TV cable adjustment - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 11-01-2008, 09:51 PM Thread Starter
bmiller2aw0
TV cable adjustment
Can some one tell me the correct wat to adjust the TV cable and will this effect shit points,
Thanks in advance
Bob M
bmiller2aw0 is offline
post #2 of 11 Old 11-01-2008, 10:48 PM
LoudRam
Redneck Yankee
LoudRam's Avatar
Right here. And yes it will affect your shift points. A little adjustment goes a long way, in other words...less is more when adjusting the TV cable.
http://www.dodgetalk.com/forums/show...ighlight=cable
Post #5
-Todd
Desert Storm Vet/ US Navy
'01 Ram 1500 SLT Laramie 4x4 Quad Cab Debadged, 360 cubic inches of pure American muscle.
Performance Mods:Hypertech Power Programmer III, TB: Fins cut, ported and polished Intake: Ported and polished, runners cut down 5/8", 180 T-stat, Edelbrock Pro-Flo 1002, Magnaflow high flow cat and 3"SI/2.5"DO exhaust w/ 3" polished stainless tips, Plenum repaired w/ Hughes kit
Appearance Mods: Eagle wheels 16x8, 33" Toyo Open Country AT's (285/75), Diamond Back headlights w/Silverstar lamps, Aluminum billet grill, Lund moonvisor, Black tube step bars, Bulldog keyless entry, Westin ultimate bull bar w/2 Baja 55w off road lights w/HID lamps
We contribute nothing to our salvation except the sin from which we need to be redeemed. – William Temple (English diplomat & author)
Proud Member of the God Squad 1992
LoudRam is offline
post #3 of 11 Old 11-02-2008, 12:08 AM
audiomechanic
I R SMRAT.
Originally Posted by bmiller2aw0 View Post
...and will this effect shit points
I adjusted my TV cable a while back but it never effected THOSE points! Beans and jalapenos usually do that.
Just given you crap, man. And what Wirenutt said is correct, less is more. The clip that holds the adjustment in place is grooved. Try moving the cable one 'click' at a time and then go for a drive. A small tightening of the cable (moving the adjustment towards the firewall) from the stock setting, will make for later, firmer shifts but is actually beneficial for the life of the transmission. Firmer shifts=longer lasting tranny.
Proud Owner Of the "SPORT BEAST"
Can't Lay a Scratch Member #1!
1999 Dodge Ram 1500 Sport 4X4 5.9L
Bought at 93,000 miles. Repairs to date:
-Rebuilt tranny and installed aftermarket tranny cooler
-Fixed exhaust leak
-Replaced drivers side tie rod, Lukes Linked the rest (including trac bar)
-Replaced Both wheel bearing hubs
-Replaced front u-joints
-Replaced power steering pump
-Replaced passenger side brake hose
-Replaced upper ball joints
-Replaced ALL fluids front to back
-Installed Maxxis Buckshot 33X12.50's
-Rewired bootlegged stereo
-Tune-Up including Sea Foaming intake, gas, crank case
-Replaced brake pads
-Replaced front sway bar bushing with Energy Bushings
-Replaced shocks with Bilstein 5100's
-replace AIC
-replace TPS
-Relocated AIT Sensor to air hat
-Modded CPS bracket to advance timing about 4*
-Changed plugs over to Autolites
-Replaced water pump
-Replaced plenum gasket
-Modded kegger and TB
- replaced driver's side wheel bearing hub (again)
audiomechanic is offline
post #4 of 11 Old 11-02-2008, 09:06 AM
charlie1935
charlie1935's Avatar
Quoted: 6 Post(s)
Thanks in advance
Bob M
Polish sausage and sour kraut works wonders!
Grouchy Old Man
Sport short bed
R&S Automotive cat back duals
SSBC slotted rotors
Tri wing tonneau cover
Ultra 50/51 16x10 wheels
265 70x16 Firestone Destination LE tires
3.55 rear
99-01 sport headlights with Silverstar bulbs
MSD coil
Fram Boost intake -Freebie. I won it
Edelbrock shocks
Yes, grandpas like toys too
87 D100 318 auto. stock
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist'
charlie1935 is offline
post #5 of 11 Old 01-12-2009, 09:52 PM
Lee Peterson
Lee Peterson's Avatar
Quoted: 4 Post(s)
Hello Everyone!
I was just wonder at what rpm are you guys shifting into 2nd? With just slowly picking up speed.
2002 Dodge Ram 1500 4x4.
360 Magnum
Hughes FI Air Gap
52mm BBK TB
210/220 .512I.512E 110 LSA cam
MSD 6A , Blaster 2 Coil
Spintech muffler
SCT tuned by FlyinRyan
Trucks & Guns Club Member #88
Lee Peterson is offline
post #6 of 11 Old 01-12-2009, 10:47 PM
madmikeismad
R.I.P Big Blue
madmikeismad's Avatar
Quoted: 109 Post(s)
Heck if I'm going real slow, it shifts at 1200 into 2nd, and 1200 into 3rd, and about 1500 OD.
And make sure it isn't too cold when messing with that clip, it could snap off like mine did.
Mike Hill
Purple People Eater - 98 12v - Maybe 800whp on old block:
The Race Truck
01 Ram 1500 Sport 4x4 5.9 (RIP Big Blue
madmikeismad is offline
post #7 of 11 Old 01-12-2009, 11:27 PM
96Sport
46re(tarded)
96Sport's Avatar
I yanked mine out a good bit to help that little 318 with the 3.55's to accelerate better without putting my foot in it more. Shifts about 2,200 babying it, 2500 normal accel, 3,000 if i take off with a little more boot. You wouldnt believe how much better the truck takes off requiring less throttle when you do this. Just be aware of the 2-3rd gear hunt the truck will do sometimes if you adjust yours to the extent i did.
1996 5.2 4x4
-Airaid Intake
-Summit 3 inch duals/Magnaflow SIDO muffler
-2" spacer with 33's
-B&M Trans cooler
-4.56's and track-lock
96Sport is offline
post #8 of 11 Old 01-12-2009, 11:32 PM
Lee Peterson
Quoted: 4 Post(s)
I had mine setup the same. I just adjusted it now shes fine I hated the hunting.
360 Magnum
Hughes FI Air Gap
52mm BBK TB
Spintech muffler
post #9 of 11 Old 01-12-2009, 11:41 PM
96Sport
46re(tarded)
96Sport's Avatar
How many teeth did you end up dropping it down?
1996 5.2 4x4
-Airaid Intake
-B&M Trans cooler
96Sport is offline
post #10 of 11 Old 02-22-2009, 06:09 PM
LarkRoy
LarkRoy
Hunting....
What do you mean by "hunting"??
LarkRoy is offline
post #11 of 11 Old 02-23-2009, 11:36 AM
96Sport
46re(tarded)
96Sport's Avatar
It will upshift to 3rd, then downshift to 2nd, then upshift to 3rd again all with no change in throttle. This is while you're accelerating though, not cruising with the OD off or anything.
1996 5.2 4x4
-Airaid Intake
-B&M Trans cooler
96Sport is offline
    Found a cool site for dodge vehicles... hemi1569 2G Dodge RAM - General Talk 10 08-12-2008 01:43 PM
    95 Neon Auto transmission cable shift adjustment abfantom Dodge Neon - General Talk 0 01-30-2008 11:23 AM
    TV cable adjustment driving me crazy ! cerberus 1G Dodge Durango - Drivetrain Talk 1 12-03-2007 07:28 AM
    Tranny cable adjustment. Sirhilton17 2G Dodge RAM - Drivetrain Talk 1 04-13-2007 10:27 PM
    Mileage Increase FYI gray bear 2G Dodge RAM - General Talk 9 10-11-2005 10:07 PM
