2001 Dodge 4x4 Rear Differential Interchange - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 01-09-2009, 08:45 PM Thread Starter
Ryan_340
Ryan_340's Avatar
A buddy of mine has a 2001 1/2 ton Dodge Ram Sport 4x4 with a 5.9 engine and auto. trans. The rear in the truck is bad and we are trying to find a replacement. We need to know what years will interchange for the rear?
1972 Power Wagon W100
1971 Duster
1972 Dart Swinger
3- 1972 Demons
Ryan_340 is offline
post #2 of 18 Old 01-09-2009, 09:13 PM
tkirk
work in progress
tkirk's Avatar
what is bad in it it might be easier and cheaper to rebuild
tkirk is offline
post #3 of 18 Old 01-09-2009, 09:18 PM Thread Starter
Ryan_340
Ryan_340's Avatar
The pinion sheared off with the yoke still hooked to the driveshaft. With the cost of having it rebuilt and the labor, I think it will be cheaper to find another rear and then we will install it.
1971 Duster
1972 Dart Swinger
3- 1972 Demons
Ryan_340 is offline
post #4 of 18 Old 01-09-2009, 09:26 PM
tkirk
work in progress
tkirk's Avatar
the only problem with that is what you get could be questionable if you rebuild it you know what you have also you could beef it up while your there just a suggestion of course
tkirk is offline
post #5 of 18 Old 01-10-2009, 11:27 AM
JBostick
JBostick's Avatar
What gears are in it?
Jerdan, Heart of Dixe!
2005 Dodge Power Wagon ----Long Gone
Black, Black leater heated seats with Nav
35x12.50x17 BfGoodrich Kms
Hella 500s behind grill
Locker Bypass
2001 Dodge Ram 1500 Off Road
285 firestone ats
77,000 miles
Super chip
Edelbrock 14x3
Warn 9,500 and Lights
JBostick is offline
post #6 of 18 Old 01-10-2009, 11:59 AM Thread Starter
Ryan_340
Ryan_340's Avatar
3.55 gears
1971 Duster
1972 Dart Swinger
3- 1972 Demons
Ryan_340 is offline
post #7 of 18 Old 01-10-2009, 05:00 PM
JBostick
JBostick's Avatar
Im not sure what all years have abs, other than that they all shold interchange 94-01
Locker Bypass
285 firestone ats
77,000 miles
Super chip
Edelbrock 14x3
JBostick is offline
post #8 of 18 Old 01-11-2009, 03:52 PM
madmikeismad
R.I.P Big Blue
madmikeismad's Avatar
Quoted: 109 Post(s)
Yeah, as long as it's got abs, and you keep the 3.55's in the 9.25 rearend, it should swap out anyways, just make sure to keep the same gears so as not to counter the front end.
Mike Hill
Purple People Eater - 98 12v - Maybe 800whp on old block:
The Race Truck
01 Ram 1500 Sport 4x4 5.9 (RIP Big Blue
madmikeismad is offline
post #9 of 18 Old 01-11-2009, 04:19 PM
DODGEPICKUP
DODGEPICKUP's Avatar
Quoted: 2 Post(s)
correct me if iam wrong but 2001 had rear disc brake's . i wouldnt want to down grade to say a 99 with drum brake's . rear abs was standard on all ram's .
1999 RAM 1500SPORT QC 4X4 5.9 3.55's grrrr
360 MAGNUM POWER 165,000 MILES DYNOED 230/290 ON 35'S
1.7 CRANE ROLLER ROCKERS
DIY CUT,PORTED,EPOXY FILLED KEGGER/ALUMINUM PLENUM PLATE,53MM THROTTLE BODY
JACOBS PRO STREET CD IGNITION
BOSCH DESIGN 3'S 24LBS VETTE INJECTORS
MOPAR P DOUG THORLEY TRI-Y'S
TAYLOR 8.2 THUNDERVOLT WIRE'S
EBC ROTORS N PADS,RUSSELL SS BRAKE HOSES
MARCH UNDERDRIVE CRANK PULLEY
1 TON X-OVER STEERING
DT PRO-FAB TRAC BAR
HELL BENT STEEL 2IN SPACER/SKJ LCA
WINNDEKAR/DSS STEERING BRACE
DODGEPICKUP is offline
post #10 of 18 Old 01-11-2009, 04:58 PM
JBostick
JBostick's Avatar
my 2001 has drums
Locker Bypass
285 firestone ats
77,000 miles
Super chip
Edelbrock 14x3
JBostick is offline
post #11 of 18 Old 01-11-2009, 05:26 PM
DODGEPICKUP
Quoted: 2 Post(s)
Originally Posted by JBostick View Post
my 2001 has drums
thx for the correction . bad memory . its a change over year for rear disc . do you have the dual piston calibers up front ?
DT PRO-FAB TRAC BAR
post #12 of 18 Old 01-12-2009, 09:34 PM
canadian_mudder
canadian_mudder's Avatar
2002 was when the 1500's changed over to the new body style trucks with 4 wheel discs. And I believe 2000 was when they put twin piston calipers up front. which is what mine has.
2000 Dodge Ram 1500 Driftwood 4x4 SLT Ext. Cab
BDS 3" suspension lift
285/75R16 Toyo Open Country M/T
Pacesetter Long tube headers with dual exhaust
AFE Stage 2 Cold air intake
Superchips 3715 programmer
And one sweet rockerguarded gas cap
Trucks and Guns Club member #137
canadian_mudder is offline
post #13 of 18 Old 01-12-2009, 11:13 PM
WaltFelix
WaltFelix's Avatar
Actually 2001 was sort of the first year for rear disks, but it wasn't the full year. The 2000 model year was ended early because Dodge didn't have any CAFE credits and were facing stiff EPA fines. So they ended the 2000 model year at the end of December 1999. Starting in January 2000, all Rams built were labeled as 2001s and still had rear drums brakes. Then starting in July 2000, when the model year retool would have normally happened, the Ram got a rear disk upgrade. While still sold as 2001, some online forums refer to them as 2001.5
Also, my 2000 has twin piston up front.
Walt Felix
1988 Dakota Sport 4x4 3.9/Auto
1996 Dakota 4x4 SLT Clubcab 5.2/Auto
2000 Ram Sport 4x4 5.9/Auto - Yellow Truck member #4
1967 Barracuda Coupe 340/4-Speed
WaltFelix is offline
post #14 of 18 Old 01-13-2009, 01:32 AM
DODGEPICKUP
Quoted: 2 Post(s)
waltflex thx for the info . i knew the 2500 , 3500 recieved rear disc and that it was a change over year but wasnt 100% on the 1500 .
DT PRO-FAB TRAC BAR
post #15 of 18 Old 01-16-2009, 09:55 AM
dorman68
dorman68's Avatar
Here is interchangeabilty information from the Hollander Salvage catalog
DODGE 1500 PICKUP 2000-2001 4x4; 3.55 ratio
dorman68 is offline
post #16 of 18 Old 01-16-2009, 05:32 PM
BOb5150
My truck was built in October of 2000, and it has drums in the rear.
BOb5150 is offline
post #17 of 18 Old 01-17-2009, 10:02 AM
madmikeismad
R.I.P Big Blue
Quoted: 109 Post(s)
How do you find out month/year?
Mike Hill
The Race Truck
post #18 of 18 Old 01-18-2009, 09:11 PM
DODGEIT
DODGEIT's Avatar
Quoted: 1 Post(s)
The tag on the drivers door jamb has the build date on it as well as other information.
2012 Dodge Ram 1500 Big Horn QC 4x4
DODGEIT is offline
    Factory Stock 1/4 mile and 0-60 times. dodgeneonACR98 Street and Strip Talk 8 05-05-2009 08:53 PM
    07 Dodge Ram Mega Cab RAM MAN Rumor Mill & Gossip Talk 0 09-02-2006 07:19 AM
    All-new 2007 Ram 3500 Chassis Cab FreeLantz Rumor Mill & Gossip Talk 1 03-02-2006 04:35 PM
    2006 Ram 1500 Info FreeLantz 3G Dodge RAM - General Talk 120 02-20-2006 01:09 AM
    Dodge Delivers Mega Value with All-New 2006 Dodge Ram Mega Cab FreeLantz Rumor Mill & Gossip Talk 0 09-02-2005 11:59 PM
