buying/bought a 1986 d 150 royal se - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 10-09-2008, 11:39 AM Thread Starter
dolfans
Quoted: 1 Post(s)
as of 10/09/08 i put a down payment on this truck and will pay,pick it up tomorrow.it's short bed,auto,ps,air,and pw.it is a 2 tone red and white and red inside.it has 3 wheels like the general lee has and the spare on other wheel. have to do some body work and clean the motor up and inside.its missing the radio and the door panels is loose on the driver side and the carpet is off there too.i will have to put a muffler on it and the pass side wiper dont work,and get it inspected.hope it will pass with out the muffler(the pipe goes to the be).the pass power window switch is rigged up and will have to fix that.hope to post pics this weekend ps he has replaced the altinator(spelling?),water pump,fuel pump and plugs and wires.
dolfans is offline
post #2 of 7 Old 10-09-2008, 01:57 PM
1972-D100
1972-D100's Avatar
Quoted: 3 Post(s)
Congrats on the purchase! Look forward to seeing some pictures and progress...
My other car is a DODGE truck that will run over and past your Rice Burner!!
[B]1972 D100 Adventure Sport
[B]1973 D100 Adventure SE
1972-D100 is offline
post #3 of 7 Old 10-10-2008, 08:58 AM
67469
Guest
Posts: n/a
Quoted: Post(s)
How much did you get it for? I have an 82 D150 Royal, I got for $650... Hasn't let me down yet.
post #4 of 7 Old 10-10-2008, 11:25 AM Thread Starter
dolfans
Quoted: 1 Post(s)
i paid $650.00 and will have to put a muffler on it,fix the pass wiper,and the trans mount needs fixing.and i need a inspection sticker but will fall bc of the wiper and maybe the muffler.
dolfans is offline
post #5 of 7 Old 10-10-2008, 11:52 AM
67469
Guest
Posts: n/a
Quoted: Post(s)
Shouldn't be that hard to get all that done. Once those are done, it should have no problems passing inspection.
post #6 of 7 Old 10-14-2008, 06:05 PM Thread Starter
dolfans
Quoted: 1 Post(s)
i got the truck sat and today i fixed the pass wiper and now they both work.i had a mechanic look at it.he said that both motor mounts and the trans mount need replacing.only one was on and that was the lf motor mount.the parts are about $10.00 each and about $115.00 to put on 3 hrs.also need wheel bearings,direct link bar i think it is called $85.00,front brakes $25.00 and rotors and studs $36.00 each for about $115.00 for 3 hrs.i need a heater hose and the parking brake cable-it has some rope now.i need the rubber for driver window for out and inside.as earlier i said it is leaking gas this morning and has a leak in the rear main seal.also was told it has a different trans.i will try to post pic tomorrow.also what is the royal se package thanks
dolfans is offline
post #7 of 7 Old 10-14-2008, 07:00 PM
bherder
Mopar Madness - Get it...
bherder's Avatar
I read that four times and still am not clear on what you said...
(All I know is, I'm SO happy I don't live in a county with smog/vehicle INSPECTIONS..)
"There's been a DODGE in my garage since 1974"
bherder is offline
    Factory Stock 1/4 mile and 0-60 times. dodgeneonACR98 Street and Strip Talk 8 05-05-2009 07:53 PM
    1986 Dodge 150 Custom Wiring Diagram SlotCarDragway 1972-1987 Dodge Ram Trucks (D, W-series) 11 09-30-2007 10:44 PM
    1986 Dodge Ram 150 with V8 318 2bl carb Viperk 1972-1987 Dodge Ram Trucks (D, W-series) 5 10-02-2005 02:17 PM
    Whats the firing order for a 1986 Dodge Ram 150 with 318 V8 Viperk 1972-1987 Dodge Ram Trucks (D, W-series) 7 05-25-2005 03:53 PM
    Replace Starter on 1986 Dodge Ram 150? P3790 Dodge Ram Truck 1st Gen (88 - 93) Forum 5 08-02-2003 03:57 PM
