07 5.9 cummins auto, wont start - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 04-03-2009, 10:05 PM Thread Starter
06trxhemi
ASE approved
06trxhemi's Avatar
the batterys are good. (it started this morning) everything come up like normal. (fuel pump, dash lights ect) but when you turn the key there is nothing. the starter selonoid does not get any power at all. could it be a nutral safety switch? (where is it and how can i check it) or a bad starter relay, (that i cannot locate, keep in mind its not my truck) or possably even a bad starter selonoid? are there any common problems we should look at.
more info: the truck is 100% stock. its used for hauling hay for the guys ranch, and to commute to work with. he does not want to mod it.
Originally Posted by PCP View Post
if it doesn't put a smile on your face, youre in the wrong shop..
follow along with the CNC Plasma cut parts on a 41 Plymouth rat rod build
(i have the capability to do the cutting)
06trxhemi is offline
post #2 of 6 Old 04-04-2009, 11:11 AM
turboedram
there is a problem with the ecm.s on the 2007 5.9, mine did the same thing, went in to home depot came out and nothing would not start, all you can do is have it towed to the dealer, there were a total of 5 trucks with the same problem at the same dealer when mine went out last winter. at that time they were on back order due to so many going out. good luck.
2007 qaud cab,SB,CTD, 6 speed manual, 4" lift,295/70/17 toyo mt,s,aero 4040 muffler,cats gone, BD tripledog with outlook monitor,BD fresh air intake,turboliner spray in bed liner and rocker panels sprayed,20 gal aux.tank,
turboedram is offline
post #3 of 6 Old 04-04-2009, 11:13 AM Thread Starter
06trxhemi
ASE approved
06trxhemi's Avatar
thanks for the help man. its goingin to the dealer this morning. so we will see what it is.
post #4 of 6 Old 04-04-2009, 12:06 PM
co416r
co416r's Avatar
How many miles did you have on your trucks when this happened? Just curious cause I have the same truck.
2007 Ram Mega Cab 5.9 CTD 4X4
ATS Transmission W/Triple Lok TC, Smarty Jr., Fog lights, chrome nerf bars, billet fuel door, OEM clearance lights, Line X, 2in. level kit, Bilstein 5100's, Hellbent Steel steering stabilizer, Glacier Diesel 2 micron fuel filter, S&B CAI, Upgraded 08+ Steering Linkage, BD adjustable trackbar, Maxx end links, Nitto Terra Grapplers 285/70/17.
co416r is offline
post #5 of 6 Old 04-04-2009, 12:08 PM
turboedram
I think it was around 20,000 miles but not sure.
post #6 of 6 Old 04-04-2009, 01:45 PM
Dodgezilla
Dodgezilla
Dodgezilla's Avatar
It's probably the trucks computer has lost communication with the chip in the key. It's a problem I have seen guys have before. Have him try a spare key if it has not already been towed....
04 Ram 2500 HO CTD, 4x4 Mostly Stock 118,000 miles
Dodgezilla is offline
    96 5.9 won,t start need help PROBMW 2G Dodge RAM - General Talk 2 05-30-2007 10:09 PM
    New 6.7-liter Cummins Info Released Today! FreeLantz 3G Dodge Ram Diesel Talk - 6.7L 50 12-02-2006 07:12 PM
    2007 Dodge Ram Heavy Duty RAM MAN Rumor Mill & Gossip Talk 0 09-02-2006 06:14 AM
