Durango vibration!!!! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 04-08-2004, 08:58 PM Thread Starter
jpi99
jpi99's Avatar
I have a 98 Durango and get a vibration over 60 mph. I've rotated and balanced tires a number of times, got an alignment, and replaced tie rods but to no avail. My tires are 33x12.5 BFG ATs but the vibration only starting recently so I don't think its the tread. Any clues as to whats going on here?
thanks Jason
1998 black Dodge Durango 5.2L SLT 4x4, 3" Rancho suspension lift, 3" PA body lift, 35x12.5x15 Mickey Thompson Baja MTZ tires, American Eagle 589 15x8 rims, Rancho RS9000X shocks, 4.56 Precision gears, Westin chrome step bars, Westin chrome safari bar, Manik stainless tail light guards, chrome differential cover, KC Hilite 100w black slimlites w/switch, Pilot back-up lights, TYC black altezzas, APC clear corners, GTS headlight covers, K&N drop in, limo tint, Hypertech Power Programmer
http://members.cardomain.com/lifteddurango
jpi99 is offline
post #2 of 5 Old 04-09-2004, 07:52 PM
Duranged D
Hard to tell but most vibration problems are caused by tires. Perhaps you have a broken belt or sidewall damage. Good luck and let us know when you figure it out.
"DURANGED D"
_____________________________________________
1998 Durango SLT
4-WD
5.2/318
AEM "Brute Force" Cold Air Intake
AEM Throttle Body Riser
Fastman TB
Gibson Shorty Headers
Gibson Cat-Back Exhaust
Hypertech Power Programmer III
160*T-Stat
MSD 6A Ignition
MSD Super Coil
Accel 8mm Plug Wires
Edlebrock IAS Shocks
Flex-a-Lite Black Magic Extreme Electric Fan
ASP Underdrive Pullies
BF Goodrich 31 x 10.5 x 15 T/A KO
After-market Chrome Grille
EGR Smoke-tinted High-profile Superguard Wraparound Deflector w/Fender Brows
Lund Hood Scoop
Duranged D is offline
post #3 of 5 Old 04-09-2004, 08:02 PM Thread Starter
jpi99
jpi99's Avatar
I'm having 2 tires swapped out tomorrow so hopefully that will solve it. Was driving on the highway today and went through a turn and it started to vibrate pretty bad, steering wheel was bouncing up and down big time. My tires at the most have 5k miles on them.
jpi99 is offline
post #4 of 5 Old 04-27-2004, 12:12 AM
MrSkott
MrSkott's Avatar
Would be good to get your ball joints checked out...they are the reason I get tire hop at above 60 too.
Skott
1999 Durango 5.9 SLT *stock* (for now)
Done building the Toy.
Time for the Dodge.
MrSkott is offline
post #5 of 5 Old 04-27-2004, 06:30 AM
Ugg
The A#1 Original!
Ugg's Avatar
jpi99:
I had a similar problem but it turned out to be a balance issue, And ya checked out all that other stuff and your getting 2 tires swaped. Have them put them on the rear and the rears put on the front, this way you'll find out if the tires ya got before were from a bad batch. I also agree that you should check out your ball joints. That is a BIG issue with the D's.
Later
Ugg
Later
Ugg
The One, The Only, The A#1 Original
The Original DOC Black Sheep #1.
Signature Police Officer # 013
2001 Durango R/T, Patriot Blue with All factory options but block heater.
*Fastman TB. *JBA Headers. *DynoMax Flo Thru Muffler. *Hitch Mounted 55 Watt Back-Up Lights. *Yellow Krypton Fog Lights. *Nu-Image Flame Glo Gauges. *Orange Flame Seat Covers. *Autolite 3923 Plugs. *Remote Start-Up & Alarm. *Country Craft Brushed Aluminium Grille & Billet. *Blue Indiglo Glo Gas And Brake Pedals. *Lund Sun Visor. *LUND Rear Window Deflector. *Removed Factory Running Boards. *Rancho RS 9000 Shocks. *Ken Thompson Wheel Well Covers. *All Steel Skid Plates Installed To Replace Plastic Skids. *IP Stage II Cold Air Intake. *Rosewood Dash Kit by Trim King. *Cargo Liner by CargoLiner. *WeatherTech Vent Visors. *T-Bars cranked Up 3 Turns. *Extra Leaf Added Per Side On Rear Springs, *Rams Head Tail Light Covers. *55 Watt Back-Up Light Bulbs (installed in normal location for MORE light). *Go Rhino Hitch Step. *Ash Tray & Cup Holders Mounted by 2nd Row Seats. *American Flag
& Black Ribbon Mounted on Antenna. *Lest We Forget, Fuzzy Dice. *Oh, & A Little White German Shepherd On The Dash, Howling.
PENDING REPLACEMENT
*Kumho Venture AT 275/60x17 Tires (WARNING, these tires are GARBAGE!
*Replaced with 15" Yoko Geolander's.
To Be Installed One Day Soon, I Hope
*Blue Engine Dress-up Kit, Made By Toucan Industies. *Jimmi Jammers. *Strobe Lights fore & aft.
The Beast
*1942 WC 53, 3/4 ton Dodge Carryall. *#152 of 8400 Made. *318 V8. *5 spd Trans. *4:86 gears. *Full Time 4WD.
Ugg is offline
