Replace rear main seal on 318 V8? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 01-26-2009, 07:24 AM Thread Starter
Elajten
Dodge Power
Elajten's Avatar
Hi!
Is it possible to replace the rear main seal on a 318 with the engine and transmission still in the car?
Elajten is offline
post #2 of 7 Old 01-26-2009, 08:36 AM
charlie1935
charlie1935's Avatar
Quoted: 6 Post(s)
If there is room to get the oil pan off, yes.
Grouchy Old Man
Sport short bed
R&S Automotive cat back duals
SSBC slotted rotors
Tri wing tonneau cover
Ultra 50/51 16x10 wheels
265 70x16 Firestone Destination LE tires
3.55 rear
99-01 sport headlights with Silverstar bulbs
MSD coil
Fram Boost intake -Freebie. I won it
Edelbrock shocks
Yes, grandpas like toys too
87 D100 318 auto. stock
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist'
charlie1935 is offline
post #3 of 7 Old 01-26-2009, 10:47 AM
alloro
Elder User
Quoted: 17 Post(s)
The 318 uses a split rear main. You have to remove the oil pan, oil pump, and the rear main bearing cap to get at it. The bottom half is easy because it's in the main bearing cap. The top half is a bit harder because you have to use a stiff wire to push the old one out and around the top of the crankshaft.
alloro is offline
post #4 of 7 Old 01-26-2009, 08:25 PM Thread Starter
Elajten
Dodge Power
Elajten's Avatar
Ok. Sounds good.
Elajten is offline
post #5 of 7 Old 01-26-2009, 08:49 PM
B-300
4 Wheel Power Disc Brakes
You will have to seperate the engine from the transmission so the engine can be raised to remove the oil pan.
Ram Van/Wagon Club Member #4
B-300
B-300 is offline
post #6 of 7 Old 01-26-2009, 10:23 PM Thread Starter
Elajten
Dodge Power
Elajten's Avatar
Is it imossible to remove the pan if i don΄t?
Elajten is offline
post #7 of 7 Old 01-27-2009, 09:20 AM
alloro
Elder User
Quoted: 17 Post(s)
I believe you can loosen the two motor mounts and lift the engine high enough to gain clearance for the pan removal without separating the tranny. You will have to take out the air cleaner housing to give you enough lifting clearance.
alloro is offline
    Automatic Transmission Diagnostic Chart tactransman 2G Dodge RAM - Drivetrain Talk 0 03-07-2008 02:49 PM
    rear main seal spadman 3G Dodge Dakota - Drivetrain Talk 20 11-11-2007 07:55 PM
    Read Main Seal was Never There!?!?! Ramin N' Jamin 2G Dodge RAM - General Talk 0 01-05-2007 01:16 AM
    Chrysler Crossfire Arrives to World Markets RAM MAN Rumor Mill & Gossip Talk 3 07-27-2003 05:49 PM
