Go Back   Dodge Talk Community Forum > Dodge Vehicle Forums > Neon Talk > Neon - General Talk
DodgeFreak
  Need an idea... - Posted: 07-25-2002, 10:36 AM
DodgeFreak's Avatar
City: Clinton Twp
State: MI
Post #1
Hi all,
My GF has a 99' Plymouth Neon Espresso with the 2.0 DOHC engine. She wants to pep it up a little (she hats the fact that my Ram is faster). I know the stock AIT was designed like crap so I was thinking about getting her a new one. Any one have any ideas as to who makes decent CAI for this application? Any other ideas for performance parts would be appreciated. Thanks.
James
2000 Jeep XJ 4x4
30x9.5s on 15 inch Eagle Alloys with 4.5 BS
*RIP*
96' Ram Sport 1500 RC/SB 5.9L
Mopar Performance PCM
Fastman 52mm TB
Edelbrock Headers
B&M TransPack shift kit
and so much more
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
scalski
 Posted: 07-25-2002, 11:31 AM
State: NC
Post #2
I know a lot of good ones for SOHC Neons, but I'm not sure about DOHC, you might want to asks this question at www.neons.org
They might know!
Later,
Scott
Just wanted to make it seem like something was here!
mkitgo2
 Posted: 07-25-2002, 04:09 PM
City: Burlington, Ontario
State: OTHER
Post #3
If your talking about making a custom unit.. you can do it for less than $100.
If you use an intake snorkel from a chrysler 3.0L V6, it is shaped in a U. This Tube will fit onto her stock throttle body, for the DOHC (which has two rad fans) you need to cut the tube at the top of the arc, and insert an extension... a piece of pvc pipe or exhaust tubing.. needs to have a 2.5" Diameter, and use hose clamps to hold it together.
Then this will allow it to go from the Throttle body, down infront of the battery. You will need to trim the excess from the front of the battery tray, and remove the dust/cooling cover.. don't cut the temperature sensor or battery hold down though.
Then using another short piece of the 2.5" piping attach a Cone Air Filter (K&N or the likes of) and Voila.
It's not as complicated as it sounds.. if you go take a look undet the hood and think.. it will all come together.
Picture of it installed
[IMG]http://photo.msn.s8.com/MS8zLzAvMS8xMDMwLzE1NS8zMi9mS3gyMC1sajFlQzktdGE4eF FEVnd3/e9c5c202ca0279473a1ebdb4bfac1bec/clbk=HcZNnT9kkUhC9PSey3bx2p4XRLW0MYGx4ODwbj5to*kIj kJ18gsP!LetgGlrwo!6r5baU6*YmdU$/jpg.jpg[/IMG]
The V6 tube before its cut.
I have an extra one of these tubes if your intersted, or if you have any questions drop me an email.. I would be happy to explain more. nitfird@hotmail.com
Another one that can get some good improvements, if she has a 5spd... get the Throttle body from an automatic.. Manual TB's are 49mm wide, but Autos are 52mm.. you can direct swap them for the most part. the only complication can be cruise control, if one has it and the other doesn't, but that can be over come.
Good Luck,
MK iT GO
DodgeFreak
 Posted: 07-26-2002, 10:07 AM
DodgeFreak's Avatar
City: Clinton Twp
State: MI
Post #4
Wow thanks mkitgo2. I will have to give it a look see.
James
2000 Jeep XJ 4x4
*RIP*
Fastman 52mm TB
Edelbrock Headers
and so much more
poorboys
 Posted: 07-26-2002, 04:21 PM
City: San Antonio
Post #5
we have a chrome header for the dohc in stock $249.99
we also custom build air intakes , if interested we could whip you up something in polished aluminum or steel (powder coated)
other than that , i have a set of ignition wires and msd is coming out with a coil for that .
mike @ poorboys performance
POORBOYS PERFORMANCE
1-877-POORBOYS
mkitgo2
  what?? - Posted: 07-29-2002, 01:41 PM
State: OTHER
Post #6
Hey Poorboy... On a Stock Engine.. what good are MSD wires or coil pack going to do????? I am talking bang for your buck here!
Really on most stock engines.. the most dramatic mods are usually exhaust, intake, computer chip and suspension... even port and polishing would be ahead of plug wires and ignition...
in my experience you don't need to beef up ignition systems and spark control until your into changing things like cams, udp, adjustable cam gears, turbo, NOS or other major modifications which require adjustment and tuning of the management systems...
MK iT GO
poorboys
 Posted: 07-29-2002, 02:53 PM
City: San Antonio
Post #7
actually you'd be suprised , the wires and coil make somewhat of a difference . of course its not going to be dramatic but noticable.
1-877-POORBOYS
mkitgo2
 Posted: 07-29-2002, 04:15 PM
State: OTHER
Post #8
I'd be very suprised!
Hmmmm...?
I think this is arguable... I would Love to see dyno numbers on this.. but no one throws new wires in and then goes to see if their HP at the wheels jumped.. cause it doesn't!
All the mods listed above, and the one that James asked about in the first place WILL give a NOTICABLE difference... So why not put your money to better use?
poorboys
 Posted: 07-29-2002, 05:01 PM
City: San Antonio
Post #9
power may not be reflected through dyno numbers ....... but over all throttle responce and mid range power should increase. usually the vehicle manufactors use the cheapest items they can when building a car or truck , ignition parts included. i am not saying that bang for buck is that great but when looking for a little extra power and with few items that are affordable for the neon (under $100.00 or so ) this is just one of the few small upgrades that can be made ....... no nothing spectacular but affordable and some what practical especially when doing a tune up anyway . just my 2cents
1-877-POORBOYS
carguy2
 Posted: 08-28-2002, 12:28 AM
City: Greenville
State: NC
Post #10
i'm with poorboy on this one. The plugs, bigger wires, and a hotter coil pack will give about 5-10 hp increase. If you aren't burnig all the fuel, maximum horsepower will not be acheived. What good is more air, if you can't use it properly?
TripleXJ
 Posted: 09-26-2002, 02:15 AM
TripleXJ's Avatar
City: Salina
State: KS
Post #11
[)oclgeFre4k
anoughter thing that can be done is lower the car just a lil and maybe look into a body kit from Wings West, will make the car more Aerodynamic and better looking, also a good aftermarket exhaust will hep out in the power range. NOPI and APC and Pacesetter all make a nice kit, and a APC cold air intake works wonders
Your Source for Cherokee's and Grand Cherokee's!!!! www.CherokeeTalk.com Check us out!!!!
My Rig
1996 Cherokee Sport,
4.7 I6 with Airaid TB Spacer and K&N Filter (both New)
AW4, NP231,
3" BDS coils wit 3/4" Spacers, Pro Comp 3.5" leaf packs,
Rusty's Adj LCA's,
R.E. Swaybar Disconnects,
Click HERE to view the complete signature...
SUV of the Month Award!:  - Issue reason: Feb 08 SUV of the Month Winner!
cold airbox/intake idea for my 'kota racerX_244 2G Dakota Performance Talk 5 11-12-2003 12:31 AM
Contest Idea! moparbob Concept/Modified Vehicle Talk 20 10-10-2003 06:28 PM
"borrowed" ramrod's console idea. SS/Teve 3G RAM - General Talk 6 09-03-2003 11:15 PM
