Odd Tire Wear - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 53 Old 11-16-2008, 02:25 PM Thread Starter
audiomechanic
I R SMRAT.
Odd Tire Wear
Hello once again everyone. I was leaving the haircut place today (looking very pretty I might add ) and noticed some odd wear on my front tires.
Here's the front driver's side tire. Notice on the inner row of tread, every other "knob" of the tread is flatter than the one next to it.
Here's the passenger side doing the same thing:
I also noticed that the two front wheels are sitting slightly tilted:
I don't get this. I know my wheels are spaced outward, but the wheel bearings are new, the tie rods are new, the upper ball joints are new, and the shop that did the ball joints said the lower were fine. All of this has been done in the past 10,000 miles or so. Nothing should be worn out yet. Also, the truck tracks straight and the steering is tight.
I bet it's a good idea if I rotate the tires so the fronts don't get any worse, but it seems the same will happen to the rears once they're moved up.
Any idears?
Proud Owner Of the "SPORT BEAST"
Can't Lay a Scratch Member #1!
1999 Dodge Ram 1500 Sport 4X4 5.9L
Bought at 93,000 miles. Repairs to date:
-Rebuilt tranny and installed aftermarket tranny cooler
-Fixed exhaust leak
-Replaced drivers side tie rod, Lukes Linked the rest (including trac bar)
-Replaced Both wheel bearing hubs
-Replaced front u-joints
-Replaced power steering pump
-Replaced passenger side brake hose
-Replaced upper ball joints
-Replaced ALL fluids front to back
-Installed Maxxis Buckshot 33X12.50's
-Rewired bootlegged stereo
-Tune-Up including Sea Foaming intake, gas, crank case
-Replaced brake pads
-Replaced front sway bar bushing with Energy Bushings
-Replaced shocks with Bilstein 5100's
-replace AIC
-replace TPS
-Relocated AIT Sensor to air hat
-Modded CPS bracket to advance timing about 4*
-Changed plugs over to Autolites
-Replaced water pump
-Replaced plenum gasket
-Modded kegger and TB
- replaced driver's side wheel bearing hub (again)
audiomechanic is offline
post #2 of 53 Old 11-16-2008, 02:38 PM
NHRam
Layin' Low
NHRam's Avatar
I say have the alignment re-checked/done. That looks like some toe out wear.
BAGGED '04 RAM 1500 HEMI
Low and on 24's
DAILY DRIVER
2008 Electric Blue Quad Cab Dakota
4x4 4.7 V8
Jan. 2005 Truck of the Month...Thanks to everyone who voted!
Red Truck Club Member #7
Previous Rams
1998 QC 4x4
1997 CC 4x4
NHRam is offline
post #3 of 53 Old 11-16-2008, 02:44 PM Thread Starter
audiomechanic
I R SMRAT.
Well, that stinks cause the 4X4's don't have a toe adjustment. Just parts to replace. Maybe the lower ball joints weren't are good as the shop said.
-Fixed exhaust leak
-replace AIC
-replace TPS
post #4 of 53 Old 11-16-2008, 03:24 PM
DODGEPICKUP
DODGEPICKUP's Avatar
Quoted: 2 Post(s)
what psi are you running ? you have a lift with lower control arm's ? this is a good read if you haven't allready .
http://dodgeram.org/tech/specs/00_steer_specs.html
1999 RAM 1500SPORT QC 4X4 5.9 3.55's grrrr
360 MAGNUM POWER 165,000 MILES DYNOED 230/290 ON 35'S
1.7 CRANE ROLLER ROCKERS
DIY CUT,PORTED,EPOXY FILLED KEGGER/ALUMINUM PLENUM PLATE,53MM THROTTLE BODY
JACOBS PRO STREET CD IGNITION
BOSCH DESIGN 3'S 24LBS VETTE INJECTORS
MOPAR P DOUG THORLEY TRI-Y'S
TAYLOR 8.2 THUNDERVOLT WIRE'S
EBC ROTORS N PADS,RUSSELL SS BRAKE HOSES
MARCH UNDERDRIVE CRANK PULLEY
1 TON X-OVER STEERING
DT PRO-FAB TRAC BAR
HELL BENT STEEL 2IN SPACER/SKJ LCA
WINNDEKAR/DSS STEERING BRACE
DODGEPICKUP is offline
post #5 of 53 Old 11-16-2008, 03:30 PM Thread Starter
audiomechanic
I R SMRAT.
Running about 36 PSI. The truck calls for 44 PSI on the door sticker but max sidewall pressure on the tires is 35. I didn't want to exceed that by much.
Also, yes, the lift came with lower control arms. I don't have a pic of them right now, but can get one if you wish.
Thanks for the link! It's like chinese to me. I suck when it comes to alignment stuff and angles and all that. Gonna read it anyway.
-Fixed exhaust leak
-replace AIC
-replace TPS
post #6 of 53 Old 11-16-2008, 03:47 PM
DODGEPICKUP
Quoted: 2 Post(s)
chinese lol to funny.......your tires only call for 35psi at max load ? that seems low for a 16in tire . what size are they ?
DT PRO-FAB TRAC BAR
post #7 of 53 Old 11-16-2008, 04:32 PM
NHRam
Layin' Low
NHRam's Avatar
who told you that??? Every vehicle has at least a front toe adjustment.
Low and on 24's
DAILY DRIVER
4x4 4.7 V8
Previous Rams
1998 QC 4x4
1997 CC 4x4
NHRam is offline
post #8 of 53 Old 11-16-2008, 07:17 PM Thread Starter
audiomechanic
I R SMRAT.
Side of the tires says "35PSI MAX sidewall pressure." They are 33X12.50's. Brand is Maxxis Buckshot Mudder
Unless I missed something while I was in there the last time. The upper and lower ball joints mount to a solid knuckle and also to a solid front axle. No place to adjust that I saw.
-Fixed exhaust leak
-replace AIC
-replace TPS
post #9 of 53 Old 11-16-2008, 07:21 PM
hemi22xx
Mopar or no car!
hemi22xx's Avatar
Tie rods...?
12' Ram 1500 Hemi Sport
RCX 6" lift - Bilsteins all 4 corners(front set at 2.8) - TGC 1.75" Rear spacer - Fuel hostage chrome 20x10 -24 - Nitto mud grappler 37x13.5x20 - NFAB wheel to wheel - flowmaster - 5000k HID headlight & fog light.
Recent vehicles
2010 Challenger RT B5 blue 6-speed
2003 Ram 1500 RC black hemi sport (Old Moes performance truck)
2006 Ram 1500 RC black hemi sport
2005 Ram 1500 RC black hemi sport (My baby, sure miss this one)
hemi22xx is offline
post #10 of 53 Old 11-16-2008, 07:44 PM
DODGEPICKUP
Quoted: 2 Post(s)
35 max then i would air down to 30psi or more 2. maxload is max payload and i dont think you drive around with 1000lbs in the bed . i run 40psi in front 35 in rear but max psi is 65 . air down see how she drive's .
camber is not adjustable on are trucks only toe and caster .
did you read any of that article . basically it's saying to check the lower arm's cambolts to see if there pionting in same direction .
DT PRO-FAB TRAC BAR
post #11 of 53 Old 11-16-2008, 07:53 PM
almighty_ed
mine too
I had the same thing happen to mine. The alignment shop told me it was probably a suspension component but eveything was either new or in good shape. I went through everything. I never found a solution. Inflating my tires to 42psi helped a little. I believe it has to be the wider rims screwing up the steering angle or the wider rims caused the upper knuckle to bend inward slightly. You can get adjustable upper ball joints from O'Reilly's. I think Moog makes them. I'm going to give them a try when I tear it down for a major overhaul.
White '98 Ram Quad 4x4:
Hpertech PTM
Holley 52mm TB
K&N FIPK
JBA shorty's
TransGo TFOD-JR
3" susp lift
33" Cepeks
2500 watts of bone-crushing "FOSGATE POWER"
CUM ON FEEL THE NOISE
almighty_ed is offline
post #12 of 53 Old 11-16-2008, 08:00 PM Thread Starter
audiomechanic
I R SMRAT.
I will definitely check them in the morning. I know the cam bolts of which you speak.
What about how both front tires are tilted inwards slightly (can be seen in the pics). Is that camber? I thought the cam bolt adjusted caster.
Thanks for the help so far , Dodgepickup! This is why you're my hero.
-Fixed exhaust leak
-replace AIC
-replace TPS
post #13 of 53 Old 11-16-2008, 08:19 PM
DODGEPICKUP
Quoted: 2 Post(s)
not a hero just owned two 2GEN ram both 4x4 and i have had every problem at one time or another .
thats why i asked about lower control arms . are they adjustable ? need to be longer to swing axle back to spec . also need an adjustable trac-bar to re-center axle under the truck . they say we dont need a trac-bar for a 3in lift but we really do . stock trac-bar is made for stock height .
brb the fan on my cpu just took a dump on me . ROAD TRIP TO FRY'S
DT PRO-FAB TRAC BAR
post #14 of 53 Old 11-16-2008, 08:47 PM Thread Starter
audiomechanic
I R SMRAT.
I love Fry's.
Far as I know, the only adjustment on the control arms is the cam bolts. They are aftermarket parts of the lift, but they're solid chunks.
Almighty_ed above made a good point about the wheels. They do have quite a bit of backspacing (or maybe it's quite a little...can't remember). Anyway, they stick out dern far. That, I'm sure, is very hard on the balljoints/wheelbearings.
I'll get pics of the control arms as well as the cam bolt settings and post 'em up.
Have fun at Fry's!
-Fixed exhaust leak
-replace AIC
-replace TPS
post #15 of 53 Old 11-17-2008, 11:04 AM Thread Starter
audiomechanic
I R SMRAT.
Ok, got some more pics. YAY PICS!!!!
Just for comparison sake, here's my driver's side rear tire. This is how the fronts SHOULD look.
Here's a pics of the sidewall pressure text:
Here's the driver's side control arms (passenger side is the same...obviously ):
Here's the driver's side cam bolt setting:
And the passenger side setting:
I have no idea how to read those cam bolts. Hopefully they're in spec as the 4X4 shop that did the alignment and replaced the upper ball joints should have set these.
If y'all need anymore pics, I'd be happy to snap whatever y'all need....except my beautiful wife....thos pics stay with me.
EDIT: after I made the last post, I got out the ol' hydraulic jack and lifted the front end. I checked the front wheels for play up/down and side/side. The wheels are tight. Especially up/down. Can't move 'em, at least with my own strength (which ain't sayin much...I'm pretty sure a girlscout could move the wheels more than me. ). I also aired down the front tires to 32PSI. Gonna see what happens now.
-Fixed exhaust leak
-replace AIC
-replace TPS
post #16 of 53 Old 11-17-2008, 11:54 AM
DODGEPICKUP
Quoted: 2 Post(s)
AUDIO.......air down them tires . you should never air up past the max psi . remember the air pressure will raise when the tires get warmer . i would try 30psi in front and 25 in rear .
i think you posted two pics of the drivers side . drivers arm should be running off pic to the right and the pass side should be running off the left . and the strategic placement of the pine needles .
your no funnnnn . hot bikini pics was gonna be my first request (next to the truck of course)
DT PRO-FAB TRAC BAR
post #17 of 53 Old 11-17-2008, 11:56 AM Thread Starter
audiomechanic
I R SMRAT.
I aired the fronts down to 32.
OH SNAP! I did post two pics of the driver's side. Hold on....
<---doofus
Here's the passenger side:
-Fixed exhaust leak
-replace AIC
-replace TPS
post #18 of 53 Old 11-17-2008, 11:58 AM Thread Starter
audiomechanic
I R SMRAT.
I fixed my first post. *embarrassed*
It's also funny that you mention the bikini pics cause she really wants to pose next to my truck in her leather bikini. ***HOT!***
-Fixed exhaust leak
-replace AIC
-replace TPS
post #19 of 53 Old 11-17-2008, 12:19 PM
DODGEPICKUP
Quoted: 2 Post(s)
knuckle head .....just as i thought all shops do this cause they dont aline dodge 4x4's . your cam bolts are pointing in opposite direction . this puts an off -set in the axle (one tire further in front of the other) . so your just like mine was the drivers side is sitting further back .
on mine i just loosened the drivers cambolt and moved it forward to match up with the otherside . you should try the same and look at the tilt of the tire see if it inproves . NOW WHEN YOU MOVE THE BOLT your toe (tires pointing straight )will be off .
I GOT DIBS ON THE FIRST HOTTTTTTTT LEATHER BIKINI PICS
DT PRO-FAB TRAC BAR
post #20 of 53 Old 11-17-2008, 12:23 PM Thread Starter
audiomechanic
I R SMRAT.
Can I do this with the truck sitting on the ground? Or do i need to get it in the air?
The shop that did the alignment was 4 Wheels Parts! They're a 4X4 shop! They should have gotten this right.
And I'll keep you in mind for the bikini pic.
Here's a teaser though:
-Fixed exhaust leak
-replace AIC
-replace TPS
    Spare Tire 01_OffRoad 2G Dodge RAM - 4X4 Talk 24 06-26-2006 12:22 AM
    Tire Pressure - Who's Right? w5blt Dodge Magnum - General Talk 13 07-29-2005 03:09 PM
    Warning if you have a flat tire MrMike Dodge Magnum - General Talk 11 07-16-2005 07:34 PM
    Tire pressures........ patryn 1G Dodge Durango General Talk 20 06-29-2005 10:03 AM
    tire wear MARLIN FAN 2G Dodge RAM - 4X4 Talk 3 06-12-2003 11:48 AM
