Codes: P0463 & P0545 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Dakota 2nd Gen (97 - 04) Forums > 2G Dodge Dakota General Talk
IronHorse98
  Codes: P0463 & P0545 - Posted: 02-21-2009, 08:48 PM
IronHorse98's Avatar
State: GA
Post #1
Need some guidance. I know that the code P0545 is the Compressure Clutch Control Relay, autozone part number MT0225, $12.99. And code P0463 is the Fuel Level Sensor. I cannot find that damn part any where, is it a dealer part? And also, how do i replace it? Drop the tank? The truck is running rough as hell, it misses, stumbles at idle and has a slight miss while accelearating. I took it to AUTOZONE and that is the only two codes it pulled. I am not sure that these two codes would cause it to run badly. The Fuel level code i can live with, every ounce in a while when i turn the key on, the fuel level doesnt register, i turn the key off and then back on, everything is fine. And the the slip that autozone gave me explaining CODE P0545 is: "The PCM has determined that the voltage signal from the exhuast gas temperture sensor in bank 1 is too low for the current engine operating conditions. (Bank 1 identifies the location of cylinder #1, while Bank 2 identifies the cylinders on the oppitsite bank)."
What the hell does that mean? I thought P0545 was the Compressor Clutch Control Relay? Need help, confused as hell.
1998 2wd R/T CC, 3inch lift, 32/11.50/15 Nitto's, 4:56 gears, 5 speed conversion, full exhuast header to dumped flowmaster, in bed tire carrier, all badges removed, pre-runner front tube bumper, lights everywhere, BIG ASS GREDDY RADIATOR with 21 inch fan, 5.9 + 5 speed= alot of offroad fun.
Future mods: Carb conversion, 408 stroker, 4 link rear suspension.
"If your too scared to carry your truck offroad, take your pansy ass and go buy a honda" - Robby Gordon..
IronHorse98
 Posted: 03-03-2009, 01:47 PM
State: GA
Post #2
Anyone? I have decided to change the AC Compressor Clutch Relay and the Pre-Cat O2 Sensor. That will clear the codes, but if they dont make the truck run better, i will have clear codes, and i will have new parts on the truck i wont have to replace for awhile. I am also ordering a FASTMAN O2 SIMM because im taking the cat and the mufflers off to run strait pipe. I want to replace the pre-cat O2 Sensor because i want to keep my fuel-air ratio's correct.
CornFan
 Posted: 03-03-2009, 03:33 PM
CornFan's Avatar
Daddy, my hat blew off
City: Omaha
State: NE
Post #3
I know the fuel pump also controls the fuel gauges in some vehicles, perhaps that's where the fuel level sensor is located. I can't say for sure if that's the case with a Dakota, but that could explain why you can't find the part.
TEAMFAST
 Posted: 03-03-2009, 06:01 PM
TEAMFAST's Avatar
01RC2WD4.75SPD
City: Montreal, Canada
State: ON
Post #4
email me at macdonaldrp@yahoo.ca and i will send you the shop manual PDF. Fuel sending unit its fully explained with diagrams on p. 14-5 thru 14-7
Unsafe at any speed
codes codes codes! WONT run! ridgerunner03 3G Dodge RAM - General Talk 12 04-20-2009 05:20 PM
Engine Codes (43) WilsonOSF 2G Dodge RAM - General Talk 0 12-01-2007 04:58 PM
'99 Caravan, unable to get codes?! Chikan Dodge Caravan/Grand Caravan Talk 7 04-26-2007 06:15 PM
1998-2004 Intrepid Trouble Codes, and how to retrieve them Daytrepper 2G Dodge Intrepid - General Talk 0 04-19-2007 03:39 AM
Read YOUR Fender Tag: RAM MAN Mopar Muscle Talk 3 10-07-2005 10:03 AM
