Power Door Locks Out...2002 Dodge Ram 1500 QC - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 16 Old 02-24-2009, 03:54 PM Thread Starter
gemini70
gemini70's Avatar
Hope someone can help. My power locks suddenly stopped working. I tried the wireless key remote, I tried the lock switches on front doors, and nothing. I know the remote has power because it does "beep" when pressing the lock button. But again, does not lock doors. Also tried the fuse box, and no go. Any other suggestions?
02 Ram 1500 QC SLT / SPORT 4X4
Exterior
Graphite Metallic Clear Coat
Ground Effects Package - Thunderroad Kit(factory)
Mopar Three Piece Color Matched
Ventshade Ventvisors 4 piece set
AVS tail light covers
TruXedo Tonneau Cover-Black
Box Bedliner - Under Rail
Interior
"Bone Stock" Infinity 7 Speaker System
Katzkin Leather w/front Seat Ram Head Logos
Billet Door Locks
Silver Front Dash Bezel ( slammed1 )
Engine/Transmission
Next Generation 4.7L Magnum V8
Multi-Speed Auto, 45RFE
Axle Ratio - 3.92
Future Mods(with fingers crossed!)
HEAD RESTS for rear bench seats
Fastman TB 68mm
K&N C.A.I.
JBA Headers
2 1/2" - 3" Rear Drop
Upgrade Sound System
Also, check out my personal website:
gemini70 is offline
post #2 of 16 Old 02-24-2009, 06:50 PM Thread Starter
gemini70
gemini70's Avatar
HELLO?
Got a an update...looked like I had a fuse go. So hoping that was the issue, I replaced fuse and it all seemed fine, and then tested it a few more times, and driver side/front back locks/unlocks, but passenger side/front back keeps getting "stuck". Then fuse blew again. Replaced with a 25a instead of a 20a(ran out of 20a)....and same thing, although this time fuse is not burning out (could be because I went to a 25amp).
Getting frustrated. The only thing I can guess without testing the voltage, is something is lose or causing a break in the circuit on the passenger side of the truck?
Exterior
Interior
Billet Door Locks
Engine/Transmission
Axle Ratio - 3.92
Fastman TB 68mm
K&N C.A.I.
JBA Headers
gemini70 is offline
post #3 of 16 Old 03-14-2009, 04:22 PM
ericsyzf
ericsyzf's Avatar
Quoted: 1 Post(s)
I have the exact same problem. Anybody have this issue and figure it out?
Thanks for any help, Eric
2014 Ram 1500 crew Sport
AMP Powersteps
Truxedo Deuce Tonneau
Sold-2002 Dodge Ram QC 5.9
ericsyzf is offline
post #4 of 16 Old 03-14-2009, 05:08 PM Thread Starter
gemini70
gemini70's Avatar
I am not sured what caused it, or even how I fixed it. The problem just disappeared. I even tried to lock and unlock repeatedly and could not duplicate the problem. Hven't had a problem with it since.
Exterior
Interior
Billet Door Locks
Engine/Transmission
Axle Ratio - 3.92
Fastman TB 68mm
K&N C.A.I.
JBA Headers
gemini70 is offline
post #5 of 16 Old 06-22-2009, 10:07 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
Rehashing using search.
Just last night the whole power door locks on my truck stopped working. Although the remote works and honks and activates the security system. the door lock switch inside works to activate the security system when key is not in ignition. Was this similar to what you experianced? I also tried to push down on the locks themselves on all 4 doors and none of them budge?
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #6 of 16 Old 06-22-2009, 10:19 PM Thread Starter
gemini70
gemini70's Avatar
Sounds like you have something different happening...mine was simply the fuse, but at no time was did they not budge like yours.
Exterior
Interior
Billet Door Locks
Engine/Transmission
Axle Ratio - 3.92
Fastman TB 68mm
K&N C.A.I.
JBA Headers
gemini70 is offline
post #7 of 16 Old 06-24-2009, 11:27 PM
skitzo
I have a similar issue
I've been having trouble too. The #22 fuse keeps blowing. I pulled the rubber cover off the wiring harness between the passenger rear door and the jamb. I found 4 wires that were completely severed and 2 more that had the insulator cracked with exposed wires. That harness really has to bend with the articulation of the rear doors. In my opinion they've got that harness routing in a horrible orientation. It folds the wires nearly in half every time the door opens. It's only a matter of time. I'm going to break out the soldering iron this weekend and see if I can't solve the problem. I'm sure I've got damaged wires on the driver's side too. I've got problems with windows, door locks and rear speakers. I'm hoping this will cure it all.
skitzo is offline
post #8 of 16 Old 06-24-2009, 11:37 PM
mocho
mocho's Avatar
Yep most trucks get that problem eventully. My door locks and windows are so messed up I just forget about it. Not worth all the hassle and money for it only to happen again. It is beyond a bad design
2010 Ram 1500 QC SLT 4x4 Hemi
Gone but not forgotten.
2004.5 3500 4x4 CTD
With plenty of mods.....
mocho is offline
post #9 of 16 Old 06-25-2009, 06:03 AM
DeMoN-HeMi
NEVER DOUBT THE DEMON
DeMoN-HeMi's Avatar
Quoted: 1 Post(s)
someone please fill me in on this? i never heard this one...
Official DodgeTalk Lighting/Wiring Expert & Retired Moderator- Daniel
2003 1500 HEMI QC -Slammed and Sprayed,
2014 Ram 1500 Black on Black Edition HEMI! - The hauler
2013 Charger - The Toy
1995 Camaro - The Project
"Dont Spread my Wealth, Spread my Work Ethic!"
"Debt is normal, be WEIRD" - Dave Ramsey
DeMoN-HeMi is offline
post #10 of 16 Old 06-25-2009, 06:25 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
Im interested also. Sounds like something I wanna at least check on mine.
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #11 of 16 Old 06-25-2009, 01:49 PM
mocho
mocho's Avatar
Well if your windows and door locks work fine your ok. But my windows randomly don't work, sometimes 1 door won't lock/unlock, sometimes the window goes down but not up. It's endless, and fricken annoying. The other problem is the rear doors are a very bad design and the wires get pinched and become bare and eventully break in the black boot.
2004.5 3500 4x4 CTD
mocho is offline
post #12 of 16 Old 06-25-2009, 02:08 PM
rye
Moderator
rye's Avatar
Take off your door panel and inspect the power lock motors. Could just be a bad ground, or a short.
DODGETALK.COM MODERATOR
5.9 2003 1500 4x4
Official Dodgetalk Facebook Page:
rye is offline
post #13 of 16 Old 06-25-2009, 02:17 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
I going on a limb here and thinking the door lock actuator is a cam design? VS. the old 80's style door locks that work "in-line". I can not get any of my locks to work inside(switch or pushing down on lock)/ outside (key) or by remote. Fuse is OK, but haven't pull door panels yet, unless I have some sort of idea, which sofar seems to be an actuator failure.
I don't want to leave my truck exposed to the low lifes that test all the door handles as they walk by at night. So I have it parked in my fenced back yard
dizzyD is offline
post #14 of 16 Old 06-25-2009, 03:17 PM
ramshead
It's probably a broken wire in the harness between the cab and the door.
My '02 had the same problem on both the drivers and passenger side.
You'll need to pull the door panel off and then pull the rubber boot back to see if that's the problem.
ramshead is offline
post #15 of 16 Old 06-25-2009, 09:43 PM
skitzo
Hope I'm not hijacking this thread, but here's some photos for those that are interested. I opened the right rear door and rolled the boot back. The first photo is with the door open and the then closed (looking at it from the right front door opening). Those wires really bend every time that rear door opens and closes. Windows, locks, speakers. They're all f'd up. I plan to solder it together this weekend and check the other side too. Hope that clears it all up.
skitzo is offline
post #16 of 16 Old 06-25-2009, 09:46 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
Wow,
I'm gonna look into this, this weekend!
dizzyD is offline
    Pricing for All-new 2009 Dodge Ram 1500 to Start at $22,170 RAM MAN Rumor Mill & Gossip Talk 3 08-31-2008 12:08 PM
    Dodge to Flex More Muscle in 2006 FreeLantz Rumor Mill & Gossip Talk 10 09-07-2005 10:08 AM
    Dodge Delivers Mega Value with All-New 2006 Dodge Ram Mega Cab FreeLantz Rumor Mill & Gossip Talk 0 09-02-2005 11:59 PM
    2006 Ram QC Revealed mrb83sxt02 3G Dodge RAM - General Talk 54 06-23-2005 04:49 PM
