5.9 missing (running rough) when cold? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 12-31-2008, 11:24 AM Thread Starter
graphicmovement
graphicmovement's Avatar
I have 2002 1500 with 5.9 85,000 miles. It was previously missing when cold about 3 months ago, and a buddy of mine (dodge tech) suggested I go through the ignition system, so I replaced plug, wires, rotor and cap (all mopar parts). It ran great for 3 months, now I am back to missing from start up for about 5 minutes, then it runs fine. Another note Dodge replaced my long block under warranty (rod knock), I wonder if there is a connection?
Thanks guys!
graphicmovement is offline
post #2 of 3 Old 12-31-2008, 12:52 PM
desync0
Gear Jammer
desync0's Avatar
make sure all the plug wire a firmly pushed on to the plugs (i had one come loose and it would intermitantly miss at idle)
And did you route all the spark plug wires according to the tsb?
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
2002 Flame Red QC 4x2 Sport With a 360! Sold
Red truck club member #251
2011 Wrangler Trading ASAP I miss my truck!
desync0 is offline
post #3 of 3 Old 12-31-2008, 02:40 PM Thread Starter
graphicmovement
Thanks, I will check the wires to see that they are fully engaged, dodge did the install of the wires and plugs, so I hope they did it correctly, but I will double check that also.
Thanks again!!
    Doh!~ Running Rough - Thoughts! 2006 Dodge 2500 Diesel Prynce 3G Dodge RAM Diesel Talk 9 10-14-2008 05:28 PM
    '02 4.7 running rough Mongo79 3G Dodge Ram Performance Talk 27 08-17-2008 03:40 PM
    Problems running in the cold codydale 1972-1987 Dodge Ram Trucks (D, W-series) 14 12-14-2007 03:35 PM
    Problem running with damp cold days whtrthanu 2G Dodge RAM - General Talk 2 03-19-2004 05:16 PM
    truck putting out code 32 and running rough skijoe 2G Dodge RAM - General Talk 0 12-29-2003 11:56 PM
