How to adjust Emergency Brake? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 08-30-2008, 10:55 PM Thread Starter
ShawnQ
Is there a way to adjust the Emergency Brake on an '01 1500?
The pedal goes all the way to the floor a lot easier than it should...which leads me to believe it either needs to be adjusted, or the rear brakes are gone. The rear brakes are fine, so I'm assuming I should be able to adjust the E-brake.
For the record, the previous owner replaced the cable that goes from the rear driver's brakes to underneath the drivers door. I'm not sure if he may have made the brake out of adjustment when doing so, or if it is just time to adjust it/replace it.
There is a threaded rod/nut mechanism underneath the driver's door that I believe I could tighten to get more pedal tension - is this the correct thing to do, or is it supposed to adjust automatically?
Any info is appreciated.
Thanks,
Shawn
2011 1500 Crew Cab Sport 4x4, Deep Water Blue, Hemi, 3.92s, Bilstein 5100 Leveling Shocks, Hooker Aero Chamber muffler, Tractor Supply toolbox (flush mount), Curt front end receiver hitch, Weathertech front/rear
ShawnQ is offline
post #2 of 5 Old 08-31-2008, 07:30 AM
tkirk
work in progress
tkirk's Avatar
the threadded rod is your adjuster all you have to do is tighten it up and you are back in buisness
tkirk is offline
post #3 of 5 Old 08-31-2008, 09:34 AM
charlie1935
charlie1935's Avatar
Quoted: 6 Post(s)
Before adjusting the E-brake cable be sure that the brakes are adjusted.
Grouchy Old Man
Sport short bed
R&S Automotive cat back duals
SSBC slotted rotors
Tri wing tonneau cover
Ultra 50/51 16x10 wheels
265 70x16 Firestone Destination LE tires
3.55 rear
99-01 sport headlights with Silverstar bulbs
MSD coil
Fram Boost intake -Freebie. I won it
Edelbrock shocks
Yes, grandpas like toys too
87 D100 318 auto. stock
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist'
charlie1935 is offline
post #4 of 5 Old 08-31-2008, 12:53 PM
hrusso
hrusso's Avatar
I agree with charlie. Nevermind the feel, does the parking brake, not emergency brake hold ? Have the truck on level ground in neutral and try to push it.
98 Ram 1500 CC 4x4 5.9
52mm fastman TB
ASP crank pulley
Accel ignition kit
Mopar headers
Magna Flow 3 inch cat-back
Transgo shift kit
4.56 gears
Eaton E-Locker(front)
CP aluminum diff covers
35x12.50R17 on Moto Metal 6 Rims
Superlift 5inch with 4 link front(not radius arm)
Thuren front shock mounts
Fox 2.0 resevoir front, Fox Emulsion rear
Trailmaster steering stabilizer
D/T track bar
Kodiac sidewinder steps
Comp Cams roller #20-744-9
M-1 intake
Edelbrock Heads
Scorpion 1.7 rocker arms
24lb FMS injectors
Parts in box
Comp Cam
Edelbrock Intake
hrusso is offline
post #5 of 5 Old 08-31-2008, 03:19 PM Thread Starter
ShawnQ
The brake holds, but it goes to the floor when I press it, which is abnormal.
SQ
ShawnQ is offline
    Brake switch TREP R/T 3G Dodge RAM - General Talk 4 02-05-2007 11:40 AM
    Intermittant Emergency Brake Light- 2000 GC steve_rn Dodge Caravan General Talk 1 01-08-2007 09:33 AM
    Squeaking brakes HELP! SeanRPM 3G Dodge RAM - General Talk 13 11-13-2005 06:46 AM
    Brake Pads DurangoDude 1G Dodge Durango General Talk 0 05-08-2002 01:00 PM
