Transmission(engine) removal 4.7 -45RE - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 11-10-2008, 09:29 AM Thread Starter
Mark1500
Hello, I am actually in the process of changing motors, sludge got this one, and I am stumped as to how to get to the upper most bolts on the bell housing. There does not seem to be enough room to get to the upper 4 bolts. Any advice would be appreciated. Thanks
Mark1500 is offline
post #2 of 5 Old 11-10-2008, 09:37 AM
tactransman
Transmission Man!
tactransman's Avatar
Usually ,you let the transmission hang down (with the crossmember removed) and you can get to them with a 36 inch long 1/2 extension.
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #3 of 5 Old 11-10-2008, 10:31 AM Thread Starter
Mark1500
Thanks tactransman it is a 4x4, so do I need to remove the drive shafts before lowering the trans?
Mark1500 is offline
post #4 of 5 Old 11-10-2008, 10:33 AM
tactransman
Transmission Man!
You shouldn't have to.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #5 of 5 Old 11-10-2008, 06:10 PM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
but you will eventually
New: 2005 Dodge Ram 1500 QCSB 4x4 Hemi Laramie Bright Silver
Flowmaster SI/DO 40 Series. Superchips 3865 - 91 Tune, 2/4 drop, More to come............
::GONE BUT NOT FORGOTTEN::2005 Dodge Ram 1500 QCSB 4x4 Hemi Sport Black
5.5" Rough Country Lift, Dick Cepek DC2 20x9, 325/60R20 Nitto Terra Grappler's, Superchips 3865 - 91 Tune, Extang Tonneau Cover, K&N Cold Air Intake, Bosch Platinum 4 plugs, Magnaflow Y-Pipe, SI/DO Flowmaster Original 40 Series, Synthetic Everything, 7000K Headlights, Foglights and Hellas..
1998 Dodge Durango SLT 4x4 Black
Hypertech 87 Tune, K&N Cold Air Intake, Bosch Platinum 4 plugs, Bosch 8.5mm Wires. Ported Throttle Body, SI/DO Flowmaster Original 40 Series Muffler, Headman Headers, 3" PA BL, 2" T/S Lift, 33x12.50R15 Firestone Destination M/T's, 15x8 Eagle Alloy Wheels.
BTC Member 211 - Steel Reserve
!05RAM05! is offline
    3G 4.7 vs. 2G 4.7 theduker25 3G Dodge Dakota General Talk 15 03-07-2008 01:14 PM
    303 HP in a 4.7 2000durangoslt 1G Dodge Durango General Talk 18 01-28-2008 10:32 PM
    4.7 Fan cluth & CAT removal 1MIKE1 3G Dodge RAM - General Talk 5 12-04-2003 06:58 PM
    Hemi 4.7 vs Reg 4.7 silencer_ 3G Dodge RAM - General Talk 7 10-27-2003 01:40 AM
