Misfire Codes P0300 & P0302 - '03 4.7 liter - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 08-11-2008, 09:42 PM Thread Starter
wilsemail
These codes were present along with the one for catalytic converter inefficiency. Coolant was missing, and pressure was building in the radiator. I figured 'head gasket' so I tore it down. When I got the heads off I noticed #2 had some aluminum corrosion that compromised the compression into the water jacket. I resurfaced both heads, and reassembled with new bolts and new gaskets. I returned the truck with new NGK Iridium plugs. Customer called back and said the engine light is on again. I checked it out and the burnt coolant seems to have cleared out of the cat and no more inefficiency there. But the random misfire and #2 misfire came back. Weird. The coolant is fine, and there's no pressure in the radiator. Do you think the codes somehow didn't clear even though I used a scan tool to clear them? Runs fine.
wilsemail is offline
post #2 of 9 Old 08-11-2008, 11:00 PM
krs
I know you know your stuff but maybe this link will help?
http://www.obd-codes.com/p0300
2002 Ram 4.7L 2wd Sold
Performance: 4.56 Gears, H/O Cams, 2008 Intake Manifold, 70mm TB, 4" Custom MIT Tube, Gibson SS Headers, ATI Pulley, SCT Tuned by FlyinRyan,2.5" Custom Y-Pipe With Magnaflow High Flow Cat and Muffler (12580) SI/DO Turn Down After Axel, Jeep Grand Cherokee TCM,
Suspension 4" CST Spindles, 1" Body Lift, 2" Lift Shackles, Doetsch Shocks
Others Srt-10 Pillar With Tranny Gauge, 16 Row Tranny Cooler, Color Matched Grill Shell
krs is offline
post #3 of 9 Old 10-29-2008, 10:32 PM Thread Starter
wilsemail
I found out that the engine shakes occasionally and cylinder 2 still misfires occassionally, enough to kick on the engine light. Now, I know cylinder 2 had coolant leaking into it, and that big problem is solved, but the misfire is still there occasionally. I replaced the coil and the fuel injector and still shakes. What do you suppose it could be? Do you think the spark plugs are bad? Even though they're new. NGK Iridiums? Do you think they need too much energy to fire? Anyone?
post #4 of 9 Old 10-29-2008, 11:05 PM
roskoe115
roskoe115's Avatar
Maybe a broke wire that is barely making contact on the coil pack? Or a wire further down the system.
02 RAM SPORT DIESEL
Edge juice hot, stage 4 nozzles, Suncoast converter & valve body, BD RAD, Industrial Injection Silver Bullet 66.
roskoe115 is offline
post #5 of 9 Old 10-29-2008, 11:16 PM
Kens03Ram
Kens03Ram's Avatar
I agree with Roscoe in that it could possibly be a wire. But could easily be a bad plug as well. Could trouble shoot it by swapping plugs with #2 and #1 cylinders, clear the code and see if the code pops up on #1. As for the NGK Iridiums needing too much energy,, don't think thats the issue. I have ran those for over a year now with no problems.
2003 1500 QC, 4.7
*Dodgetalk.com 287 Enthusiast Member # 5*
Semper FI
Kens03Ram is offline
post #6 of 9 Old 10-29-2008, 11:18 PM
roskoe115
roskoe115's Avatar
wouldn't take long for that test.
02 RAM SPORT DIESEL
post #7 of 9 Old 10-29-2008, 11:32 PM
04totowcj7
im running ngks no issues in the 4.7, or the brothers dak or the sisters stang. when it comes time to pull the plugs again i will throw new ones in and call it good. ide swap the #2 plug with #1 and the coil pack with #3 move the two apart and see if either one does it.
287 enthusiast club # 147
Air ram power wire, Jet stream scoop
Home made cold air intake with k&n race filter
04totowcj7 is offline
post #8 of 9 Old 11-05-2008, 09:50 PM
Kens03Ram
Kens03Ram's Avatar
What was the verdict?
2003 1500 QC, 4.7
Semper FI
post #9 of 9 Old 11-05-2008, 10:17 PM Thread Starter
wilsemail
I will see the truck this weekend. I will swap two of the spark plugs and wait again for the verdict. Even though they're new, I understand that they could have either been bad or I could have accidentally damaged them and not realized. I'll keep you posted.
Thanks!!
    P0300 Random/multiple misfire with oil leak. protegechris Dodge Caravan General Talk 16 06-24-2008 03:26 AM
    misfire P0300 byo71 1G Dodge Durango General Talk 2 08-28-2007 09:36 AM
    P0302 cylinder 2 misfire detected JustDave45 2G Dodge RAM - General Talk 7 02-09-2005 08:48 PM
    4.7 Cylinder Misfire rryerso 2G Dodge Dakota General Talk 11 12-06-2004 05:20 PM
    Oil gauge on a 2000 QC 4.7 liter duketter 2G Dodge Dakota General Talk 2 10-12-2003 01:08 AM
