How do I get out of limp mode? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 04-04-2009, 05:10 PM Thread Starter
Gusaroo
I suspect my 3.3 v6 2002 grand caravan is in "limp mode". How can I tell if it is? My wife stalled the vehicle and now it seems to only shift into reverse and low gear, the check engine light is on, but the only code showing doing the key on/off trick is P1684 (battery has been disconnected). Any ideas?
Gusaroo is offline
post #2 of 6 Old 04-04-2009, 06:06 PM Thread Starter
Gusaroo
OK, after an hour of searching and reading thru this forum, I believe my problem is the solenoid pack (its been leaking tranny fluid from there for some time now).
My Haynes POS manual has no instructions to do this, has anyone documented the process on this board? I have not found anything yet.
Gusaroo is offline
post #3 of 6 Old 04-04-2009, 07:26 PM
Rick99
It's strange to have the solenoid pack go without any codes-- or to have the tranny in limp mode without any codes for that matter. Are you sure you're not getting a P0700?
Disconnecting the battery should reset the computer so it will start out in normal mode until it detects a fault that sends it back to limp-in.
As for the procedure, plenty of people have managed to remove it from the top with the tranny in place-- may have to remove the battery tray and some other things, just take a look at what it takes to get access. I did mine when I had the tranny out for other reasons-- see post #72 in the following link which will give you an idea for the actual removal and replacement of the pack:
http://www.dodgetalk.com/forums/show...=150579&page=4
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
Just got a new set of BFG All-Terrains
Planning retrofit to 4WABS
1999 Durango SLT+
4x4, 5.2l
Mods: B&M Supercooler, Ford OEM Remote Start/Keyless Entry/Alarm, Heated Seats
01 T&C Limited 3.8l
Rick99 is offline
post #4 of 6 Old 04-04-2009, 09:33 PM Thread Starter
Gusaroo
I agree, I dont think the van is in limp mode, I think the solenoid has failed... I found your post earlier today and printed out the part regarding the solenid. I also do not like to resolve issues by throwing parts at it, but since this thing has been leaking, I might as well replace it and hope for the best. Ill do the two speed sensors too, since they are cheap (under $20) Thx
Gusaroo is offline
post #5 of 6 Old 04-07-2009, 07:31 AM Thread Starter
Gusaroo
Well I replaced the shift solenoid, input and output sensors last night (in the rain). Not too difficult of a job, my 1" socket was not deep enough to get one of the sensors out, but luckily a buddy delivered one to me. Van shifts perfectly now, maybe even a little tighter and no more leaks. All three parts cost me $327 from mopar dealer. I did break a vacuum line T when removing the battery tray, but thats an EZ fix. Thx for the info guys!
Gusaroo is offline
post #6 of 6 Old 04-10-2009, 12:33 PM
frookie
i just replaced my pack is ez to do but a lil costly gl and dont forget to refill tranny lol
frookie is offline
    93 Dynasty ATF Identification / limp in mode danno245 Vintage Dodge Car Forum 1 10-13-2007 11:20 PM
    Help! Limp Mode question xswinnyx 2G Dodge Intrepid - General Talk 7 10-12-2006 11:40 PM
    94 3.3L Caravan in limp mode..HELP!! som1dies2nite Dodge Caravan General Talk 1 04-17-2006 11:43 AM
    95 Stratus Limp mode earnhdtvii 2G Dodge Stratus - General Talk 0 04-16-2006 12:30 PM
    92 Grand 3.3 Limp mode - cure Rochester Joe Dodge Caravan General Talk 1 07-14-2005 09:42 PM
