2000 Stratus, Heater Box? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 04-14-2004, 11:06 PM Thread Starter
lelajude
Question 2000 Stratus, Heater Box?
I have a 2000 Dodge Stratus and was recently told by the dealer that my A/C is not blowing cold air due to a cracked heater box. The heat works just fine. I was also told it would cost $1000 to fix it ! Of course I told them to forget it. I have been doing some research online and am trying to figure out if the heater box and heater core the same thing? Also if someone can give me some advice as to how much this part costs and any other information that would be great. Of course I am a woman and have no clue! Thank you for your time.
lelajude is offline
post #2 of 7 Old 04-15-2004, 03:37 PM
LB3711
Moose
LB3711's Avatar
Quoted: 68 Post(s)
heater box and heater core are the same thing just a different name. Does the fan blow on all fan speeds? I dont have a 2000 so I'm not sure whats involved in a heater core changeout
2011 Dodge Ram 1500 Hemi QC 4x4
2001 Dodge Stratus ES 4Dr. 2.7L Magnum DOHC V6. SOLD
2002 Dodge Durango SLT 4Dr. 4.7L Magnum V8. SOLD
Proud Member of The Original WCPW
LB3711 is offline
post #3 of 7 Old 04-15-2004, 09:54 PM Thread Starter
lelajude
Wink
Its funny that you asked me that because just recently it was only blowing out if it was turned all the way up. I just had some work done at the dealer that was under extended warranty and they told me they had to replace the blower motor and thats why it was only blowing out if it was turned on high but according to them the a/c problem comes from a cracked heater box that is not under warranty. I did try the a/c just for the heck of it after they replaced the blower motor and it still does not work. Thank you so much for you help.
lelajude is offline
post #4 of 7 Old 04-19-2004, 07:58 PM
LB3711
Moose
LB3711's Avatar
Quoted: 68 Post(s)
Maybe they forgot to charge the AC or there is a leak somewhere.
LB3711 is offline
post #5 of 7 Old 04-27-2004, 05:37 AM
gabbledak
i think that she/you should first check to see if your compressor is turning on when you turn on the a/c. if the compressor isn't turning on then it could be a series of things.
The a/c wasn't working in my 96 stratus and it was holding pressure fine and it ended up being a sensor on the high pressure end of the a/c line.
also if the compressor isn't turning on then it might be a leak in the system like lb3711 said, and quite possibly be near or at the heater core/box.
gabbledak is offline
post #6 of 7 Old 10-06-2004, 10:31 PM
POSstratus
okay my problem, is a/c will turn on (i can hear ther click) will not blow on low or meddium settings, only on high does any one know how to fix?
POSstratus is offline
post #7 of 7 Old 10-07-2004, 02:03 PM
rkfsm
rkfsm's Avatar
Blower motor resistor. It's an incredibly common problem. Easy to replace with one each phillips and flatblade screw driver and a socket set, and it only costs about $20 for the part. If you need instructions/diagrams/pictures/schematics, let me know. The hardest part is finding someplace to put all the stuff in your glove box while you do this.
RK
rkfsm is offline
