Noisy lifter fix??? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 10-28-2008, 09:55 PM Thread Starter
reddodge1
reddodge1's Avatar
Noisy lifter fix???
I have a 2000 Ram Sport with 5.9 with only 58000 miles. Sounds like one of my lifters is Ticking and wondering if there was any easy way to determine what is causing this. I already tried the five minute oil flush didnt help. Is this a common problem? seems kinda soon for a lifter to be making noise. are the rockers and adjustable? any help would be great thanks
reddodge1 is offline
post #2 of 6 Old 10-29-2008, 12:50 AM
DODGEPICKUP
DODGEPICKUP's Avatar
Quoted: 2 Post(s)
are 100% sure its a lifter and not an injector ? the lifter's do tick and u can hear them at idle . stock rockers are none adjustable . try seafoam in engine . follow the direction's on how much to put in then drive about 100 mile's or so then do an oil change . i have heard of useing some marven's mystery oil but have never tried it . hope this help's ya out
1999 RAM 1500SPORT QC 4X4 5.9 3.55's grrrr
360 MAGNUM POWER 165,000 MILES DYNOED 230/290 ON 35'S
1.7 CRANE ROLLER ROCKERS
DIY CUT,PORTED,EPOXY FILLED KEGGER/ALUMINUM PLENUM PLATE,53MM THROTTLE BODY
JACOBS PRO STREET CD IGNITION
BOSCH DESIGN 3'S 24LBS VETTE INJECTORS
MOPAR P DOUG THORLEY TRI-Y'S
TAYLOR 8.2 THUNDERVOLT WIRE'S
EBC ROTORS N PADS,RUSSELL SS BRAKE HOSES
MARCH UNDERDRIVE CRANK PULLEY
1 TON X-OVER STEERING
DT PRO-FAB TRAC BAR
HELL BENT STEEL 2IN SPACER/SKJ LCA
WINNDEKAR/DSS STEERING BRACE
DODGEPICKUP is offline
post #3 of 6 Old 10-29-2008, 08:34 PM Thread Starter
reddodge1
reddodge1's Avatar
I hear it at idle and under normal driving conditions. do the injectors make noise sometimes too?
post #4 of 6 Old 10-29-2008, 09:00 PM
DODGEPICKUP
Quoted: 2 Post(s)
Originally Posted by reddodge1 View Post
........ do the injectors make noise sometimes too?
YEP ALL THE TIME
DT PRO-FAB TRAC BAR
post #5 of 6 Old 10-29-2008, 09:04 PM Thread Starter
reddodge1
reddodge1's Avatar
what causes the injector noise?
post #6 of 6 Old 10-29-2008, 09:18 PM
DODGEPICKUP
Quoted: 2 Post(s)
some injector just tick louder then others . the pink top furd's i'm running now tick even louder .
if a tick per say gets so loud u need to turn the stereo up then yes u have a problem and need to pin point where its coming from .... use a stethascope or even a long pipe and listen around the intake .
DT PRO-FAB TRAC BAR
    Lamp out fix... closer9 3G Dodge RAM - Interior/Exterior Talk 1 02-19-2007 07:00 PM
    does your 3.0 belt FALL OFF or SQUEAL? We have the fix..... MiDnIgHtRuMbLeR Dodge Caravan General Talk 0 12-22-2006 10:57 AM
    How-To: Fix your window motor for cheap coachholland 1G Dodge Durango - Tech Articles 3 10-09-2005 10:06 PM
    A fix is in for liftgate spoiler gasket seepage mklein Dodge Magnum - Interior/Exterior Talk 3 09-22-2005 11:40 AM
