Dodge ram oil pressure gauge falls then check gauges light comes on - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 04-06-2009, 11:46 AM Thread Starter
ksjosker
ksjosker's Avatar
Exclamation Dodge ram oil pressure gauge falls then check gauges light comes on
I have a 2004 dodge ram with a problem. While driving the oil pressure gauge drops suddenly and the check gauges light illuminates. If I pull over and turn the the truck off then back on, it's fine. Sometimes it will keep doing it, sometimes it wont. It is still under warranty so I took it back to where I purchased it and they replaced the oil pressure switch; still doing the same thing. I was having a few other issues with the truck that they couldn't figure out so they brought it to a dodge dealer for a diagnostic. He said he had them diagnose the oil pressure gauge also. My car dealer claims the dodge dealer said the problem is in the instrument cluster; but my dealers warranty does NOT cover the instrument cluster. So I found a company who repairs them and they said they doubt it is in the cluster. They think the repair shop purchased an aftermarket pressure switch and that could cause the problem.
When the oil pressure gauge falls, the truck runs the same. It does not run rough or anything...
Is it possible the aftermarket switch is junk?? Thanks for your help!!
ksjosker is offline
post #2 of 7 Old 04-06-2009, 01:17 PM
JDMorgan
JDMorgan's Avatar
go to a dodge dealer and get the factory one i think mine was around 20 bucks its in the uper front corner of the motor really easy to change already has sealent on it too just unplug it unscrew it and put the new one in. I cought my dodge dealer scaming me on that they said they replaced it under warenty when mine did the same but i put a blue dot of paint on it befor it went in the third time for them to tell me it was replaced and when i picked it up looked quick and there the sender was with the blue dot. I think they just dont do it bec they know its under warenty and they can keep billing dodge for alot of diagnostic time and they know its just a sender. As soon as i put my new one in it stopped doing havent had a problem since
JDMorgan is offline
post #3 of 7 Old 04-06-2009, 02:00 PM
moparman2k2
moparman2k2's Avatar
Quoted: 2 Post(s)
agreed try an OE sender
Mike
Current Rides:
2015 Ram 1500 Outdoorsman 4x4 Crew
2014 Chevrolet Malibu LT
Former Rams: 86 W150 RC/LB 4x4, 93 W150 RC/SB 4x4, 00 1500 QC 4x4 Sport, 02 1500 QC 4x4 Sport
moparman2k2 is offline
post #4 of 7 Old 04-06-2009, 02:05 PM
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 229 Post(s)
I don't see why you are trying to fix this yourself. Take it to Dodge, tell them its still not fixed.. and they should fix it.
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #5 of 7 Old 04-06-2009, 02:30 PM Thread Starter
ksjosker
ksjosker's Avatar
I purchased it through a private dealer, not the dodge dealership. It is still covered under warranty through my private dealer, but he tells me it's something in the instrument cluster, which is NOT covered under his warranty.
ksjosker is offline
post #6 of 7 Old 04-06-2009, 02:35 PM Thread Starter
ksjosker
ksjosker's Avatar
What should I do? Should I replace the switch from the dealership and see what that does? What if that's the problem, do I go back to where I purchased the truck and tell them I fixed the problem.? I don't have much balls here, I am not one to bitch about things, but damn it, I am getting quite frustrated.
ksjosker is offline
post #7 of 7 Old 04-06-2009, 02:46 PM
Wingviper
Wingviper
Wingviper's Avatar
I put an after market oil pressure gauge and sending unit in my 04, I still have the facory
one in as well, I would try replacing the factory sending unit first as its cheap and easy to do, should only take 15 min. to change out.
The dealers are getting pretty bad on doing what they should, I expected they would as
they are not selling cars, I had a heck of a time getting them to service my wifes PT, had to bring it back 3 times to do something that sould only take 1 day.
Wingviper is offline
    Automatic Transmission Diagnostic Chart tactransman 2G Dodge RAM - Drivetrain Talk 0 03-07-2008 02:49 PM
    Dodge Reveals New 2006 Ram 1500 FreeLantz Rumor Mill & Gossip Talk 60 06-08-2006 09:58 PM
    Dodge Introduces the Largest Pickup Cab Ever RAM MAN Rumor Mill & Gossip Talk 39 06-29-2005 11:09 PM
    2004 Dodge Truck Highlights RAM MAN Rumor Mill & Gossip Talk 0 09-03-2003 05:27 PM
    Press Kit: 2004 Dodge Car Product Line-up RAM MAN Rumor Mill & Gossip Talk 0 08-01-2003 03:42 PM
