Fuel rail connector hose leak - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 12 Old 12-04-2008, 01:08 PM Thread Starter
ontos
98 Ram 360 2500 4x,
I have a leak on the passenger side end of the fuel rail crossover hose.
hard to see the connection. Is it a clamp? Does the entire hose need to be replaced or is it simply( as if) a new clamp needed?
Thanks any info or advice.
ontos is offline
post #2 of 12 Old 12-04-2008, 01:22 PM
parks9
parks9's Avatar
GET THAT FIXED!! dont drive it until you do, i just lost my 95 ram cuz it caught on fire and burnt.. Im telln you do not drive it until its fixed. I know on the 95 it was just glued on, but im not sure on the 98, u will have to replace it more then likely, but when i went to replace mine they gave me regular fuel line and said it would work, so i changed it out, but didnt put clamps on it because my other hose didnt have them, in turn, my truck is a gonner. Its only a gonner cuz it leaked and ignited, if i wouldve put hose clamps on it, it would be here today
2000 Ram 1500 4x4 Sport ext cab
5.9
163,000
flowmaster
k&n filter
leveling blocks
parks9 is offline
post #3 of 12 Old 12-04-2008, 01:23 PM
parks9
parks9's Avatar
might i say that it was a leak on the same side too!
5.9
163,000
flowmaster
k&n filter
leveling blocks
parks9 is offline
post #4 of 12 Old 12-04-2008, 07:13 PM Thread Starter
ontos
Thanks, it's parked.
Need daylight to see how the hose is connected.
ontos is offline
post #5 of 12 Old 12-04-2008, 07:24 PM
DODGEPICKUP
DODGEPICKUP's Avatar
Quoted: 2 Post(s)
according to my manuals its a none repairable hose . so you would have to find a whole new/good used fuel rail assembly . i wouldnt take a chance catching my ram on fire .
1999 RAM 1500SPORT QC 4X4 5.9 3.55's grrrr
360 MAGNUM POWER 165,000 MILES DYNOED 230/290 ON 35'S
1.7 CRANE ROLLER ROCKERS
DIY CUT,PORTED,EPOXY FILLED KEGGER/ALUMINUM PLENUM PLATE,53MM THROTTLE BODY
JACOBS PRO STREET CD IGNITION
BOSCH DESIGN 3'S 24LBS VETTE INJECTORS
MOPAR P DOUG THORLEY TRI-Y'S
TAYLOR 8.2 THUNDERVOLT WIRE'S
EBC ROTORS N PADS,RUSSELL SS BRAKE HOSES
MARCH UNDERDRIVE CRANK PULLEY
1 TON X-OVER STEERING
DT PRO-FAB TRAC BAR
HELL BENT STEEL 2IN SPACER/SKJ LCA
WINNDEKAR/DSS STEERING BRACE
DODGEPICKUP is offline
post #6 of 12 Old 12-04-2008, 07:35 PM
parks9
parks9's Avatar
i wish that i would have known before i tried to replace it, and i can see why its a non replaceable hose!! haha
5.9
163,000
flowmaster
k&n filter
leveling blocks
parks9 is offline
post #7 of 12 Old 12-04-2008, 09:51 PM Thread Starter
ontos
Thanks, I was afraid of that.
How big a job to replace the fuel rail assembly when I get a new assembly? Thanks any info.
ontos is offline
post #8 of 12 Old 12-04-2008, 11:07 PM
parks9
parks9's Avatar
i dont know all of what you would need to do, i was replacing head gaskets when i did all of this, so i dont know what you do and dont need to take off to replace it. cuz replacing the head gaskets requires stripping everything to tear the motor down.. lol
5.9
163,000
flowmaster
k&n filter
leveling blocks
parks9 is offline
post #9 of 12 Old 12-05-2008, 01:39 AM
DODGEPICKUP
Quoted: 2 Post(s)
not a big job at all , about an hours work ON A COLD ENGINE . you will need a fuel line disconnect tool and basic hand tools . relieve fuel pressure before removing the fuel line from rail . before you switch injectors over this is a great time to replace the O-rings on the injectors . if you use the fel-pro O-rings you will need 4 packages as one only services 2 injectors . lightly coat O-rings with oil before installing in rail or manifold . GOOD LUCK .
DT PRO-FAB TRAC BAR
post #10 of 12 Old 12-05-2008, 03:29 AM
madmikeismad
R.I.P Big Blue
madmikeismad's Avatar
Quoted: 109 Post(s)
parks9, you deserve a beer , you could have just saved a dodge's life.
Mike Hill
Purple People Eater - 98 12v - Maybe 800whp on old block:
The Race Truck
01 Ram 1500 Sport 4x4 5.9 (RIP Big Blue
madmikeismad is offline
post #11 of 12 Old 12-06-2008, 02:24 PM
parks9
parks9's Avatar
ill take a couple... i wouldnt want ONTOS to go through what i did, and thats to watch your pride and joy burn.. It was miserable.
5.9
163,000
flowmaster
k&n filter
leveling blocks
parks9 is offline
post #12 of 12 Old 12-06-2008, 05:02 PM Thread Starter
ontos
Thanks for alll the good advice and info. I got lucky in that I checked for the source of gasoline smell, and also that I was able to see where it was leaking. The good advice posts about not driving it also helped me to not be me and drive it a while......
Sending it out to a local repair place with Dodge experience. Too cold for "shade tree" soloution. Shop said it's not uncommon. That's scary.
Thanks again for good response.
ontos is offline
    front fuel rail O ring leak 91.. 91AWD3.3 Dodge Caravan General Talk 1 08-14-2008 11:03 PM
    Engine Error Codes? tigerbob63 1G Dodge Durango General Talk 10 07-23-2008 08:24 AM
    1998 24v diesel seems weak joshuafiscus 2G Dodge Ram Diesel Talk 3 01-27-2007 09:47 PM
    Where to find Engine Codes doug_mi 1G Dodge Durango General Talk 15 08-22-2005 08:14 AM
    P0601 Error jgonick 1G Dodge Durango Performance Talk 7 06-11-2004 01:33 AM
