code p1762 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 11-16-2008, 05:47 PM Thread Starter
chode
chode's Avatar
code p1762
check engin light is on and i had it checked at autozone they told me it was 1 internal trasnmission failure or 2 open or shorted circut condition im hopeing it is an open circut som question is where do i start looking my truck is a 98 qc 4x4 360 any help would be awesome, this is my everyday driver so i cant be without it
98 ram qc 4x4 360 with .30 overbore everything els stock 86 ram d150 with a bad 318 and in the carhold a 67 plymouth satilite 383 b&m slap shifter with 4.10 rear gears blue truck #195
chode is offline
post #2 of 11 Old 11-16-2008, 06:07 PM
osprey
You have a governor pressure sensor problem. IIRC, the sensor itself is about $60, and relatively easy to replace (compared to a full transmission rebuild). When mine went out, I took ot to a reliable transmission shop, and the total cost was in the $250 to $300 USD range here in Phoenix, Arizona. This included a new pan gasket and fluid replacement.
Usual symtoms of this problem are sluggish acceleration due to the transmission starting out in drive in "limp home" mode. Eventually, if it is not repaired soon, you will only have first gear and reverse.
As far as doing the repair yourself, I am not sure about this. You might want to search under this code, or (hopefully) Tactransman will see this thread and respond with his vast knowledge and expertise on Dodge Ram transmissions.
Hope this helps.
With everybody else asking for a bailout, let me ask, "Where is the taxpayer's bailout ?"
osprey is offline
post #3 of 11 Old 11-16-2008, 07:09 PM Thread Starter
chode
chode's Avatar
that does help i will call around monday thanks
chode is offline
post #4 of 11 Old 11-16-2008, 10:34 PM
tactransman
Transmission Man!
tactransman's Avatar
You can change the GP sensor easily. It is as simple as dropping the pan. I would replace the GP solenoid as well though while you are in there.
Here is some helpful info: http://dodgeram.info/tsb/recalls/Notice690.htm
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #5 of 11 Old 11-17-2008, 07:02 PM Thread Starter
chode
chode's Avatar
i would like to do it myself but i am a little nervious, i think i can do it, any special tolls i will need to do right?
chode is offline
post #6 of 11 Old 11-18-2008, 09:47 AM
tactransman
Transmission Man!
A 25 torx bit.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #7 of 11 Old 11-18-2008, 05:48 PM Thread Starter
chode
chode's Avatar
im sure i have that, can you tell me what parts i will have to buy, like parts number and stuff like that and how long do you think it will take me thanks for the info
chode is offline
post #8 of 11 Old 11-18-2008, 10:52 PM
tactransman
Transmission Man!
Solenoid
http://www.transmissionpartsusa.com/...-000053396.htm
sensor
http://www.transmissionpartsusa.com/...-000053397.htm
I always use this filter instead of the original black plastic style(you have to remove and use the third bolt not used with the original)
http://www.transmissionpartsusa.com/...-000054926.htm
Pan gasket if you do not have a reusable original one.
http://www.transmissionpartsusa.com/...-000054140.htm
Around $107 for all of it.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #9 of 11 Old 11-18-2008, 11:01 PM Thread Starter
chode
chode's Avatar
thinks alot i appreciate all your help
chode is offline
post #10 of 11 Old 11-18-2008, 11:05 PM Thread Starter
chode
chode's Avatar
just 1 sensor and 1 solenoid?
chode is offline
post #11 of 11 Old 11-18-2008, 11:09 PM Thread Starter
chode
chode's Avatar
is there anything else i should do while im in there
chode is offline
    Trouble codes for neons 95-99 dodgeneonACR98 Dodge Neon - General Talk 87 02-25-2008 01:15 PM
    98 Caravan 3.3L "Haunted" - Electrical problems daberguson Dodge Caravan General Talk 11 12-22-2007 03:48 AM
    Trouble Codes for 96-97 Caravans Jmw132001 3rd Gen Caravan Talk (96-00) 0 05-18-2006 10:54 PM
    How to decode the VIN flattop 3G Dodge RAM Diesel Talk 9 03-23-2005 10:25 PM
