Where is the ASD relay? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 09-17-2008, 04:55 PM Thread Starter
RussNash
Quoted: 1 Post(s)
Hi everyone! Just found this forum and this is my first post, thought it would be rude to not say "Hi" first
I have a 2006 1500 quad cab with the 4.7L v8, I've been trying to find the ASD relay but am totally confused. The service manual I have says that it is in the PDC next to the battery, however, all I can find in it are fuses. Removing the unit there are the expected wiring looms coming out of the bottom, but I can't for the life of me figure out where the ASD relay is located? Do I need to get into the insides of the PDC to get at it ... or am I being dumb?
Any help would be appreciated, this is confusing the heck out of me!
Russ.
RussNash is offline
post #2 of 7 Old 09-17-2008, 07:56 PM Thread Starter
RussNash
Quoted: 1 Post(s)
It seems that there are absolutely no relays housed in the PDC next to the battery on the 4.7L 06 & 07. Does anyone know where the relays were moved to in these trucks?
RussNash is offline
post #3 of 7 Old 09-17-2008, 08:06 PM
RubberFrog
I RECOMMEND FUKKEN WAX
RubberFrog's Avatar
That's a good question. On the older models there were a ton of relays in the PDC. I am assuming your using a manual for your year. Let's see what one of the electrical guru's havs to say.
'07 QCSB, Flame Red 5.7 4x4 SLT
Performance:
Internal: Custom Cam, 180 T-Stat - Intake: Ported Throttle Body, K&N Filter - Exhaust: Edelbrock Shorties, Magnaflow Y Pipe, Raceland Cutout, Dumped Gibson Catback
Tuning & Monitoring: SuperChimps, Aeroforce Interceptor w/ afr
Suspension & Tires:
Lift: 6" Suspension, 3" Body Lift - Wheels: Custom Painted BMF S.O.T.A.s, 37" Trail Grapplers, Mopar Wheel Well Liners
Appearance:
Bed: Leer 100XQ Shell, Line-x XTRA, Defender Roof Rack - Other: SRT Hood, Bushwacker Pocket Flares,Tow Mirrors, Nerf Bars, 2500 Tow Hooks, Shorty Antenna, Tactical Grill
AV:
Tunes: Kenwood DDX512, Infinity Reference Speakers, Kicker 10" Sub, Kicker 400.1 Amp, FoxBox - Video: 10.4" TFT-LCD Flip-down Overhead Monitor, R Cam, Chuck Norris Kicked My Ass
Lighting:
Led Tails, Smoked Cab Lights, 4x VisionX 180w, Hella 500's
RubberFrog is offline
post #4 of 7 Old 09-17-2008, 08:15 PM Thread Starter
RussNash
Quoted: 1 Post(s)
I have a copy of the "2006 Dodge Ram Truck Workshop Service Repair Manual" in pdf format. When looking up the ASD or other relays in the index, the page states that it is 'located in the PDC', however, the PDC in the diagram is always the bigger style as in the hemi. The PDC in my 4.7 is much smaller than the hemi's and only contains fuses.
The manual deals with 3.7, 4.7, 5.7 and diesel so I don't know why it won't differentiate? Maybe they changed the 4.7's PDC mid model year????
RussNash is offline
post #5 of 7 Old 09-17-2008, 11:26 PM
piper18
Great View
piper18's Avatar
Russ.
On the 06 and newer there are no relays, its all solid state
2008 Dodge Ram 1500 4x4 SLT, 5.7 Hemi MDS, Regular Cab, Long Box, 3.55 LS rear end ,17" cast wheels, Flame Red
Member of the Red Truck Club #231
Switch installed in chime circuit to turn off chime
Installed MDS indicator light on dash ---
Tools Box w/ lights inside tided to cargo light
Custom made deer guard 2" pipe
Sportsmaster Tonneau cover w/top gun fabric
Mopar rear wheel liners
Iron Cross stainless 3" step bars
Tailgate open indicator light
9005 fog light bulbs
piper18 is offline
post #6 of 7 Old 09-17-2008, 11:39 PM Thread Starter
RussNash
Quoted: 1 Post(s)
Well that definitely explains it, thanks for the input!
Guess I'll need an add-a-circuit if I want to switch a relay on and off only with the engine running.
RussNash is offline
post #7 of 7 Old 09-17-2008, 11:47 PM
mopar314
Master FLiP'n P SRT-8 Ram
mopar314's Avatar
Yep, thats correct! The PDC is now called the TIPM(Totally Integrated Power Module) for 2006 and up. And the TIPM is relay-less, with the modules Low and High side drivers doing all the work now. ("Don't mind that we have had more problems with the TIPM's than we seem to have with the PDC" <---- are my thoughts)
"The only thing necessary for evil to triumph is for good men to do nothing." - Edmund Burke
Bright Silver Metallic#185 2007 Dodge Ram 1500 SLT-4.7 Liter-Regular Cab-Short Bed 287 Enthusiast Member#314
20" Argent Aluminum Wheel / 3.92 LSD / AirRam Power Wire / AirRam Jet Stream Scoop / AERO Turbine AT3030XL Muffler
SRT-10 Hood / SRT-10 Push Button Start Switch & Trim Bezel / SRT-10 Accelerator Pedal / SRT-10 Quad Cab Brake Pedal Pad
"SRT" Grill Emblem / SRT-10 A-Pillar Pod Trim Panel Post / Aeroforce Technology Interceptor Scan Gauge (Blue Readout/Black Face/Silver Ring)
2" Drop Shackles / Mopar Rear Wheel Well Liners / Mopar Vent Visors / Line-X Bedliner - UnderRail
mopar314 is offline
    1998 24v diesel seems weak joshuafiscus 2G Dodge Ram Diesel Talk 3 01-27-2007 09:47 PM
    1996 Dodge Grand Caravan LE AC/Heater Blower, Relay and Resistor Block Problems 101 HeadlessHorsemn Dodge Caravan General Talk 4 01-16-2006 07:55 AM
    HELP!!! Code P0132 SHADOW QUAD CAB 2G Dodge Dakota General Talk 4 04-30-2005 10:00 PM
    Problem code baseball401 1G Dodge Durango General Talk 2 04-17-2005 12:56 AM
