How to Replace EGR Valve??? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 03-15-2009, 06:06 PM Thread Starter
Nine inch RAM
Can anyone explain how to find and replace the EGR Valve. I own an 05 4.7 V8 1500 and wish to repalce this part due to a check engine light.
Any help is appreciated. Pics would be a plus!
Nine inch RAM is offline
post #2 of 13 Old 03-15-2009, 10:24 PM
danhalen
danhalen's Avatar
From my '05 FSM:
REMOVAL
4.7L Engine
The electronic EGR valve and solenoid assembly
is attached to the rear of the left cylinder head. An
exhaust gas routing tube connects the EGR valve
to the intake manifold.
1. Remove electrical connector at top of EGR
valve solenoid.
2. Remove tube mounting bolt at intake manifold.
3. Remove two bolts connecting EGR tube to
valve assembly.
4. Remove gasket located between EGR tube flange
and EGR valve assembly.
5. Remove two EGR valve mounting bolts.
6. Separate valve assembly from engine.
7. Remove and discard metal gasket located between
cylinder head and valve assembly.
INSTALLATION
4.7L Engine
1. Clean area at rear of left cylinder head where it
joins base of EGR valve.
2. Clean EGR tube where it joins EGR valve.
3. Position new gasket between EGR valve and cylinder
head.
4. Position EGR valve to cylinder head. Install and
tighten two bolts. Refer to Torque Specifications.
5. Position new gasket between EGR tube flange and
EGR valve assembly.
6. Position EGR tube to side of EGR valve and
into intake manifold. Install two bolts finger tight
(temporarily).
7. Install EGR tube flange bolt at intake manifold.
Tighten bolt. Refer to Torque Specifications.
8. Connect electrical connector to top of EGR
valve solenoid.
9. Do a final tightening of two EGR tube bolts.
I don't see any torque specs, though. Hope this helps.
2011 Deep Water Blue RAM 1500 4x4 QC Sport - Black Mopar Tubular Side Steps, HBS 2.5", Mopar Molded Splash Guards, DualLiner, Husky Floor Liners
Blue Truck Club Member #264
RIP 4/13/05 - 10/22/11 2005 Bright Silver Ram 1500 QC Laramie 4x4, Hemi, Loaded, Sirius, Mopar Tubular Side Steps, Bilsteins, AEM Brute Force Intake, Jet Stream Scoop, Magnaflow Dual Exhaust, Sylvania Silverstars
danhalen is offline
post #3 of 13 Old 03-16-2009, 02:26 AM Thread Starter
Nine inch RAM
Hell yeah...thanks alot! Did u do this work on your truck and for what reason?
post #4 of 13 Old 03-16-2009, 08:16 AM
hemi1569
All Around Great Guy
hemi1569's Avatar
nine inch what engine do you have
hemi1569 is offline
post #5 of 13 Old 03-16-2009, 03:37 PM Thread Starter
Nine inch RAM
post #6 of 13 Old 03-16-2009, 04:14 PM
zbgsaa
Just did this on my 05 hemi
pain in the ass getting my big hands in there to undo and tighten the bolts
Member #72 "The Red Truck Club"
zbgsaa is offline
post #7 of 13 Old 03-16-2009, 04:55 PM
danhalen
danhalen's Avatar
I've done it twice (once on mine and the other on a buddies). Both times were on the 5.7. It was a pretty easy job. Only takes about 15-20 minutes.
danhalen is offline
post #8 of 13 Old 03-17-2009, 03:04 AM Thread Starter
Nine inch RAM
I've read in these forums that it's actually easiest in the Hemis. Not sure if theres any truth to that. I'll have to do it as soon as it gets warmer.
Thanks for all the replies...
post #9 of 13 Old 03-17-2009, 01:33 PM
ALZHEMI
HEMI FAN
ALZHEMI's Avatar
very easy job, i have the hemi its in the front (passenger side), i was told by a mechanic not to use silicone !
i just changed my plugs and removed the egr tube made the spark plug change alot easier with this tube out of the way
Official DodgeTalk Supporter
OLD
03 HEMI RAM 1500 QC SB 4X4 SLT W/20'S, ALANTIC BLUE PEARLCOAT (DEAD
"APRIL 04 TRUCK OF THE MONTH"
NEW
06 HEMI RAM 1500 QC SB 4X4 SLT W/17x9 PROCOMP EXTREME ALLOY & 35x12.5x17 COOPER STT, PATRIOT BLUE PEARL COAT, BIG HORN EDITION
ALZHEMI is offline
post #10 of 13 Old 03-17-2009, 06:30 PM
CLappert
Mine is at the dealership as we speak they are bulkin cause its 2weeks out of warrenty so Iam hoping to hear different in the Am . Its an 06 5.7 Hemi
CLappert is offline
post #11 of 13 Old 03-23-2009, 10:42 PM Thread Starter
Nine inch RAM
Damn, I did my plugs today but was not brave enough to tackle on this job while I had the Intake off. The EGR valve is really back in the compartment, I can barely make it out. Is it really that easy to change? I wish someone had pics of this, would really help.
I bought a Haynes repair Manual and the freaking thing doesnt even mention the EGR valve. What gives??
post #12 of 13 Old 04-23-2009, 05:15 PM Thread Starter
Nine inch RAM
Sup, So I have yet to do this job. I just don't know how to get all the way back in the compartment to reach the EGR valve. It's practically hidden on the 4.7 Magnum Engine.
And I know HEMI owners have it alot easier, lucky fockers!
As far as the EGR valve on the 4.7 does anyone have any pics, maybe i'm not looking in the right place. I don't want to pay a mechanic when I know I can probably change it myself, but I truly need some help! Please!
post #13 of 13 Old 04-23-2009, 05:36 PM
RiCh1HTX
RiCh1HTX's Avatar
Can this part be bought at your local auto store?....i need to replace mine as well
RiCh1HTX is offline
    How-To: Throttle Body cleaning and EGR Valve cleaning...... zirai10 2G Dodge Durango - Tech Articles 0 03-13-2009 08:51 PM
    EGR Valve and crankcase breather 97' Half Ton 2G Dodge RAM - General Talk 1 08-18-2008 10:02 AM
    5.7 EGR Valve? DonRam 3G Dodge RAM - General Talk 24 05-18-2007 01:14 AM
    1991 3.3 EGR valve? bodyfat2 Dodge Caravan General Talk 5 10-03-2005 02:11 PM
