Torque Specifications for Differential Cover - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 01-17-2009, 01:12 PM Thread Starter
krs
Anybody know whats the torque required to tighten down the cover for a 98 1500 v6? Im thinking its the same as my 3rd gen, but want to be safe.
Thanks
2002 Ram 4.7L 2wd Sold
Performance: 4.56 Gears, H/O Cams, 2008 Intake Manifold, 70mm TB, 4" Custom MIT Tube, Gibson SS Headers, ATI Pulley, SCT Tuned by FlyinRyan,2.5" Custom Y-Pipe With Magnaflow High Flow Cat and Muffler (12580) SI/DO Turn Down After Axel, Jeep Grand Cherokee TCM,
Suspension 4" CST Spindles, 1" Body Lift, 2" Lift Shackles, Doetsch Shocks
Others Srt-10 Pillar With Tranny Gauge, 16 Row Tranny Cooler, Color Matched Grill Shell
krs is offline
post #2 of 13 Old 01-17-2009, 01:35 PM
DODGEPICKUP
DODGEPICKUP's Avatar
Quoted: 2 Post(s)
30 ft. lbs. (41 Nm)
1999 RAM 1500SPORT QC 4X4 5.9 3.55's grrrr
360 MAGNUM POWER 165,000 MILES DYNOED 230/290 ON 35'S
1.7 CRANE ROLLER ROCKERS
DIY CUT,PORTED,EPOXY FILLED KEGGER/ALUMINUM PLENUM PLATE,53MM THROTTLE BODY
JACOBS PRO STREET CD IGNITION
BOSCH DESIGN 3'S 24LBS VETTE INJECTORS
MOPAR P DOUG THORLEY TRI-Y'S
TAYLOR 8.2 THUNDERVOLT WIRE'S
EBC ROTORS N PADS,RUSSELL SS BRAKE HOSES
MARCH UNDERDRIVE CRANK PULLEY
1 TON X-OVER STEERING
DT PRO-FAB TRAC BAR
HELL BENT STEEL 2IN SPACER/SKJ LCA
WINNDEKAR/DSS STEERING BRACE
DODGEPICKUP is offline
post #3 of 13 Old 01-17-2009, 01:36 PM
Lee Peterson
Lee Peterson's Avatar
Quoted: 4 Post(s)
Heres the specs for the 2001 1500 9 1/4 axle.
Differential Cover Bolts 30 - Ft. Lbs.
2002 Dodge Ram 1500 4x4.
360 Magnum
Hughes FI Air Gap
52mm BBK TB
210/220 .512I.512E 110 LSA cam
MSD 6A , Blaster 2 Coil
Spintech muffler
SCT tuned by FlyinRyan
Trucks & Guns Club Member #88
Lee Peterson is offline
post #4 of 13 Old 01-17-2009, 01:58 PM Thread Starter
krs
Thanks guys, I appreicate it
krs is offline
post #5 of 13 Old 01-21-2009, 08:54 PM
canadian_mudder
canadian_mudder's Avatar
Can't say ive ever torqued a diff cover, mind you done so many just got the feel for it by now, But ya everyone here is right 30ftlbs
2000 Dodge Ram 1500 Driftwood 4x4 SLT Ext. Cab
BDS 3" suspension lift
285/75R16 Toyo Open Country M/T
Pacesetter Long tube headers with dual exhaust
AFE Stage 2 Cold air intake
Superchips 3715 programmer
And one sweet rockerguarded gas cap
Trucks and Guns Club member #137
canadian_mudder is offline
post #6 of 13 Old 01-22-2009, 10:26 AM
96Sport
46re(tarded)
96Sport's Avatar
Same. I use the German torque spec. Goot-n-tight
1996 5.2 4x4
-Airaid Intake
-Summit 3 inch duals/Magnaflow SIDO muffler
-2" spacer with 33's
-B&M Trans cooler
-4.56's and track-lock
96Sport is offline
post #7 of 13 Old 01-22-2009, 11:57 AM
OleTomCat
Bridal Veil Falls
OleTomCat's Avatar
Quoted: 1 Post(s)
I use the spot torque method....
Torque it until you see spots...
My name is Al from Summerville, SC and I am a
Me: '14 Ram 1500 EcoDiesel
'01 Ram 1500 5.2L Sport
Rhino Liner, Pioneer sound, new ball joints
I am not just a member I am the President
Wife: '05 Durango 4.7L
OleTomCat is offline
post #8 of 13 Old 01-22-2009, 12:00 PM Thread Starter
krs
Thanks for the comments guys, but I already swaped out the fluid on Sunday and torqued the bolts at 30ft. lbs.
krs is offline
post #9 of 13 Old 01-22-2009, 06:00 PM
canadian_mudder
Guess were just rambling on then lol.
post #10 of 13 Old 01-22-2009, 06:23 PM Thread Starter
krs
Lol, its all good
krs is offline
post #11 of 13 Old 01-23-2009, 05:23 PM
WaltFelix
WaltFelix's Avatar
Tighten it until it loosens and then back off a quarter turn.
Walt Felix
1988 Dakota Sport 4x4 3.9/Auto
1996 Dakota 4x4 SLT Clubcab 5.2/Auto
2000 Ram Sport 4x4 5.9/Auto - Yellow Truck member #4
1967 Barracuda Coupe 340/4-Speed
WaltFelix is offline
post #12 of 13 Old 01-23-2009, 05:52 PM
DODGEPICKUP
Quoted: 2 Post(s)
or the all importent........righty tighty , lefty loosey
DT PRO-FAB TRAC BAR
post #13 of 13 Old 01-23-2009, 10:05 PM
canadian_mudder
lol good ole thread stretcher method. If that dont work ya go till ya hear a snap then off a 1/2 turn.works every time.
    fiberglass cover 03 ram short bed scottyd419 For Sale - Truck Parts 14 01-24-2008 10:28 AM
    Rusty differential cover codys2500 3G Dodge RAM - Drivetrain Talk 15 12-28-2007 09:23 PM
    How a Torque Converter works......... Rob 3G Dodge Ram Performance Talk 2 03-31-2006 08:01 AM
    aps converter RAMBS 3G Dodge Ram Performance Talk 86 01-29-2005 11:48 PM
