Po406? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Durango 2nd Gen (04 - 09) Forums > 2G Dodge Durango General Talk
lagnaf
  Po406? - Posted: 03-03-2009, 01:49 PM
lagnaf's Avatar
EATIN CHEVYS SHITIN FORDS
City: Bladenboro
State: NC
Post #1
has anybody had this code come up? what is the code? i checked it this morning when i went out to crank the d up. do you think this might be what is causing some of the problems i am having with it? like hesitation, running rough sometimes. need help thanks.
2006 Dodge Ram 2500 4x4 CTD
-edge CTS with backup camera and turbo timer
-5in flow pro turbo back with 6in black chrome tip
-35in tires
-led lights in all lights that are not HIDS
-4% window tint
-30% with 4% sun strip on windshield
-dodge door sill gaurds
-dodge catch all mats
-2 10" JL Audio subs
-500 watt amp
-light smoked led third brake light
-light smoked led brake lights with led backup lights
AK1
 Posted: 03-03-2009, 03:08 PM
AK1's Avatar
What! Me Worry?
City: Stoney Creek
State: ON
Status: Online
Post #2
P0406... EGR valve voltage too high.
Sounds like your EGR valve is shot.
BLACK '04 Durango LTD
"Yeah, it's got a HEMI"
SPEED HAS NEVER KILLED ANYONE, SUDDENLY BECOMING STATIONARY, THAT'S WHAT GETS YOU!
Black Truck Club member #153 | DT Durango Club member #72|Hemi Club member #102
lagnaf
 Posted: 03-03-2009, 04:18 PM
lagnaf's Avatar
City: Bladenboro
State: NC
Post #3
thanks ak1!!! you guys think that might be the cause of the problems that i am having?
-35in tires
-4% window tint
-500 watt amp
CopperMtnGuy
 Posted: 03-03-2009, 04:21 PM
CopperMtnGuy's Avatar
Where is the snow?
State: WI
Post #4
Definatly EGR. Those are the same symtoms that I had before I replaced mine. It was expensive, $250 including labor. I would've done it myself except that the dealer would charge $70 if I left without them doing it, and it's on the back of the engine block.
05 Jeep KJ Limted 4x4 (NP242)- Lifted, skid, hooks, Huskyliners
07 Land Rover LR3 SE 4.4 4x4
2005 Durango HEMI 4x2 Limited (Traded)
Sig pic by Dodge4L1fe
lagnaf
 Posted: 03-03-2009, 06:44 PM
lagnaf's Avatar
City: Bladenboro
State: NC
Post #5
for sure it is on the back of the block? i read somewhere on here that the 4.7 was on the back of the engine block and the hemi is up front. i looked to day and i think it is on the front. i am going to clean the throttle body, replace the pcv, this weekend and change the egr if it is where i think it is. thanks durango+kj. so yours was having the same issues mine has? it will hesitate when you try to take off slowly, and run a little rough at when you are cruising at slower speed? i can reset the pcm and it will take care of it for a few weeks and then it comes back.
-35in tires
-4% window tint
-500 watt amp
sca
 Posted: 03-03-2009, 06:55 PM
sca's Avatar
City: Streetsville, CANADA
State: ON
View This User's Timeslip
Post #6
On the Hemi it is straight forward on the passenger side in front of the cylinder head.
...Leading Durango HEMI Performance since 2004...
2007 Dodge RAM 3500 CTD 5.9L Cummins SLT
2008 Dodge RAM 5500 CTD 6.7L Cummins SLT
2011 Dodge RAM 2500 CTD 6.7L Cummins Laramie
lagnaf
 Posted: 03-03-2009, 06:56 PM
lagnaf's Avatar
City: Bladenboro
State: NC
Post #7
thanks sca. you the man!!!!
-35in tires
-4% window tint
-500 watt amp
sca
 Posted: 03-03-2009, 07:31 PM
sca's Avatar
State: ON
Post #8
2 bolts and a clip if I remember corectly + a connector.
zirai10
 Posted: 03-03-2009, 07:37 PM
zirai10's Avatar
Word to your Mother!
City: Naptown
State: IN
Post #9
Pics??? Anyone?
Lagnaf....you mind taking some picture if you decide to do it yourself?
lagnaf
 Posted: 03-03-2009, 07:50 PM
lagnaf's Avatar
City: Bladenboro
State: NC
Post #10
yeah i will post some pics. as soon as i get the time to pic up the parts i am going to do it. hey sca, do you think the problems that i am having is the egr? or do i need to look somewhere else after i replace the egr? when i do the egr i am going to clean the tb and replace the pcv.
-35in tires
-4% window tint
-500 watt amp
sca
 Posted: 03-03-2009, 07:54 PM
sca's Avatar
State: ON
Post #11
Out of the manual.....very handy document at 100 MB!
sca
 Posted: 03-03-2009, 07:57 PM
sca's Avatar
State: ON
Post #12
What I heared is that the EGR doesn't do chit but could it cause problems if it doesn't work properly? Not really sure, the code you have indicates the problem, I would replace it and try if you still have the issues clean your TB. I lean more towards the TB but that doesn't clear your EGR code.
lagnaf
 Posted: 03-03-2009, 08:13 PM
lagnaf's Avatar
City: Bladenboro
State: NC
Post #13
thanks sca. is there anyway you can get the pic to show up better? thanks for the info!!!!
-35in tires
-4% window tint
-500 watt amp
sca
 Posted: 03-03-2009, 08:23 PM
sca's Avatar
State: ON
Post #14
Try that...
lagnaf
 Posted: 03-03-2009, 08:42 PM
lagnaf's Avatar
City: Bladenboro
State: NC
Post #15
that works. thanks.
-35in tires
-4% window tint
-500 watt amp
sca
 Posted: 03-03-2009, 08:44 PM
sca's Avatar
State: ON
Post #16
I thought now you want me to install it for you
lagnaf
 Posted: 03-03-2009, 09:13 PM
lagnaf's Avatar
City: Bladenboro
State: NC
Post #17
if you want to!!!!!!!!! come on down to nc and lend a hand!!!!!
-35in tires
-4% window tint
-500 watt amp
zirai10
 Posted: 03-04-2009, 04:36 AM
zirai10's Avatar
City: Naptown
State: IN
Post #18
Sca you are the man.......I appreciate it.
It had to be the LAST section of the 6661 service manual huh?
And correct me if I'm wrong, but this install shouldn't take more than 30-45 minutes right? Doesn't seem to be too difficult anyways.
DurangoZ
 Posted: 03-04-2009, 02:39 PM
DurangoZ's Avatar
State: OTHER
Post #19
Hey Lagnaf, I had a similar code (I think mine was P0404; but there are at least 4 codes related to the EGR, upper circuit and lower circuit and hi voltage and low voltage for each).
The thin is mine had NO TROUBLE AT ALL, except for the check engine light on all the time. I didn't had the code for longer than 3 weeks/1500 miles aprox. but it was not related to anything I can think of, except for one time the engine just stalled on a stop light, but I don't know if it was related.
So, I think you should check some other things if you have rough engine run at low speeds, pcv and Throttle body cleaning should help discarding from the easiest to the more complicated. Check how old your spark plugs are, maybe wires, what gasoline have you been using, etc... if you are nopt having engine lights it probably is something simple.
Happy owner of a black 05 Durango SLT. And yeah it's packed with a Hemi
lagnaf
 Posted: 03-04-2009, 03:51 PM
lagnaf's Avatar
City: Bladenboro
State: NC
Post #20
well i just had the plugs changed about 2500k ago. so i dont think it would be the plugs. the funny thing is that i can reset the pcm and the problems stop. then a few weeks later it comes back and this code keeps coming up when the problems start. so i think it might be the egr.
-35in tires
-4% window tint
-500 watt amp
