Ignition control module location - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 03-25-2009, 07:13 PM Thread Starter
Rodster44
Rodster44's Avatar
Hi
We have a 1995 Dodge 1500 6 cylinder van. It is stalling at highway speeds. Then it will start after a few minutes. Then run for 15 or 20 minutes and quit again. This is only at highway speeds. Running 45-50 no problem. Can you tell me where the ignition control module is loacted and what it looks like or is it part of the computer ? Also any ideas of what is wrong would be welcome. We had a shop check it out today and they conld not find anything wrong.
Thanks in advance Rod
Rodster44 is offline
post #2 of 6 Old 03-25-2009, 08:01 PM
97B2500CCV
Gone but not forgotten
97B2500CCV's Avatar
That is part of the PCM. Since loading of the engine is a factor then it sounds like the fuel filter is clogging up. Sad part is that the fuel filter is part of the fuel pump module which is replaced as an assembly.
Next time it quits you might pull the coil wire and see (be very careful) and see if it sparks when turning over the engine. If so then the problem is fuel delivery.
1977 Chevrolet Impala Sedan, 5.0L, TH200, 2.56:1, 106K miles, 37 Lifetime Warranty Parts.
1989 GMC Sierra Extended Cab 5.7L, 5 Speed, 3.08:1, 327K miles, 0 Lifetime Warranty Parts.
1997 Dodge Ram B2500, gone.
97B2500CCV is offline
post #3 of 6 Old 03-25-2009, 08:09 PM Thread Starter
Rodster44
Rodster44's Avatar
Is the PCM the computer that is mounted on the firewall ?
Thanks Rod
post #4 of 6 Old 03-25-2009, 08:10 PM
97B2500CCV
97B2500CCV's Avatar
Yes it is.
post #5 of 6 Old 03-25-2009, 08:11 PM Thread Starter
Rodster44
Rodster44's Avatar
This is a friends van. I will pass the replies on to him.
Rod
post #6 of 6 Old 03-26-2009, 04:04 PM Thread Starter
Rodster44
Rodster44's Avatar
My friend bought a new fuel pump. He is waiting to change it until he runs some gas out to make it lighter.
Thanks for all the help
Rod
    code sheet stinger1 3G Dodge Ram Performance Talk 63 05-28-2010 04:32 PM
    Trouble Codes for 2nd Gen Neons alaskaneon Dodge Neon - General Talk 3 12-23-2007 11:01 AM
    Generic Chrysler Diagnostic Trouble Code List tactransman 2G Dodge RAM - Drivetrain Talk 0 10-18-2007 02:27 PM
    Where To find Fault Codes?????????? slayer 3G Dodge RAM - General Talk 15 12-27-2003 10:02 AM
    Engine Light on at 21,100 miles ColoradoQuadCab 2G Dodge Dakota Performance Talk 6 11-17-2003 03:25 AM
