2G Dodge Stratus - General Talk 1 08-30-2006 11:27 AM
    99 Stratus 2.4 Engine Mount Vibration jadleman Dodge Stratus 1st Gen (95 - 00) 0 07-20-2006 07:44 AM
    Motor mount jirik Dodge Caravan General Talk 1 12-01-2004 11:04 AM
