Engine code PO 456 ? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 04-27-2009, 09:54 AM Thread Starter
Cain
Cain's Avatar
Hey All,
A while back the engine light came on in my wifes 03 Ram, she took it to advanced auto, they hooked up their little diagnostic computer and it gave this code PO 456. They told her it was a gas cap issue, it might not be on all the way, sooo, she tightened the cap up and the light went out....woo hoo
HOWEVER, now its back on !! So this time I took it over to Advanced Auto and it spit back the same code. So I took off my gas cap from my 03 Ram and switched it out with hers, my thinking for this was, since im not haveing issues with my gas cap and were the same make, modle, and year no harm no foul. Well, the pretty little check engine light IS STILL ON
So, heres my question. Has anyone else had this issue? If so, what was your remedy to fix?
Also, was I mis-informed at Advanced Auto? Is the PO 456 code something other than a gas cap issue?
Any and ALL help is appreciated.
Cain is offline
post #2 of 10 Old 04-27-2009, 10:02 AM
SchroederMP
living life
SchroederMP's Avatar
My threw the same code. I'm not a mechanic by all mean but it had to do something with a purge sylidoid for emissions and a couple other things. They should have printed you out a ticket with all of the things the code could have ment. Then take that ticket to the dealer and they will run a better diagnostic on it.
2005 CTD 4x4-5" Turbo back exhaust, Icebox CAI, Smarty, AirDog, built tranny, leveled, Linex Rockers
1993 Dodge Stealth 3.0L 5sp-Project/Gas Saver
SchroederMP is offline
post #3 of 10 Old 04-27-2009, 10:04 AM
Palmentech766
^GM Goodwrench Certified^
Palmentech766's Avatar
p0456 is a small evap leak, most commonly caused by a faulty gas cap. Other things can cause it are most likely a crack in an evap system rubber hose.
2013 Ram 1500 Outdoorsman Mineral Gray
1978 AMC Matador Wagon Morocco Buff
1967 AMC Ambassador Convertible Matador Red
Palmentech766 is offline
post #4 of 10 Old 04-27-2009, 10:26 AM
SchroederMP
living life
post #5 of 10 Old 04-27-2009, 11:21 AM Thread Starter
Cain
Cain's Avatar
If it is the rubber hose, is it an easy fix? And if so, where abouts is it located?
Cain is offline
post #6 of 10 Old 04-27-2009, 11:35 AM
mississaugaram
Are we going down?
mississaugaram's Avatar
I had the same code last week, P0456. I crawled under the truck and checked my evap. hoses and found one had a small crack. You can find them on the drivers side just under the doors, there is a black box with a couple of hose's there. The hose I needed was part # 5210279aa. It cost me 10 bucks to fix. I will try to post a diagram I got off this site. Bye the way the code has not reappeared. Hope this helps.
2003 Dodge Ram Quadcab Sport 4X4
Silver
Hemi
3.92 gears,running boards,SRT-10 hood, rollup tonneau cover,cup holder light, carpeted fold flat floor,ebay CAI
Silver Truck Club Member # 134
mississaugaram is offline
post #7 of 10 Old 04-27-2009, 11:44 AM Thread Starter
Cain
Cain's Avatar
Great Diagram, very helpful. I will look at that this weekend to see if I can detect any cracks.
Thank you
Cain is offline
post #8 of 10 Old 05-16-2009, 04:08 PM
Rev jd
I have this same code and the same 2 hoses show little cracks right at the fittings. Do I have to use the factory replacement hoses, or can I get hose from my parts house and bend them (maybe a little wider bend) to fit? Is there anything that would cause the hoses to collapse, etc., or otherwise foul things up if I did this?
2003 Ram QC 2WD
-Mighty 4.7 V8
-Volant Intake
-Fastman TB
-Flowmaster Exhaust
-Superchip
-4.56 Yukons (installed soon!)
-20' ECO rims
Rev jd is offline
post #9 of 10 Old 05-16-2009, 04:31 PM
rye
rye's Avatar
If you can't find a leak, you can take it to a garage for a smoke test. Shouldn't be more than $40 for that. Just get them to tell you where the leak is and fix it yourself.
DODGETALK.COM MODERATOR
5.9 2003 1500 4x4
Official Dodgetalk Facebook Page:
rye is offline
post #10 of 10 Old 05-16-2009, 04:40 PM
Rev jd
Oh, I can see the cracks in the hoses, so I'm sure that's where the leak is. I went ahead and called my trusty dealership to buy the hoses. They have one in stock and ordered the other for me. I was just trying to be a cheap-o, as usual!
2003 Ram QC 2WD
-Mighty 4.7 V8
-Volant Intake
-Fastman TB
-Flowmaster Exhaust
-Superchip
-20' ECO rims
Rev jd is offline
    456 install luvcycles2 3G Dodge RAM - General Talk 1 02-01-2009 03:03 PM
    diagnostic code 456 donnie_roe 1G Dodge Durango General Talk 1 07-02-2007 09:22 PM
    Check Engine code 2002 3.3 engine login Dodge Caravan General Talk 5 04-19-2006 10:49 AM
