Stereo Color Codes for 99 Durango - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 04-13-2009, 12:56 PM Thread Starter
MAXIMILLION
I need The CORRECT COLOR CODES for my 1999 Dodge Durango, i dont think i have any infinity speakers, so im not having problems producing sound, its when ever i switch on my headlights my pioneer stereo turns off and i have no idea where to connect my remote control starter for my kicker amp, i know for sure ive hooked it up but im still having a situation with the headlights turnin on, any ones 2 cents will be helpful i just got my dodge 4 days ago and im just tryin to trick this baby out
MAXIMILLION is offline
post #2 of 6 Old 04-13-2009, 09:28 PM
dkeys412
dkeys412's Avatar
ok, that sounds like a electrical problem somewhere due to the fact that the headlight switch should have nothing to do with your radio. ( But I could be wrong) As for the turn on (not remote control starter) it should be the blue wire coming from the wiring harness off the back of your pioneer deck. That part I do know, as for the headlight thing maybe someone else has had the problem and help you out
dkeys412 is offline
post #3 of 6 Old 04-14-2009, 08:09 PM
B1G BLEU
WORLD'S GREATEST TRUCK
B1G BLEU's Avatar
I'm guessing you didn't ground the radio so it's getting it from the illumination wire which becomes + once you turn on the headlights (when they're off the radio is drawing current through the bulbs to ground).
Paul
02 Durango (build 11/01) SLT┼ AB/BLACK INT 4.7L NGC 45RFE PT3.55 LSD 4X4 - Superchips 3715 Performance - Sensatracs - Chrome Nose - Carriage Works Billet Grilles - APC Clear Corners - Infinity 6022i's w/stock tweeters - - Hidden Hitch - Silverstar 9007ST's - K&N high-flow 33-2175 air filter- TFP Chrome Handles - 33K Miles - (MB Gunner Chrome Wheels + General Grabbers wintering in basement) Hammered blue factory rims
Wife's Ride : 2006 Grand Caravan SXT INFERNO RED
Work Ride : 2009 Ford Edge SEL
Daughter's Ride : 2011 Jeep Compass Latitude
Son 1's Ride : 2012 Nissan Altima S Coupe
Son 2's Ride : 2006 STi Stage 2 Grandma Gray (kinda mine, too
B1G BLEU is offline
post #4 of 6 Old 04-15-2009, 11:31 PM
zzzzzzz
what amps run you running ?
here are the wires for the speakers
Constant 12V+ Red/Blue
Switched 12V+ Red/White
Ground n/a
Illumination Black/Yellow
Dimmer Orange
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Brown/Yellow
Right Front (-) Brown/Light Blue
Rear Speakers 6 1/2" Rear Door
Left Rear (+) White
Left Rear (-) Dark Blue/Red
Right Rear (+) Brown/White
Right Rear (-) Brown/Orange
zzzzzzz is offline
post #5 of 6 Old 04-15-2009, 11:31 PM
zzzzzzz
test your alt and see what it is at
zzzzzzz is offline
post #6 of 6 Old 04-15-2009, 11:55 PM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
the remote turn on for your amp gets hooked to the wire labeled remote on your headunit. its a blue/white wire. check to make sure you didnt cross a wire somewhere. your dimmer wire is designed to dim the lights on your factory stereo. aftermarket stereos don't usually have that option, so if you hooked a wire to it, odds are its "dimming" your power, thus turning off.
New: 2005 Dodge Ram 1500 QCSB 4x4 Hemi Laramie Bright Silver
Flowmaster SI/DO 40 Series. Superchips 3865 - 91 Tune, 2/4 drop, More to come............
::GONE BUT NOT FORGOTTEN::2005 Dodge Ram 1500 QCSB 4x4 Hemi Sport Black
5.5" Rough Country Lift, Dick Cepek DC2 20x9, 325/60R20 Nitto Terra Grappler's, Superchips 3865 - 91 Tune, Extang Tonneau Cover, K&N Cold Air Intake, Bosch Platinum 4 plugs, Magnaflow Y-Pipe, SI/DO Flowmaster Original 40 Series, Synthetic Everything, 7000K Headlights, Foglights and Hellas..
1998 Dodge Durango SLT 4x4 Black
Hypertech 87 Tune, K&N Cold Air Intake, Bosch Platinum 4 plugs, Bosch 8.5mm Wires. Ported Throttle Body, SI/DO Flowmaster Original 40 Series Muffler, Headman Headers, 3" PA BL, 2" T/S Lift, 33x12.50R15 Firestone Destination M/T's, 15x8 Eagle Alloy Wheels.
BTC Member 211 - Steel Reserve
!05RAM05! is offline
    O2 sensor wire color codes? nogodurango 1G Dodge Durango General Talk 2 09-23-2006 09:53 PM
    Paint Color Codes zaxxon62 1G Dodge Durango - Interior/Exterior 4 09-10-2005 06:38 AM
    Color Code for stereo wiring harness pipes013 Dodge Magnum - General Talk 2 01-16-2005 09:15 AM
    Factory Wiring Color Codes...? MeanThree18 Mobile Audio & Electronics Talk 2 10-01-2004 01:03 AM
    2003 Ram stereo wire color codes mcrascal 3G Dodge RAM - Interior/Exterior Talk 3 03-28-2003 10:24 AM
