Replacing fuel injector? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 03-16-2009, 10:00 PM Thread Starter
Barbarossa13
Barbarossa13's Avatar
So I tried searching but couldn't find a DIY on replacing a fuel injector? I'm almost positive I have a leaking fuel injector. So I'm going to do a tune up soon, and hopefully find a plug that looks wet. That should tell me what injector is leaking, correct? So anyone have any advice on replacing one? And is my train of thought correct in finding which injector is leaking? Thanks in advance folks!
2005 Ram 1500 QC Hemi Laramie, 4'' Rancho Lift, 18'' Amp Wheels, 35'' Dynapro Hankook Tires, Dual Borla Exhaust, Airaid MIT, Power Wire, 2 10'' Rockford Fosgate Subs
Barbarossa13 is offline
post #2 of 10 Old 03-17-2009, 12:36 AM
HemiRamOn22s
Hemi2nV
HemiRamOn22s's Avatar
Quoted: 5 Post(s)
you could pull the injector and check for damage to the O-ring. first thing you do is pull the fuel pump fuse while the truck is running then let it die. turn the key off. undo the positive to the battery. disconnect the injector plugs. unbolt the fuel rail. its 2 bolts for each side. pop the clip off the injector and pull the injector. make sure you have plenty of rags to collect the fuel that will come out when you pop off the injector. to reinstall the injector put some vasaline on the o-ring and slide it back in. reinstall the clip. Repeat as needed. make sure the injectors are seated nice before you install the fuel rail bolts. reinstall the connectors to the injectors and then battery and start it up and check for leaks. Be careful to clean up any excess fuel. A leaky o-ring could cause a fire.
HemiRamOn22s
2014 Black CC 4wd Hemi Ram Sport
-Bilsteins @2.1-Solo Mach40 Exhaust-305/55 Nitto Terras-20x10(-12) Fuel Mavericks-
-Ram Lockbox-5% Tint-Air Lift 1000s-Factory Brake Controller
Other Rides
2007 Jeep Grand Cherokee SRT8
2012 Black Jeep Wrangler Unlimited
2015 Blue Streak CC 2500HD 4wd 6.4L Hemi
HemiRamOn22s is offline
post #3 of 10 Old 03-17-2009, 09:00 PM Thread Starter
Barbarossa13
Wow, thanks for the input HemiRam, sounds like a chore!
post #4 of 10 Old 03-17-2009, 09:52 PM
johnnyk416
Gold Member
Originally Posted by Barbarossa13 View Post
I'm almost positive I have a leaking fuel injector. :
One question what makes ya think ya have an injector leaking??
johnnyk416 is offline
post #5 of 10 Old 03-18-2009, 12:24 AM
draggin-accord
//Negative Camber\\
draggin-accord's Avatar
http://www.dodgetalk.com/forums/showthread.php?t=237883
//NC\\ New Jersey
current project:
low tow - 04 rc sb 2wd hemi - too many mods to list
HEMI VALVE SPRING SWAP TOOL MAKER
draggin-accord is offline
post #6 of 10 Old 03-18-2009, 10:24 AM
johnnyk416
Gold Member
Originally Posted by draggin-accord View Post
Thanks didn't see that, but he still has changed the plugs from what I can see on the other thread. 62K on stock coppers is way to much mileage mine at 33K were .010-.015 out of spec, can't imagine what they would look like if they had 62K on them.
Johnnyk
post #7 of 10 Old 03-18-2009, 10:29 AM
ivegotcows671
ivegotcows671's Avatar
Johnnyk
This make me nervous to pull mine out at 70k..they are getting replace this weekend
CHRIS
2003 4.7L QC RAM
SCT Tune by HEMIFEVER / Killians Ported and Polished Heads / HO Cams / JBA Ceramic Coated Headers / Motive 4.10 gears with lsd / Gibson Dual Extreme Exhaust / DMH electric cutout / Fastman 70mm Throttle body / Jet 180 Tstat / Ramhammer / Sonnax Transmission Line Pressure Booster / Powerwire/Jetstream Scoop / Aeroforce Interceptor Scan Gauge / Custom Powdercoated Srt10 wheels wrapped in 305-40-22 Nitto 420s / Sport Conversion / McGaughys 2/4 Deluxe Drop
Signature picture by BMRbrnSNRbrd
ivegotcows671 is offline
post #8 of 10 Old 03-18-2009, 02:57 PM
06trxhemi
ASE approved
06trxhemi's Avatar
i have 32 5.7 injectors let me know if you need some.they are all used but if you PM me an address ill send you what you need for the cost of shipping.
Originally Posted by PCP View Post
if it doesn't put a smile on your face, youre in the wrong shop..
follow along with the CNC Plasma cut parts on a 41 Plymouth rat rod build
(i have the capability to do the cutting)
06trxhemi is offline
post #9 of 10 Old 03-24-2009, 11:07 PM Thread Starter
Barbarossa13
Sorry I haven't responded, been a hectic few days. Anyway I still haven't tore into my truck. The dealer said it's not covered under 70k/7 year, wishful thinking, and another place wanted $160 to replace the injector. So I think I'll try it myself. Will I know a bad injector when I see it? Or is it normally just a bad o-ring on these that causes a leak? Thanks again for your input guys, I really appreciate it!
post #10 of 10 Old 03-25-2009, 08:11 AM
06trxhemi
ASE approved
06trxhemi's Avatar
I got your PM, and ill respond to it a little later.
    code sheet stinger1 3G Dodge Ram Performance Talk 63 05-28-2010 04:32 PM
    Generic Chrysler Diagnostic Trouble Code List tactransman 2G Dodge RAM - Drivetrain Talk 0 10-18-2007 02:27 PM
    Generic Chrysler Diagnostic Trouble Code List tactransman 1G Dodge Durango General Talk 0 10-18-2007 02:27 PM
