'95 Plymouth Voyager "Trans System Relay" going nuts before engine start. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 02-01-2009, 12:15 PM Thread Starter
deusexaethera
Still trying to diagnose what the hell is going wrong with my 1995 Plymouth Voyager -- aside from the fact that it's old as dirt and has 288kmi on the clock, of course.
It's intermittently dropping into 2nd gear, the infamous "limp mode" (without which I wouldn't have made it home one night, so it's not all bad), and the speedometer is also intermittently cutting out. Both the input and output speed sensors have been replaced, so while it's possible the new OSS is pooched already, it doesn't seem likely. I unplugged the ISS, OSS, and transmission computer harnesses and hit them with silicone spray to dry them out, but that made no difference.
Since it's a '95, I don't have the luxury of plugging in an OBD2 reader, but I was able to use the Check Engine light to blink out codes to me, and it's reporting codes 37 and 15 -- i.e., "Part Throttle Solenoid Short" and "No Output Speed Sensor Signal".
In addition, I noticed that one of the relays in the relay box next to the battery is clicking on/off constantly, stock-ticker style, when the ignition is on but the engine is off. It stops doing that when the engine is started. It might be totally unrelated, but I don't recall it ever doing that before. I swapped out the relay and it still does it, so it's not a problem with the relay in any event.
Any of this ring any bells?
deusexaethera is offline
post #2 of 3 Old 02-02-2009, 01:14 PM
91AWD3.3
Sometimes, shutdown & restart gets the tranny back.
Grounds can be problematic; allpar covers all the basics.
Dealer Item $$$ type scanner can pull tranny codes (~40 buckis).
Good thread here.
Tranny solenoid pack might be a prob & ~ easy (clean up & 3 bolts) to change (part is ~ 100 bucks).
91AWD3.3 is offline
post #3 of 3 Old 02-02-2009, 10:53 PM Thread Starter
deusexaethera
Well...I appreciate the advice, but we have snow coming, and a move also, so the decision was made to replace the old Plymouth Voyager with a 2005 Dodge Grand Caravan with ~30kmi on the clock. Anything I should watch out for with this one?
    Found a cool site for dodge vehicles... hemi1569 2G Dodge RAM - General Talk 10 08-12-2008 01:43 PM
    2008 Dodge Charger — Bold, Powerful and Capable RAM MAN Rumor Mill & Gossip Talk 0 09-12-2007 02:48 PM
    All-New 2008 Dodge Grand Caravan Extends Its Leadership RAM MAN Rumor Mill & Gossip Talk 0 09-12-2007 02:46 PM
    2007 Dodge Dakota RAM MAN Rumor Mill & Gossip Talk 19 01-23-2007 05:04 PM
    Check Engine code 2002 3.3 engine login Dodge Caravan General Talk 5 04-19-2006 11:49 AM
