Oil Pan Removal Help / 5.7 HEMI 2500 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 12 Old 02-12-2009, 09:49 AM Thread Starter
headstrong569
Does anyone out there know if it is possible to remove the oil pan from an 05 ram 2500 w/ 5.7 hemi. without pulling the motor? I replaced the oil pump but the screen on the end of the pick up line is clogged and I really can't bring my-self to remove the entire engine just to drop the oil pan there has to be another way
headstrong569 is offline
post #2 of 12 Old 02-12-2009, 09:51 AM
Dskirtech
Dskirtech's Avatar
Headstrong,
Im going to move this thread to 3 Gen Ram General Talk. You will get much more exposure there. This area is primarily for submitting New How-To: articles.
The guys over there should be able to help you out.
Dane Skirtech - Moderator
MadDawg
Proud Member of WCPW Parts 1-3,432
2010 TRX Quad
/...Not Stock
.....Political Correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end..........
Dskirtech is offline
post #3 of 12 Old 02-12-2009, 09:55 AM
Dskirtech
Dskirtech's Avatar
3 Gen Guys, Can anyone Offer some Advice?
Thanks!
MadDawg
2010 TRX Quad
/...Not Stock
post #4 of 12 Old 02-12-2009, 10:11 AM
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 229 Post(s)
I think the easier way to do this is to remove the starter, transmission. I've only heard of it being done this way. Someone on here will give you a better answer then mine.. haha
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #5 of 12 Old 02-12-2009, 10:12 AM
Palmentech766
^GM Goodwrench Certified^
Palmentech766's Avatar
it calls for you to loosen the engine mounts, remove the crossmember and lift up the engine to gain clearance.
2013 Ram 1500 Outdoorsman Mineral Gray
1978 AMC Matador Wagon Morocco Buff
1967 AMC Ambassador Convertible Matador Red
Palmentech766 is offline
post #6 of 12 Old 02-12-2009, 10:13 AM
Palmentech766
Disconnect the negative battery cable.
Install engine support fixture # 8534. Do not raise engine at this time.
For 2WD vehicles, Remove both engine mount to frame through bolts.
For 4WD vehicles, Loosen both left and right side engine mount bracket to mount bolts, and remove the lower bolt on each side. The upper hole in the engine bracket is slotted.
Remove the structural dust cover (1). (Refer to 9 - ENGINE/ENGINE BLOCK/STRUCTURAL COVER - REMOVAL).
Drain engine oil.
Remove the front crossmember(Refer to 13 - FRAME & BUMPERS/FRAME/FRONT CROSSMEMBER - REMOVAL).
CAUTION: Only raise the engine enough to provide clearance for oil pan removal. Check for proper clearance at fan shroud to fan and cowl to intake manifold.
Raise engine using special tool # 8534 to provide clearance to remove oil pan.
Remove the nuts from the transmission mount to crossmember.
Using suitable transmission jack, raise the transmission approximately 3 inches off of the crossmember.
NOTE: Do not pry on oil pan or oil pan gasket. Gasket is integral to engine windage tray and does not come out with oil pan.
Remove the oil pan mounting bolts using the sequence above, and remove oil pan.
NOTE: The double ended oil pan studs must be installed in the same location that they were removed from.
Unbolt oil pump pickup tube and remove tube.
NOTE: When the oil pan is removed, a new oil pan gasket/windage tray assembly must be installed. The old gasket cannot be reused.
Discard the integral windage tray and gasket and replace.
post #7 of 12 Old 02-12-2009, 11:49 AM Thread Starter
headstrong569
thank you
thanks for all the help it seems like i have no choice but to raise it up. you guys are great thanks again
post #8 of 12 Old 03-15-2009, 10:58 PM
07 sport
I just changed an oil pan in a 2004 2500 and you just have to remove the support form the trans. Unbolt the pan unbolt the pick up tube from the oil pump and the one support nut from the middle main cap bolt from inside the pan with a wrench and pull the pan out and change the gasket.
07 sport is offline
post #9 of 12 Old 03-16-2009, 12:14 AM
TwinStick
Why would it be plugged in the first place ??? I have never heard of that on such a new vehicle.
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
post #10 of 12 Old 03-16-2009, 08:18 AM
hemi1569
All Around Great Guy
hemi1569's Avatar
maybe infrequent oil changes
hemi1569 is offline
post #11 of 12 Old 03-16-2009, 09:25 AM
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
Yeah I do find this to be a bid odd. Maybe oil additives.
do you have any history on the vehicle?
My Vehicle Build =
post #12 of 12 Old 03-16-2009, 11:44 AM
Palmentech766
what is it today and bumping month old threads, i posted in one this morning, the last post was in october.
    Article says "wrong oil causes improper operation of MDS" TSB waynebyrom 3G Dodge RAM - General Talk 5 12-16-2008 01:46 PM
    Need Help Removing Oil Pan cretamk 3G Dodge RAM - General Talk 23 01-14-2008 07:07 PM
    Question? regarding low oil pressureon 5.7 Hemi buddyboy 3G Dodge RAM - General Talk 11 10-02-2006 05:23 AM
    Synthetic Oil for 5.7 hemitwo 3G Dodge RAM - General Talk 78 09-27-2003 12:02 PM
    Dirty Looking Oil dodgehemi345hp 3G Dodge RAM - General Talk 12 09-26-2003 06:37 PM
