Thread Tools |
Crazy Speedometer
- Posted: 11-06-2008, 12:27 PM
Post #1
ok well about a week ago my speedometer started going CRAZY!!! once I get above 30-35 or so it starts jumping around and it seems that the faster I go the more it jumps. ie. i was going aprox. 45-50mph and it was jumping all the way up to 70+ and them back down and immediately up again. so basically it jumps way around. whats the cause??? just gone bad???
Thanks, Dan
1991 Dodge W150 Power Ram 360ci 37" Interco M16 Mud Tires 4.56 gears 3" body lift 4" Rough Country suspension Lift |
| Sponsored Links | |
Advertisement |
Posted: 11-07-2008, 07:55 AM
Post #2
91 won't have a cable...it's electronic. There is a speed sensor that goes into the transmission at the tailshaft....sounds like this is your problem.
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Member of: Old Line Vanners Interstellar Space Truckers SouthEast Van Council A-100 Van Association Honorary Canadian as bestowed upon me by Van Clan plus One
Posted: 11-07-2008, 08:43 AM
Post #3
hmmmm don't know anything about it. you don't think it could be the actual speedo do you? I'm just trying to rule things out.
Thanks, Dan
Posted: 11-07-2008, 09:27 PM
Post #4
Sounds like the speedsensor to me to, a common problem 38 dollar part.You can check it with a digtalmeter
mr.318 |
Posted: 11-08-2008, 07:33 AM
Post #5
ok well in that case could you tell me where exactly it is? and how to get to it?
Thanks, Dan
Posted: 11-08-2008, 02:49 PM
Post #6
i have been in a few forums and most agree that a repair manual is the most important tool you can own. if you can't get one ,they might have one at the library. they have pics of where the parts are located.
Posted: 11-08-2008, 03:46 PM
Post #7
yeah i've got a haynes manual i'll check it out
Posted: 11-08-2008, 03:55 PM
Post #8
do you guys think its the speedometer cable that needs fixing or is that something else aside from the speedo sensor
Posted: 11-16-2008, 05:55 PM
Post #9
yea either the connection is bad or the sensor
360 8 pack |
Posted: 11-17-2008, 07:29 AM
Post #10
www.autobooksbishko.com get a factory service manual. It will pay for itself many times over.
Posted: 11-20-2008, 06:36 PM
Post #11
There is no cable. It is electronic.
The speedometer gear inside the cluster likes to go bad on these trucks, too. Check the speed sensor on the tail shaft. If it checks out, your speedometer gear would be the next thing to suspect. There's a place who sells them that's been posted before. I'll try and find a link.
'91 Dodge Ram LE - 5.2L, auto, loaded '04 Chevy Silverado ECSB - 5.3L, 4L60-E, 3.73's Past rides: '70 Charger R/T - 440, PS, PB, A/C, 1 of 328 EB7 cars '67 Chevy C-10 - 454, TH-350, 12 bolt, 4/6 drop '66 Chevy C-20 - 350, 4-speed, long/step |
Posted: 11-26-2008, 09:23 PM
Post #12
I've had a similiar problem with the plastic gear on the end of the speedo cable not being adjusted right. I swapped a A999 in my `88, outside, laying on ice and snow and didn't the gear lined up just right. (It's hard to get the right 'feel' for a job when you can't feel your hands anymore.) For me, it's meant getting another gear from the scrapyard... but I waited until spring. I've seen similar gear in my 727 out of my 1968 Dodge, but can't say what is in anything newer then `88.
Posted: 11-26-2008, 11:55 PM
Post #13
yeah i have to check a few more connections but i don't have a cable. mines a 91 which means its electronic
but thanks for the infoDan
Posted: 11-27-2008, 07:54 AM
Post #14
I'm just taking a guess in the dark. Could this electronic setup be nothing more
then a sensor instead of a cable hooked up to the same type plastic gear? ![]() Dodge / Jeep 2WD / 4WD Speedometer Gears These gears are used with most Jeep and Dodge truck electronic speed sensors for the speedometer. You can increase or decrease the number of teeth depending on tire size to make your speedometer more accurate. The drive gear has 13 teeth and is machined into the output shaft. These are the late model type with a short shaft. Comes in 28 tooth to 43 tooth. Cost $65.00. Source: http://www.transmissioncenter.net/dodge.htm If what they're saying here is true, my `88 used a cable, so sometime after that, they hooked up an electronic speed sensor instead. I've also looked and the same 'type' of transmissions were used past `88... so maybe mechanically it isn't so different (used the plastic gear) but the wiring and electronics changed? Anyways, this was the 'mechanical' problem that produced my bouncing speedometer. |
Speed sensor
- Posted: 12-13-2008, 10:19 PM
Post #15
I have a similar problem with mine I think it either has to be the speed sensor going out or maybe the teeth are stripped on the sensor
Posted: 12-13-2008, 10:55 PM
Post #16
uhhh weird enough I just unplugged the connector at the trans and made sure it was clean and it hasn't bounced since. lol I don't know but maybe just dirty??
Thanks for the help, Dan
Posted: 12-14-2008, 12:18 AM
Post #17
yeah I dont know mine would work and then not, bounce and then quit, now it doesnt work at all
Posted: 12-14-2008, 09:27 AM
Post #18
hmmm i'm ust not sure maybe its the cable? if its mechanical or maybe its a gear on the electrical ones
Posted: 12-14-2008, 06:59 PM
Post #19
checked it today broke the end off the drive on the sensor wierd huh
Posted: 12-14-2008, 07:09 PM
Post #20
yeah that's no good man sounds like you have some replacing to do...
| Thread Tools | |
| alright go crazy with it | geterdone04 | Concept/Modified Vehicle Talk | 3 | 01-07-2007 02:02 PM |
| crazy larry | dirtydiesel04 | 3G Dodge Ram Performance Talk | 0 | 12-17-2006 11:16 PM |
| Bad drivers or a factory freak???? | bristo_me_quik | 3G Dodge RAM - General Talk | 24 | 06-14-2005 07:43 AM |
| Got bored - PICTURES | Grant211 | 3G Dodge RAM - General Talk | 42 | 04-22-2005 07:43 AM |
Privacy Statement | |
