2001 Dodge Durango TCCM - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 12-10-2008, 10:34 AM Thread Starter
MidMichTrans
Can anyone tell me where it it? A picture would be great. The picture I got from the dealer has an arrow pointing up. A bit less than descriptive. I have the book for it, and can't find anything about it.
If this has already been answered and you'd be kind enough to direct me to the thread it would be very much appreciated!
MidMichTrans is offline
post #2 of 3 Old 12-10-2008, 03:59 PM
skebert
2005 SRT4
skebert's Avatar
I hope this helps you out:
DESCRIPTION
The Transfer Case Control Module (TCCM)(Transfer Case Control Module (TCCM)) is a microprocessor-based assembly, controlling the 4X4 transfer case shift functions via the actuation of a shift motor and utilizing the feedback of a mode sensor assembly. Communication is via the PCI serial bus. Inputs include user selectable 4X4 modes that include AWD(NV244), 2WD(NV133 and NV233), 4HI, 4LO, and Neutral. The logic and driver circuitry is contained in a molded plastic housing with an embedded heat-sink and is located behind the center section of the lower instrument panel, to the right of the steering column.
*Dodgetalk.com 287 Enthusiast Member #14*
2005 Neon SRT-4
skebert is offline
post #3 of 3 Old 02-20-2009, 10:27 PM
45romeo
TCCM photo.
Here is a photo of where the TCCM is located on an '01 Durango. It is the blue box behind the metal dash frame. Held in by 3 screws. No need to cut anything, just takes some patients to wiggle it out. Need to remove the lower base trim and ashtray which is still in place in this photo.
I had the same problem where the trasfer case quit responding, no lights on the switch and the switch did nothing. I was stuck in 4wd Hi. Took to the stealership and they wanted $445 for the part and a couple hundred to put it in. Found one for $75.00 delivered. Plugged it in and it works great.
I also found a 2000+ page manual in pdf format for a 2001 Dakota. Described in great detail how to remove the dash. Easy to do, just remove the screws and it "pops" off with a quick tug. search "2001dakotamanual.pdf" in google and you'll find the manual.
45Romeo
45romeo is offline
    Dodge Announces Pricing for New 2008 Dodge Dakota RAM MAN Rumor Mill & Gossip Talk 8 07-25-2007 10:53 AM
    2007 Dodge Durango FreeLantz Rumor Mill & Gossip Talk 24 01-23-2007 04:33 PM
    All-new 2007 Ram 3500 Chassis Cab FreeLantz Rumor Mill & Gossip Talk 1 03-02-2006 04:35 PM
    Legendary Dodge Ram Power Wagon Returns RAM MAN Rumor Mill & Gossip Talk 4 10-02-2004 06:44 PM
    Press Kit: 2004 Dodge Car Product Line-up RAM MAN Rumor Mill & Gossip Talk 0 08-01-2003 03:42 PM
