2001 Dodge Tranny PROBLEM!! (no reverse) - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 02-10-2009, 03:51 PM Thread Starter
ZERO˝
Hey guys, a dodge newbie here. I have a 2001 4X4 1500. The other day, reverse just went completely out. Drive seems o, tho i only drove it about 5 miles. When ever you start it up, and shift into reverse, you can feel the gear kick in, but when you hit the throttle it just revs up. not quite like it is in neutral cause the motor sounds a little different, but like it just wont pull it self. Any tips?? I am TERRIBLE at trannys!!!
ZERO˝ is offline
post #2 of 6 Old 02-14-2009, 11:21 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
Sounds like your band is not grabbing to me. Is the fluid level good?
Justin
Resigned July 19th 2011
COIN HOLDERS ASSOCIATION MEMBER # 88
Beta tester for online games.
1998 Dodge Ram 1500 qc sport 360 4x4
208,300 original miles (as of 9-25-10)
new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core.
Jmw132001 is offline
post #3 of 6 Old 02-16-2009, 02:02 PM Thread Starter
ZERO˝
Yup fluid level is exactly where needs to be. And yes before it gets asked, it was warm and in neutral. Can the band be tightened up???
ZERO˝ is offline
post #4 of 6 Old 02-16-2009, 02:57 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
yes, if it is the bands causing the problem then they can all be tightened.
Justin
post #5 of 6 Old 02-16-2009, 09:46 PM
tactransman
Transmission Man!
tactransman's Avatar
Welcome to Dodge Talk!
You probably broke the low and Rev band ,rear servo piston or the snap ring in the OD section.
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #6 of 6 Old 02-16-2009, 10:55 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
This man knows what he is talking about
Justin
    2008 Dodge Charger — Bold, Powerful and Capable RAM MAN Rumor Mill & Gossip Talk 0 09-12-2007 01:48 PM
    Dodge Announces Pricing for New 2008 Dodge Dakota RAM MAN Rumor Mill & Gossip Talk 8 07-25-2007 09:53 AM
    All-new 2007 Dodge Caliber SRT4 to Dominate Sport-compact Market FreeLantz Rumor Mill & Gossip Talk 13 02-17-2006 08:10 PM
    2006 Dodge Ram 1500, What's New for '06 RAM MAN Rumor Mill & Gossip Talk 4 07-19-2005 09:31 AM
    2004 Dodge Car Highlights RAM MAN Rumor Mill & Gossip Talk 0 08-01-2003 02:38 PM
