Cutting Coil Springs - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 24 Old 01-10-2009, 10:25 PM Thread Starter
rptr00
rptr00
rptr00's Avatar
OK, so I am wanting to lower my D, and I was thinking about trying to cut my springs. I see that some of the Ram guys have done this. I have always been told that cutting springs is very bad. I have thought about it for a while. What if any problems could this cause. I am only going to cut about 1 coil. I know a lot of people have their opinions, just looking for someone with first hand experience that could offer advice or suggestions.
SOLD 2003 SLT Plus 4.7L SOLD - 18x8" Centerline Billet Trigons - Yokohama AVS ST 255/55/18 FR and 285/50/18 - Optima Red Top battery - Gibson chrome headers - Motive 4.56 gears - JET 180 Thermostat -ASP underdrive Pulley
2004 Ford Expedition Eddie Bauer 5.4L
K&N CAI - Magnaflow 3" Catback - 3 inch lift - 315 70 17 BFG AT's
rptr00 is offline
post #2 of 24 Old 01-10-2009, 11:22 PM
2003DurangoSLT
2003DurangoSLT's Avatar
Take it from someone who used to work on a stock car team...the more you cut off of a spring...the stiffer it gets..as to how stiff..that depends on the diameter of the spring wire.
Jim Duffle
2003 Durango SLT 4.7L
145,000 And Still Going Strong!
JVC KD-HDR60 Head Unit
Michelin LTX M/S Rubber
Luggage Rack Removed
Bendix Brakes
Monroe Sensa-Trac Shocks
Mobile 1 High Mileage
Support Our Troops
John 3:16
2003DurangoSLT is offline
post #3 of 24 Old 01-10-2009, 11:48 PM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
you need to just make sure that you cut EXACTLY the same amount from each spring. people do it all the time. As long as both springs are even, you are ok. If not, you will got one side sitting lower than the other. The you will have one side pulling while driving down the road. Then you will need a front end alignemtn every 3 months. Its gets frustrating.
New: 2005 Dodge Ram 1500 QCSB 4x4 Hemi Laramie Bright Silver
Flowmaster SI/DO 40 Series. Superchips 3865 - 91 Tune, 2/4 drop, More to come............
::GONE BUT NOT FORGOTTEN::2005 Dodge Ram 1500 QCSB 4x4 Hemi Sport Black
5.5" Rough Country Lift, Dick Cepek DC2 20x9, 325/60R20 Nitto Terra Grappler's, Superchips 3865 - 91 Tune, Extang Tonneau Cover, K&N Cold Air Intake, Bosch Platinum 4 plugs, Magnaflow Y-Pipe, SI/DO Flowmaster Original 40 Series, Synthetic Everything, 7000K Headlights, Foglights and Hellas..
1998 Dodge Durango SLT 4x4 Black
Hypertech 87 Tune, K&N Cold Air Intake, Bosch Platinum 4 plugs, Bosch 8.5mm Wires. Ported Throttle Body, SI/DO Flowmaster Original 40 Series Muffler, Headman Headers, 3" PA BL, 2" T/S Lift, 33x12.50R15 Firestone Destination M/T's, 15x8 Eagle Alloy Wheels.
BTC Member 211 - Steel Reserve
!05RAM05! is offline
post #4 of 24 Old 01-10-2009, 11:58 PM Thread Starter
rptr00
rptr00
rptr00's Avatar
yeah, I was already thinking the cutting and measuring will be a bit difficult. As for the stiffer spring, that wouldnt be so bad. My D feels really soft up front already. I dont plan to cut alot, just a little bit. I will be shooting for about 1 inch. The Ram guys say 2 coils is about 4 inches, so I will use that as a reference. So I guess I will cut less than 1 coil.
rptr00 is offline
post #5 of 24 Old 01-11-2009, 10:33 AM
dkeys412
dkeys412's Avatar
why not go on ebay and get a lowering kit, they come with everything you need. I lowered my r/t 3 inches with the lowering blocks for the rear, but the front I have the adjustable torsion bars, so I just let me out a little to match the rear. here is a pic
dkeys412 is offline
post #6 of 24 Old 01-11-2009, 11:58 AM Thread Starter
rptr00
rptr00
rptr00's Avatar
First, there are no "kits" out there for an 03. You have to piece it together. Second, I want to do this as a free project / experiment. I have had 2 inch bell tech springs on my D about 2 years ago and the ride was very bouncy up front. Now this was with factory shocks that have since been replaced. I have a set of 2 inch blocks laying around my garage, but would need new u bolts. I may try to work something with the leafs, maybe remove one of the springs or something, not sure on that yet. Anyhow, if this can all be done for practically no cost, I think a lot of people would be interested to know the outcome. Again, this is more of an experiment. I would be willing to put drop springs later on or possibly try out factory R/T or V6 springs.
rptr00 is offline
post #7 of 24 Old 01-11-2009, 12:22 PM
B1G BLEU
WORLD'S GREATEST TRUCK
B1G BLEU's Avatar
I'd like to point out that there's no coil springs on a gen I D
Paul
02 Durango (build 11/01) SLT┼ AB/BLACK INT 4.7L NGC 45RFE PT3.55 LSD 4X4 - Superchips 3715 Performance - Sensatracs - Chrome Nose - Carriage Works Billet Grilles - APC Clear Corners - Infinity 6022i's w/stock tweeters - - Hidden Hitch - Silverstar 9007ST's - K&N high-flow 33-2175 air filter- TFP Chrome Handles - 33K Miles - (MB Gunner Chrome Wheels + General Grabbers wintering in basement) Hammered blue factory rims
Wife's Ride : 2006 Grand Caravan SXT INFERNO RED
Work Ride : 2009 Ford Edge SEL
Daughter's Ride : 2011 Jeep Compass Latitude
Son 1's Ride : 2012 Nissan Altima S Coupe
Son 2's Ride : 2006 STi Stage 2 Grandma Gray (kinda mine, too
B1G BLEU is offline
post #8 of 24 Old 01-11-2009, 12:38 PM
dkeys412
dkeys412's Avatar
you might want to do a search before saying there are no kits for a 03 or any other generation 1 durango. Here you go
http://cgi.ebay.com/ebaymotors/DURAN...Q5fAccessories
and I do understand about the low to almost no money for a experiment which is a good thing to see what could happen, like I said before I only paid the 25 bucks for the blocks, and that's it at auto zone. I also had to find the kit with the bigger u bolts. I had a friend that went to home depot and had ubolts made there for 10 bucks.
dkeys412 is offline
post #9 of 24 Old 01-11-2009, 06:46 PM Thread Starter
rptr00
rptr00
rptr00's Avatar
To clarify, there are no kits from the major companies (Bell Tech, Ground Force, DJM...). I have seen the ebay SpringTechs, but dont know much about them or their quality so I ruled them out.
As for Gen 1 without springs? I have a 2wd with coils up front and leaf springs out back
Home Depot for u-bolts? I'll have to check into that.
rptr00 is offline
post #10 of 24 Old 01-11-2009, 09:45 PM
gr8scott
Haven't ever seen the front of a 2wd Durango then have you?
Scott
to, too, and two
there, they're, and their
your and you're
Doesn't anyone know the difference anymore?
2000 Dodge Durango SLT 2wd 5.9L V8 - 111k miles Fastman tranny, added leaf springs, 4.56:1 gears, Hawk Superduty pads, Bilstein HDs, Yoko Geolander H/T-S 265/75/15, Optima Red Top Battery
gr8scott is offline
post #11 of 24 Old 01-11-2009, 10:21 PM Thread Starter
rptr00
rptr00
rptr00's Avatar
hereis a pic of the 2wd coil spring set up for those who have not seen it
rptr00 is offline
post #12 of 24 Old 01-12-2009, 12:20 AM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
Bleu, you shot yourself in the foot man.
post #13 of 24 Old 01-12-2009, 06:17 AM
Neil F.
Neil F.'s Avatar
DJM has 2wd Durango kits. It says 98-02 but there is no difference suspension wise for the 03 http://djmsuspension.com/applications/dodge%20apps.html
Hotchkis used to have a TVS kit with front coils and rear lowering leafs for the 2wd Durango but it has been out of production for a while so I doubt anyone has a kit in stock. It was part number 80312
99 Durango 5.9, FT 4x4, IP stage III w/ K&N air hat, M1, MOPAR PCM, Fastman TB, 1.7 RR, JBA headers, Borla cat back, Martin Saine valve body, Hotchkis swaybars, Blistein shocks, lowered 2" Black Rhino Kenya wheels, 246. 7 RWHP, 319 TQ
Neil F. is offline
post #14 of 24 Old 01-12-2009, 06:29 AM
Neil F.
Neil F.'s Avatar
Did you search? Belltech lists kis and components for the 2wd Durango http://www.belltechsporttrucks.com/productfinder/
www.belltech.com/products/dodge.htm.
Neil F. is offline
post #15 of 24 Old 01-12-2009, 10:15 AM Thread Starter
rptr00
rptr00
rptr00's Avatar
Again, most "kits" stop at 2002. I dont know the reason why.
rptr00 is offline
post #16 of 24 Old 01-12-2009, 10:21 AM Thread Starter
rptr00
rptr00
rptr00's Avatar
OK ,so I have done a little research on how to cut the springs. It is recommended to cut the "wild end" of the spring 1/4 coil at a time with a cut off wheel or hacksaw. I can use the cut portion as a template for cutting the other spring exactly.
http://www.superchevy.com/technical/...ide/index.html
rptr00 is offline
post #17 of 24 Old 01-16-2009, 07:27 PM Thread Starter
rptr00
rptr00
rptr00's Avatar
Today, I finished the front end. I cut about a 1/4 coil, reinstalled everything, drove it around to let everything settle. This got me about 1 inch. Ripped everything apart one last time, and this time cut just a little less than the first time. Again, reassembled everything and took it for a drive. Now I'm sitting at about 2 inches. I didnt get out on the highway, just neighborhood streets. It honestly feels real good. Not too firm. I installed new shocks about 6 months ago, so I'm sure that helped. The truck has always ridden very rough, so I was a little worried about the increased spring rate. Well, it feels great. This has cost me nothing!
The truck has a slight rake to it right now, added with the larger tires in back. The rear tires are about 1/2 inch taller. I have a set of 2 inch blocks that I might put on or leave off. not sure yet. I like the raked look.
AFTER PIC
rptr00 is offline
post #18 of 24 Old 01-17-2009, 11:41 AM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
I think it looks fine the way it is. I would leave the back the way it is, in the event you go on vacation and throw some stuff in there. The suspension will keep the body off the wheels. Speed bumps wont put you into the body either.
post #19 of 24 Old 01-25-2009, 11:12 PM
B1G BLEU
B1G BLEU's Avatar
Dr. Scholl's can't help me with this one! Truth is, I've never seen a 2wd Durango!
Paul
B1G BLEU is offline
post #20 of 24 Old 03-29-2009, 01:07 PM Thread Starter
rptr00
rptr00
rptr00's Avatar
wanted to post an update on things. as the front suspension settled and got a few more miles on it, the front end was beginning to feel a bit bouncy. Well, thats because it was sitting right on the bump stops. To keep the no cost mod alive, and researching a little online, I decided to go ahead and cut them. Everything I read recommended trimming as much as the drop itself. Well, I cut about an inch and a half from each side. Now it rides much better and the bounce has been eliminated.
rptr00 is offline
    coil springs razer 3G Dodge RAM - Drivetrain Talk 6 07-22-2008 03:09 PM
    Front Coil Springs Cjaiceman 2G Dodge RAM - 4X4 Talk 4 06-23-2008 04:06 AM
    Removing/Installing Coil Springs LaFrance454 2G Dodge RAM - 4X4 Talk 9 03-18-2008 01:31 AM
    Coil Springs Paint?? BigBlackRam1500 2G Dodge RAM - General Talk 9 09-13-2006 04:03 PM
    No coil springs lifted5.9 3G Dodge RAM - 4X4 Talk 2 07-27-2006 07:38 PM
