P0128 Help - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 12-08-2008, 01:05 PM Thread Starter
firecadet613
P0128 Help
My D is throwing a P0128. I reset the computer and a few days later it set it again. What should I be looking at first? It has a new thermostat in it that I installed back in May when I flushed my cooling system completely and refilled with new Mopar HOAT fluid. It's a Stant 203 degree unit I believe.
Should I replace it again, or look at the temp sensor?
2006 Ram 2500 QC 4x4 Hemi
firecadet613 is offline
post #2 of 13 Old 12-08-2008, 03:52 PM
Beach Assault
Beach Assault's Avatar
Quoted: 12 Post(s)
What did the code say? Overheat?
Big Black Limited w/Hemi and 20" Chrome Ram Wheels
Roof Carrier for 20" Spare
Removed Front Spoiler
Tinted Front Windows
Blackened Tail Lights
SmittyBilt Grill Guard
Blacked out the grill
1 1/2" Torsion Lift
Westin Sidebars
OEM Mudflaps
Rancho RSX Series Shocks
Red Brake Calipers
Slotted Rotors
Hawk Pads
MOPAR/Magnaflow CAT-Back exhaust
SuperChips[tm] Tuned 93 Octane
Taylor "Shorty" Sparkplug wires
Home-built PVC SRI
DodgeTalk.com Durango Club Member #41
Beach Assault is offline
post #3 of 13 Old 12-08-2008, 07:47 PM
sca
sca's Avatar
Sounds more like a sensor, what does your temp gage show? Are you over-heating as well?
sca is offline
post #4 of 13 Old 12-08-2008, 11:04 PM Thread Starter
firecadet613
Sorry I should have put this in the original post. P0128 is the truck taking too long to warm up, at least thats what the PCM states. I have noticed since it's gotten colder out it does take a bit longer to get warm on the gauge. I did have a problem earlier this year where the gauge said it was running a bit on the warm side but after changing the coolant and thermostat it still said the same. Maybe its my temp sensor. Has anyone changed one yet?
post #5 of 13 Old 12-09-2008, 06:04 AM
sca
sca's Avatar
Could be a stuck open thermostat or a defective sensor.
sca is offline
post #6 of 13 Old 12-09-2008, 08:59 AM Thread Starter
firecadet613
Thats what my guess is. What would you try first?
post #7 of 13 Old 12-09-2008, 12:59 PM
Beach Assault
Quoted: 12 Post(s)
Does it take a long/longer time for the heater to blow hot air?
If not - temp switch bad.
If so - open thermostat.
1 1/2" Torsion Lift
Westin Sidebars
OEM Mudflaps
Red Brake Calipers
Slotted Rotors
Hawk Pads
Home-built PVC SRI
post #8 of 13 Old 12-09-2008, 01:22 PM Thread Starter
firecadet613
I haven't noticed an increase in time. Temp switch it is. I picked one up this AM...looks like I have to move my a/c compressor to change it.
Anyone change it out before?
post #9 of 13 Old 12-09-2008, 09:36 PM Thread Starter
firecadet613
Talk about a PIA to get to. Its burried under the A/C Compressor.
Got it changed out...I'll report back in a few days if it did the trick or not.
post #10 of 13 Old 12-09-2008, 09:48 PM
sca
sca's Avatar
sca is offline
post #11 of 13 Old 12-10-2008, 12:09 PM
rangoneer
Power Aficionado
rangoneer's Avatar
going back to the Thermostat. When you put it in make sure the air release tab is up.
05 LTD Black HEMI ...loaded with the basics
I NEED MORE POWER!! ...and to lose some weight!
rangoneer is offline
post #12 of 13 Old 12-10-2008, 12:28 PM
rangoneer
Power Aficionado
rangoneer's Avatar
Sorry, I'm usually more thorough with DTCs...here's some info.
P0128-THERMOSTAT RATIONALITY
Theory of Operation
The PCM predicts what the engine coolant temperature should be, based on the engine coolant temperature at start-up, ambient temperature and how the vehicle is subsequently driven. The predicted engine coolant temperature is compared to the Engine Coolant Temperature Sensor reading. The error between the two is calculated and integrated with respect to time. When the Thermostat diagnostic runs, the integrated error is compared to a calibrated threshold and pass/fail is determined. Separate pass and fail thresholds are used in order to improve accuracy of the diagnostic.
Oh and make sure your coolant isn't low.
post #13 of 13 Old 12-24-2008, 08:40 AM Thread Starter
firecadet613
My wife drove my truck to work today. It spit back out the P0128. It has a brand new temp sensor, is the only other possible cause the thermostat? Coolant is about 6 months old and same with the thermostat.
    P0128 Coolant Thermostat Malfunction... Casey02L 3G Dodge RAM - General Talk 3 03-07-2005 12:56 PM
